Problem Please help an internal problem and not the program iphone4 iphone 4 problem dfu ********* Problem error 1601 iphone 4 |
change usb port your done |
iPhone Hardware problems Changed everything |
where he said hardware problem he just said modify host file of your computer :( |
Changed the computer |
The problem was screen Changed |
i will be pleased to help you |
is your device on springboard or recovery or dfu ? |
plug ur device and restore without screen if you have the same error 1601 check your HOST file note that itunes must be closed when deleting the 2 ip's to take effect if it persist try to restore to the latest firmware but take care with baseband if you have unlockqble one use a custom one and pwned dfu it is safer |
thanks a lot here's english hahahahaha when i changed the iphone4's screen unfortunatly the new one was bad so i have this problem ======> black screen how can i change the dfu mode and what is the IC responsible for dfu mode because it might be problem or may be the problem in the IC of the screen driver when i pluged the device the itune gives me the error 1600 or 1601 i tryed the programs for this error and no effect i also changed the screen so many times with defferent ones and the problem doesn't solved i changed the bord it self and still no effect here's the problem clearly i neeeeeeeed solution |
