Problem with (re)jailbreak on ios 5.0.1 iphone 4s - any idea??? I got iphone 4s jailbroken but there is no Cydia icon on it. I can install cracked ipa apps via itunes, i have access to system files. Iphone DOESN'T have ssh installed so i can"t ssh and instsll DEB FILES :( i dont have iFile installed - if i get it i could do everything :( Mayve someone know where i can download from iFile IPA formst? Then i could instsll DEB Cydia file manually by this software... Now i re-jailbreak by the newsest redsnow 0.9.10b8 ..i got succesfull jailbroken and iphone restarts but after it still no Cydia icon :(( Any idea what is wrong? P.S. absinthr 0.4 dont work - it says Already Jailbroken..:( I cant restore to 5.0.1 firmware cause apple signs onky 5.1... BR |
i did jailbreak on iphone 4s 5.0.1 with absinthr and was fine installing cydia. and the shsh is 5.1. i cant unlock this. me too have problem on iphone 4s sprint 5.0.1. |
PLEASE read carefully :) IPhone: How To Manually Install Cydia 1.1.1 On Your iOS Device BUT use i-funbox or itools 2012 instead http://forum.gsmhosting.com/vbb/f456...4/#post8281766 Take the cydia *.deb file and paste in the designated folder. Then follow rest of the steps as given. Post results |
Not working As u see i dont have ssh and ifile in my iphone but its jailbroken :) I can install ipa by itunes and by itools no problems But to install DEB files manually u need ifile Autoinstall dont work :) Tested many times before so still no idea how to recover cydia icon back and make it workimg? Maybe next relese of redsnow will fix this issue :( No success :( |
use pc software buddy. just try it |
I-funbox and iTools. by default shsh open now for some odd reason |
Ifunbox and itools install only IPA files not deb files...no idea :( |
which PC software can install DEB files??? there is no solutin yet... |
Reboot Phone and try again. |
very funny :) dont post messages if u have no real solution to solve my problem :) |
if you are jailbreaked and can see the jailbreaked icon on ifunbox or iTools 2012 it's 2000% solution. tried and tested. that's only if cydia.app is missing and you are jailbroken. pls check again before doubting my advice |
I will post screenshot for you if u like |
I dont have Cydia.app original I re-upload it from other iphne 4 but still no success No reaction after putting deb files in autoinstall folder - nothing... Now i see cydia icon (uploaded Cydia.app folder from other iphone 4) but when i start it goes to springboard Othes cracked appss working well, still i can indtall ipa files by itunes But cant recover my cydia :( Any idea how to install iFile without cydia? It would be easier.. |
I said put. cydia.deb file in autoinstall buddy |
delete cydia app from applications only and then put cydia 1.14 deb file in autoinstall then reboot two time http://rdsbc.********.com/2011/04/how-to-install-ifile-150-4-deb-file-for.html?m=1 |
