Old 11-08-2014, 08:56   #31 (permalink)
Member: 1677616
Thanks Meter: 6
i also have the same problem how can we solve it ?
Old 11-08-2014, 08:56   #32 (permalink)
Member: 1677616
Thanks Meter: 6
have same problem. iphone 4s error29 pls any solution?
Old 11-08-2014, 08:58   #33 (permalink)
Member: 1677616
Thanks Meter: 6
I have same problam plz any one help
Iphone 4 restore error 3194 on ios7.0.1
Old 12-06-2014, 16:35   #34 (permalink)
Member: 1999993
i think its an battery problem, try change it with an genuine battery and not aftermarket one, i think it will work
Old 01-08-2015, 09:23   #35 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 266
The Following User Says Thank You to ameerali19 For This Useful Post:
Old 01-12-2015, 11:27   #36 (permalink)
kharimobiles's Avatar
Member: 1814389
Sonork: 100.1621147
Thanks Meter: 30
i have the same problem error 29 on iphone 4s.....????
Old 03-09-2015, 09:00   #37 (permalink)
Member: 2359382
hi
sorry for my bad english!
yes, it is battery problem.
simplest way is replacing battery.
but let's be pro.
the gas gauge wire on the flex makes the problem. because it's at outer side of flex cable and is very thin and disconnects easily.
if someone has a healthy iphone 4s battery, share the connection way from socket to battery board. so we'll can do wiring.
Old 05-01-2015, 10:03   #38 (permalink)
Member: 2358551
My iphone 4s error 29 the same ????
Old 06-02-2015, 20:20   #39 (permalink)
..::KASHIF::..'s Avatar
Member: 1294044
Thanks Meter: 1,269
change battry 100% solution for error 29
i test
1000000% work
not sol chek Video hadrwer
https://www.youtube.com/watch?v=wOXmrFnDnQI
Old 07-22-2015, 10:46   #40 (permalink)
Member: 2119236
Thanks Meter: 3
I have same problem. I have try to replace the battery, all condesator beep and found In the right position (R153 R61 ecc). The only thing I noticed is that the phone does not remain open with the battery attached , but have to be connected to a charger to power up in recovery mode
Old 12-16-2015, 15:58   #41 (permalink)
Member: 1120289
Thanks Meter: 148
How you did to solve it?
Originally Posted by deepak_atoz View Post
perfect answer 100000000000% tested by me
thx mate
how you did to solve it please .
Thanks in advance
Old 03-28-2016, 08:25   #42 (permalink)
Cheater -Don't Deal with him-
Member: 2262340
this hardware problem
try change battery
if still not working try Remove Battery and check the battery ways, there are 4 caps. Make sure that they are all in place and not damaged or corroded. If they are all in place you will need to replace the PMIC on motherboard. If you see damage to caps then you can simply remove them off a different motherboard and add to the phone you are trying to fix.
Old 03-30-2016, 16:18   #43 (permalink)
Member: 689942
Thanks Meter: 312
The problem is battery
Tested and aprovved
Old 04-06-2016, 09:06   #44 (permalink)
Member: 2085676
Thanks Meter: 299
i try change battery and r153 nd r61 but not slove error 29
pls help
Old 04-18-2016, 09:33   #45 (permalink)
Member: 2528954
change battery 100% Tested 29 eror fix
Page generated in 0.20274 seconds with 8 queries
