08-23-2010, 01:40 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Partap Mobile Point, Jalandhar
Member: 1088851 Status: Offline Thanks Meter: 17 | Downgrade done for 3Gs on 4.0.2 To 4.0.1 Navigate to C:\Windows\System32\drivers\etc\ and locate “hosts” file. Open this “hosts” file in Notepad and add this line in the end 74.208.105.171 gs.apple.com And then i open my itune using 9.2.1, Select shift+restore and phone starting downgrade.......wow |
The Following 4 Users Say Thank You to partapmobile For This Useful Post: |
08-23-2010, 02:21 | #3 (permalink) |
Member: 1088851 Status: Offline Thanks Meter: 17 | I never save my shsh b4. By mistake this phone i restore to 4.0.2, and then i start looking the solution but no chance to dwngrd......after lots of searches here i found something abt TinyUmbrella........here is my TinyUmbrella log.... 08/23/2010 00:03:23.890 The Real Firmware Umbrella - v4.02.04 by semaphore 08/23/2010 00:03:23.890 For help click here 08/23/2010 00:03:23.906 Connect a device to continue... 08/23/2010 00:03:24.500 NOT running as administrator OR your hosts file is not editable - Cannot listen on port 80! TSS Server will not work! 08/23/2010 00:03:24.531 Caching shsh files... 08/23/2010 00:03:24.546 Found [2] shsh files to cache... 08/23/2010 00:03:25.093 Cached [2] shsh files 08/23/2010 00:03:32.671 You are using the current version of TinyUmbrella. 08/23/2010 00:03:33.578 Device Detected - Device: iPhone3GS 4.0.2 (8A400) Model: MB715LL/A Name: AMAN UUID: 76BEF98FFFF9C06DCBDDDFDD418E4EE72A9DCD35 Baseband: 05.13.04 - 6.4_M3S2 08/23/2010 00:22:03.546 Device disconnected:76bef98ffff9c06dcbdddfdd418e4ee72a9dc d35 08/23/2010 00:22:10.031 Recovery Device Detected - iDevice:80945SEY3NP 08/23/2010 00:22:11.281 Recovery Device disconnected. 08/23/2010 00:22:19.625 Recovery Device Detected - iDevice:80945SEY3NP 08/23/2010 00:22:26.484 Recovery Device disconnected. 08/23/2010 00:29:47.687 Device Detected - Device: iPhone3GS 4.0.1 (8A306) Model: MB715LL/A Name: iPhone UUID: 76BEF98FFFF9C06DCBDDDFDD418E4EE72A9DCD35 Baseband: 05.13.04 - 6.4_M3S2 08/23/2010 00:31:54.968 Device disconnected:76bef98ffff9c06dcbdddfdd418e4ee72a9dc d35 08/23/2010 00:32:16.953 Device Detected - Device: iPhone3GS 4.0.1 (8A306) Model: MB715LL/A Name: iPhone UUID: 76BEF98FFFF9C06DCBDDDFDD418E4EE72A9DCD35 Baseband: 05.13.04 - 6.4_M3S2 08/23/2010 00:42:37.953 Device disconnected:76bef98ffff9c06dcbdddfdd418e4ee72a9dc d35 After this i pass thru HOSTS file procedure and got everything done |
08-23-2010, 02:42 | #4 (permalink) |
No Life Poster Join Date: Nov 2005 Location: USA
Member: 197538 Status: Offline Thanks Meter: 97 | @Partapmobile Please next time dont deny regarding saving the shsh files here is proof from from tiny umbrella log 08/23/2010 00:03:24.546 Found [2] shsh files to cache this procedure only works for shsh files saved on cydia thanks mike |
08-23-2010, 02:48 | #5 (permalink) | |
Insane Poster Join Date: Dec 2009
Member: 1181806 Status: Offline Thanks Meter: 5 | Quote:
08-23-2010, 03:02 | #9 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1375278 Status: Offline Thanks Meter: 3 | I dont have a before and after of the phone screen, but it definitely works. here's what i did. Followed steps from these threads: http://forum.gsmhosting.com/vbb/f456...-02-a-1078191/ http://forum.gsmhosting.com/vbb/f456...0-1-a-1078190/ So thanks to partapmobile, and MPhoneClinic. 1 - I downloaded TinyUmbrella (google it, you'll find a link) 2- Run TinyUmbrella. Click Advanced Option. Select 3Gs 4.01. Select Cydia. Save SHSH. 3 - Same steps as above but Select 3Gs 4.0.2 (cant be too safe) 4 - Edited Local host to say following: 74.208.105.171 gs.apple.com 5 - Rebooted iPhone into Recovery Mode, chose 4.0.1 IPSW And voila, it worked. I know i'm probably not creditable because this is my 4th post, but I had a 3Gs with no SHSH saved ever. Followed these steps and officially downgraded to 4.0.1. |
08-23-2010, 03:30 | #10 (permalink) |
Member: 1181806 Status: Offline Thanks Meter: 5 | 8/22/2010 20:33:03.703 Asking CYDIA for SHSH blobs for iPhone3GS 4.0.1 (8A306)... 08/22/2010 20:33:15.109 SHSH SUCCESSFULLY saved! [Click Here to Open] 08/22/2010 20:33:15.125 You have saved your SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 08/22/2010 20:33:15.140 Caching shsh files... 08/22/2010 20:33:15.156 Found [1] shsh files to cache... 08/22/2010 20:33:15.218 Cached [1] shsh files 08/22/2010 20:33:19.625 Starting TSS service on port 80 08/22/2010 20:33:19.625 TSS Accepting connections... 08/22/2010 20:33:19.640 TSS Server Started! for how long it will finish..??? |
08-23-2010, 03:57 | #12 (permalink) | |
Junior Member Join Date: Aug 2010 Location: somewhere in island
Member: 1375515 Status: Offline Thanks Meter: 4 | Quote:
how about if you encountered an error using tinyumbrella..? | |
08-23-2010, 03:59 | #13 (permalink) |
Member: 1181806 Status: Offline Thanks Meter: 5 | 08/22/2010 20:33:03.703 Asking CYDIA for SHSH blobs for iPhone3GS 4.0.1 (8A306)... 08/22/2010 20:33:15.109 SHSH SUCCESSFULLY saved! [Click Here to Open] 08/22/2010 20:33:15.125 You have saved your SHSH locally and the request was sent to CYDIA. This means that CYDIA DOES have your SHSH. Do NOT bug semaphore about the Cydia home page showing this version. 08/22/2010 20:33:15.140 Caching shsh files... 08/22/2010 20:33:15.156 Found [1] shsh files to cache... 08/22/2010 20:33:15.218 Cached [1] shsh files 08/22/2010 20:33:19.625 Starting TSS service on port 80 08/22/2010 20:33:19.625 TSS Accepting connections... 08/22/2010 20:33:19.640 TSS Server Started! that mean i had save .shsh ??? Yes I did same ae instruction |
08-23-2010, 06:08 | #15 (permalink) | |
No Life Poster Join Date: May 2007
Member: 512970 Status: Offline Sonork: 100.1584185 Thanks Meter: 134 | Quote:
The Following User Says Thank You to mounir0020 For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
