04-05-2012, 18:39 | #2 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Another one ... You will be 21th for today . http://forum.gsmhosting.com/vbb/f456...leted-1350948/ Quote:
04-06-2012, 08:22 | #3 (permalink) |
Junior Member Join Date: Sep 2009 Location: bahawalnagar
Member: 1122708 Status: Offline Thanks Meter: 3 | How to Jailbreak or update 5.1 iOS with Sn0wbreeze Step 1 Download Sn0wbreeze 2.9.2 Download iOS 5.1 Download iTunes 10.6 Connect your iPhone, iPad or iPod Touch to iTunes and backup your personal stuff Step 2 Run the Sn0wBreeze.exe. Hit Ok, Close Credits and then hit the next button. Step 3 Hit the Browse button and select the iOS 5.1 IPSW file for your iDevice that you downloaded in Step 1. Sn0wBreeze will identify the IPSW firmware file. Then hit the Next button. Step 4 Select the Expert Mode, hit Next; Select General and hit Next; Make your desired choices, then keep hitting Next until you’re back to the screen where you selected General. Step 5 Select the Build IPSW option and hit next. Sn0wBreeze 2.9.2 will start building custom iOS 5.1 firmware to jailbreak your iPhone, iPad or iPod Touch. Sno0wbreeze offers you the choice to play PacMac during the IPSW building process or stick with the Spinner. Once Done! Hit the OK button. (Custom firmware 5.1 can be found on desktop along with an iBooty folder) Step 6 Now follow the on screen Sn0wBreeze instructions *important* to put your iPhone, iPad or iPod Touch into Pwned DFU state NOT the simple DFU mode. Hold Power + Home buttons for 10 seconds Now release the Power button but keep holding the Home button for 10-30 more seconds Sn0wBreeze will prompt you once you’re into Pwned DFU state. Your device should now be in DFU mode. Step 7 Now open iTunes, Hold down the Shift/Option key and hit the Restore button. Browse and select the custom firmware that we just created, from the desktop. iTunes will start restoring iOS 5.1 on your iPhone/iPad/iPod Touch. Once done, your iPhone, ipad or iPod Touch will be running iOS 5.1 jailbroken tethered. How To Tether Boot On your desktop, there’ll be a new folder named iBooty. Open the folder and run the iBooty.exe. Select your device from the drop down menu (bottom-right) and hit the start button. Follow the on screen instructions to put your iDevice into DFU mode. Hold Power + Home buttons for 10 seconds. Now release the Power button but keep holding the Home button for 10-30 more seconds Your device should now be in DFU mode Once you’re into DFU mode, iBooty will do the rest and your iPhone, iPad or iPod touch will boot into jailbroken state! |
04-06-2012, 08:36 | #4 (permalink) | |
Member: 40400 Status: Offline Thanks Meter: 1,250 | Quote:
upgrade from ver 4 to ver 5.0.1 | |
The Following User Says Thank You to ribbentrop For This Useful Post: |
04-08-2012, 04:05 | #7 (permalink) |
No Life Poster Join Date: Mar 2004 Location: world wide
Member: 57836 Status: Offline Thanks Meter: 47 | i still lookig for answare how to do that and i see no body have it also i did search i this forum & i did not find how to do that HOW CAN I UPDATE iPHONE 4 FROM OS 4 TO OS 5.0.1 WITHOUT CHANGING THE BASE BAND |
04-08-2012, 05:54 | #8 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | no way to upgrade without changing baseband, and u cant restore to 5.0.1, u must restore to 5.1 and baseband must be upgraded. correct me if im wrong, just newbie's view. br |
04-08-2012, 07:04 | #9 (permalink) | |
If yes : - you can upgrade without rising up BB ( use last redsnow for that, stitch+bb cut) If no: - no, you can't In both cases use this facked search button ! | |
04-08-2012, 16:15 | #10 (permalink) | |
Member: 57836 Status: Offline Thanks Meter: 47 | Quote:
the unit need to upgrade from 4 too 5 it was not in iOS 5 befor, it's 1st time for updating | |
04-09-2012, 00:06 | #12 (permalink) |
Freak Poster Join Date: Oct 2005 Age: 40
Member: 186734 Status: Offline Thanks Meter: 165 | If the phone has been jailbroken before then yes, it may be possible to upgrade your phone to 5.0.1 |
The Following User Says Thank You to zeezoo For This Useful Post: |
04-09-2012, 02:48 | #14 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1745112 Status: Offline Thanks Meter: 0 | If the phone has been jailbroken before then yes, it may be possible to upgrade your phone to 5.0.1 http://forum.gsmhosting.com/vbb/f489 |
04-10-2012, 03:17 | #15 (permalink) |
Member: 1745542 Status: Offline Thanks Meter: 1 | You can use this to upgrade! The introduction and use of methods can be seen here! http://aba.su/MAqc7I |
The Following User Says Thank You to lophgsf For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
