Old 09-16-2012, 19:25   #1876 (permalink)
Member: 1811719
Iphone 4 16GB network/SIM problem
I bought iphone 4 on O2 Ireland used one, i upgraded it to 5.1.1 then i activated the phone with o2 sim card now the problem is when i try to use any other irish O2 sim card it says no service when i put the SIM through which phone activated it works.
Note:first time i activated with 3 ireland and it works and was not taking any other sim then again with o2 and was not taking 3 second time third time with o2 and works only with that o2 through it was activated
Thanks
Old 09-25-2012, 10:29   #1877 (permalink)
zry
Member: 1662128
can i use iphon net on loptop?
Old 09-25-2012, 11:28   #1878 (permalink)
Member: 319697
Thanks Meter: 12
plzzzzzz help iphOne 4 wifi icOn nOt shOw sOme bOdy help me
Old 09-26-2012, 00:33   #1879 (permalink)
Member: 1806419
Sonork: redapplerahul
i have iphone4s which is ireland meteor.i dont have original carrier simcard.that is why,i can't activate it.plz help me to give any solution,which can activate it & also jailbreak it..
& can i use it by turbo sim or any other process or factory unlock is possible??
Old 09-26-2012, 08:07   #1880 (permalink)
Member: 707088
Sonork: moonstarmobile
iphone
booting problem in iphone 3 8gb
plz make gud solution pls anu body help me
Old 09-28-2012, 23:49   #1881 (permalink)
Member: 1816979
hey please halp me
sory for bad eanglish
im olredy 5 dayis traying to fix my iphone 2g with error 23 or 1600
and im not able to do that
traying redsn0w 094 to unlock bicus i see that it flash somting so i put the bootloader file and run it so it stuck after rebot on the bootNeuter 2.1 this say determining currrent settigs...
and stay like it looot time so what shold i do please halp
thaaanks allot for any halp!!!!
Old 10-02-2012, 05:01   #1882 (permalink)
Member: 1680267
Thanks Meter: 22
i want to downgrade ios 6.0 to 5.1.1
but i dnt have saved shsh blobs.
or
u have any idea abt data working on iphone 4 cdma model?
i flashed to reliance but data is not working.
Help Need Thanks in Advanced
Old 10-02-2012, 09:10   #1883 (permalink)
Registered User
Member: 1360757
hii ihave iphone 4s with network searching problem i did restore with ipsw downloaded file it shows error plz help me urgent
Old 10-04-2012, 01:56   #1884 (permalink)
Member: 1819965
Hi, I have iPhone3GS the battery died and after replacement, when I try to charge it , instead to charge display it shows the connection sign without charging (matter of fact it drains the battery ).
What could be the problem?
Thank you
Old 10-04-2012, 23:11   #1885 (permalink)
Crazy Poster
Member: 1763949
Sonork: 100.1639086
Thanks Meter: 13
hello everyone
I have error 20 when i try to restore my 3GS
how can i fix its ??
plz give me a solution .............
Old 10-05-2012, 01:39   #1886 (permalink)
Member: 126801
Thanks Meter: 23
Thank you
try to change another good battery
Old 10-05-2012, 11:24   #1887 (permalink)
Member: 1749326
Sonork: 5283
brother tell me how i add videos or apps via Itune
Old 10-07-2012, 08:43   #1888 (permalink)
Member: 1612815
i Have A iphone 3gs 32gb 4.1 when i tried to jailbreak nd update to 5.1.1 it using redsnow it hanged on the screen just after uploading jailbreak data saying 'transferring control to jailbreak data'
Old 10-07-2012, 18:58   #1889 (permalink)
Member: 1635186
Greetings from Amsterdam, Hallo People, Well i just managed to roger an iphone 3gs 32gb.I bought it second hand, it was stuck on itunes logo after the previous owner upgraded to ios 6. I managed to get it going , jailbroke it installed ios 4.1. Then i found out that it was not charging via wall socket or usb port on computer. Well it did charge , but only a bit and would not charge any further , so i managed to jailbreak with this little charge. Also found out during the course of jailbreaking that the home button did not work at all, managed to put it in dfu mode through blackra1n. All went through beautifully. Read on google that it is a battery problem , so i changed the battery from another dud 3gs 32 gb i bought second hand, no joy. So i googled further and concluded that it was the dock connector , bought a new one and went about replacing it, in the process of replacing it i botched up my LCD, got a white screen, numerous attempts of replacing connectors 1, 2 and 3 did not solve the problem. I could hear the sound from the iphone saying something about my music etc, itunes recognised it, but the white screen would not allow me to see whether the issue of charging and the home button was resolved or not.
Decide to test the whole top portion LCD,DIGITIZER ETC ON ANOTHER PHONE AND YES THE LCD WORKS ON THE OTHER PHONE , DECIDED TO SWAP LOGIC BOARDS AND AGAIN BOTH LCDS THAT WORKED ON THE OTHER PHONE DO NOT WORK ON THIS ONE. dEDUCTION ROGERED LOGIC BOARD.
aBSOLUTELY CLUELESS AND WILLING TO EXPERIMENT , ANY SUGGESTIONS AND HELP WILL BE A GODsent if there is a ***.
Old 10-07-2012, 22:11   #1890 (permalink)
Member: 1802241
I bought a Iphone 4 from a girl and she told me all it would do is say searching... I read where the battery can be changed and sometimes that helps so I did, I also tried the turning on and off airplane mode and that didn't work. Took the phone apart, checked connections, checked for corrosion and found nothing. Could it be a bad part of somekind? Any ideas? It is a Iphone 4, GSM phone. Thanks in advance.
is any problem with this flashing procedure ? miq Twisterflasher 6 04-12-2004 07:32
Any problem with new italian T*M 64K ? hanglider_62 Sim Cloning and Scaning 4 07-14-2003 08:11
is there any problem with T10 made in Estonia ? nightxyz Old Ericsson Phones & Sony Phones 0 08-30-2000 05:54
Page generated in 0.28724 seconds with 10 queries
