Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
08-06-2008, 12:07 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | TRY THIS CODE , MANY CODE & PINOUT HEAR:- CHINA MOBILE CODES AND PINOUTS CHINA MOBILE CODES AND PINOUTS CHINESE MODELS: default user code: 1122, 3344, 1234, 5678 Engineer mode: *#110*01# Factory mode: *#987# Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200 Restore factory settings: *#987*99# LCD contrast: *#369# software version: *#800# software version: *#900# set default language: *#0000# Send set English language: *#0044# Send set English language (new firmware): *#001# Send ------------------------------------------------------------------------- ==================== Motorola-A1200 Cect-C600 keyboard top, connector_1x8_mini 6: Rx 7: Tx 8: Gnd ==================== Samsung-E712D keyboard top, connector_1x8_mini 2: Rx 3: Tx 8: Gnd ==================== GStar-GM128 Samsung-E730+ keyboard top 1.........24 1: +Vcc 2: +Vcc 3: +Bat 4: +Bat 6: Tx 8: Rx 11: Gnd 17: Gnd 20: Gnd ==================== Cect Q300 keyboard top 1.........18 ==================== Samsung-X810+ Samsung-D500i Samsung-D600i keyboard top 1.........18 3: Gnd 7: Rx 9: Tx ==================== Nokia-N70C TIANYU A699 ??? keyboard top 1.........18 1: +Vcc 2: +Vcc 4: Tx 5: Rx 8: Gnd 11: Gnd ==================== Nokia-G6-Power-MPEG4 connector_2x6_mini 1: 2: 3: 4: 5: 6: Gnd ?? 7: 8: 9: 10: 11: 12: Gnd ?? ==================== Cect-S560 Cect-Q618 Nokia-N73 Nokia-N83 Nokia-N95 Nokia-N730 connector_2x6_mini 1: 2: Vcc 3: Vcc 4: USB D+ 5: USB D- 6: Rx 7: Tx 8: Gnd 9: HF ear 10: HF ear 11: HF mic ==================== Smarj-S70: points under battery near sim holder ANTENNA 1 2 3 4 5 1: Rx 2: Tx 3: Gnd ==================== GStart-GM238: points under battery near MMC ANTENNA 1 2 3 4 5 1: Phone Rx 2: Phone Tx 3: Gnd ==================== Nokia-8800i: points under battery near sim holder ANTENNA 1 2 3 4 1: Rx 2: Tx 4: Gnd ==================== Samsung-D900 Samsung-E900 keyboard top 1.........18 4: Rx 5: Gnd 9: Tx 17: +Charge ==================== Samsung-D820 Nokia-N85 Nokia-6300 18 pin ==================== Cect-N168 Nokia-N800 A950 keyboard top, connector_1x12_mini 5: Gnd 6: Tx 7: Rx ==================== Samsung-D820 Nokia-N77i Nokia-N88 Cect-C600 Camry-V138 Everfo-E863 keyboard top, connector_1x12_mini 1: Gnd 7: Tx 8: Rx ==================== Nokia-N95 slider keyboard top, connector_1x12_mini 1: Gnd 6: Tx 7: Rx ==================== Nokia-N95 slider keyboard top, connector_2x6_mini 1: Rx 2: Tx 4: Gnd 8: VBat 12: Gnd ==================== Cect-T689 Nokia-N99 keyboard top, connector_1x12_mini 6: Tx 7: Rx 12: Gnd ==================== Nokia-3280 keyboard top, connector_1x12_mini 1.........12 7: Rx 8: Tx 9: Gnd ==================== GStar-G2 GStar-GM208 GStar-GM238 GStar-GM308 GStar-GM508 GStar-GM608 GStar-GM618 Nokia-8800i Samsung-E760 Samsung-E730C connector_2x6_mini 1: +Vcc 2: 3: Gnd 4: Rx 5: USB D- 6: Gnd 7: +Vcc 8: 9: 10: 11: Tx 12: USB D+ ==================== GStar-GM328 Samsung-D900 connector_2x6_mini 1: HF ear 2: Gnd 3: +Vcc 4: 5: Tx 6: USB D- 7: HF ear 8: HF mic 9: +Vcc 10: +Battery 11: Rx 12: USB D+ ==================== Nokia-N95 (T98) connector_2x6_mini 1: Tx 2: Rx 6: Gnd 5: connect to pin 12 12: connect to pin-5 ==================== Nokia-N95 keyboard top 1.........18 8: Gnd 11: Gnd 13: Rx (RJ-45 pin-2) 14: Tx (RJ-45 pin-3) ==================== Nokia-N95-PDA keyboard top 1.........18 1: Gnd 2: Gnd 7: Rx 9: Tx ==================== Cect-M1818 connector_2x7_mini 7: Tx 8: Rx 10: Gnd ==================== Cect-N1818 connector_2x6_mini 3: Gnd 9: Rx 10: Tx ==================== Cect-N1818 Cect-M901 connector_2x6_mini 3: Rx 5: Gnd 10: Tx ==================== Cect-Y809 connector_2x6_mini 4: Tx 9: Rx 12: Gnd ==================== L7 connector_2x6_mini 1: Gnd 6: Rx 7: Tx ==================== GStar-GM108 KEYBOARD TOP 1.........24 6: Tx 8: Rx 11: Gnd ==================== Motorola mpeg4 v3+ keyboard up 1........18 10: Gnd 13: Rx 14: Tx 17: +Charge 18: +Battery ==================== Cect-P168-9900 ______________ +B _. . Tx__. . ._Gnd . . Rx__. _________________ ==================== 1. for flash/unlock/reset you must use only 3 wires: Rx, Tx, Gnd 2. other pins description (f.e. +v, USB etc.) only for your reference (f.e. if you need to build your own charger) ==================== phone bottom connector_2x6_mini __________________ / 1 2 3 4 5 6 \ | 7 8 9 10 11 12 | -------------------- ==================== phone bottom connector_2x7_mini _____________________ / 1 2 3 4 5 6 7 \ | 8 9 10 11 12 13 14 | ----------------------- ==================== phone bottom connector_2x5_mini _______________ / 1 2 3 4 5 \ | 6 7 8 9 10 | ----------------- ==================== phone bottom connector_1x8_mini _________________ / 1 2 3 4 5 6 7 8 \ ------------------- ==================== phone bottom connector_1x12_mini ___________________________ / 1 2 3 4 5 6 7 8 9 10 11 12\ ----------------------------- ==================== Nokia-N288 keyboard top 1..........8 1: Vcc 4: Gnd 7: Tx (RJ45 pin-2) 8: Rx (RJ45 pin-3) ==================== Nokia-N92 keyboard top 1.........18 1: Gnd 2: Gnd 7: Rx 9: Tx ==================== Nokia-6300i keyboard top 1..........8 1: Vcc 6: Tx 7: Rx 8: Gnd ==================== Nokia-N73 connector: the same as original Nokia keyboard top 1.........13 2: Rx 3: Tx 7: Gnd 8: Gnd 10: Gnd 13: Gnd ==================== Samsung-A838 Samsung-A99 keyboard top 1.........10 2: Tx (RJ45 pin 3) 3: Rx (RJ45 pin 2) 7: +power Gnd: take from pcb ==================== m-448 gsm mpeg 4 dual simcard (simtray under ringer) connector_2x6_mini 3: Rx 5: Gnd 10: Tx ==================== Nokia-N94s 2simcard phone with big LCD connector_2x5_mini 3: Gnd 8: Phone Tx 9: Phone Rx ==================== Nokia-N95i-Bluetooth-PDA keyboard top 1.........18 1: Gnd 2: Gnd 13: Gnd 4: Rx 5: Tx ==================== Motorola-L7+ keyboard top 1.........18 1: Gnd 11: Tx 12: Rx ==================== M660 connector_1x8_mini 4: Gnd 5: Tx 8: Rx ==================== Nokia-8030 keyboard top 1.........18 4: +V 5: +V 10: Tx 12: Rx 17: Gnd 18: Gnd ==================== MP4-K18-PDA connector_1x8_mini 3: Rx 4: Tx 5: Gnd ==================== ZT-6618 ZTC-ZT6618 Xingtai-338 connector_2x5_mini 10: Gnd 4: D- 6: D+ 2: +5V ==================== ZT-6618-PDA-2sim connector_1x8_mini 3: Rx 4: Tx 5: Gnd ==================== Huayu-K888 16 = rx red 17+18 = gnd 15 = tx white ==================== Bird: connector 18 pins keyboard top 1.........18 3: Gnd 12: Rx 13: Tx ==================== Bird: connector_2x5_mini keyboard top 1..........5 1: Gnd 3: Rx 4: Tx ==================== TCL-M580 connector 8 pins keyboard top 1..........8 3: Rx 4: Tx 5: Gnd ==================== TCL: connector_2x5_mini 4: Rx 5: Gnd 6: Tx ==================== TCL-U80 test points under battery 1 2 3 4 5 6 7 5: Rx 6: Gnd 7: Tx ==================== TCL-V6 keyboard top 1.........18 8: Gnd 13: Rx 14: Tx ==================== TCL-V18 keyboard top 1.........18 15: Rx 16: Tx 18: Gnd ==================== Porsche-Cayenne connector_2x6_mini 1: Gnd 2: Rx 7: Gnd 8: Tx ==================== MPEG4-A968 0--- 0---vbat 0---tx 0---rx simtray here 0---gnd ==================== Nokia-N95(T99) 2 sim connector_2x5_mini 1: +V 4: phone Rx (RJ45 pin 2) 5: phone Tx (RJ45 pin 3) 6: Gnd 10: connect to phone pin-1 ==================== Swatch-Mobile-M300 connector_2x5_mini --- unlock/flash --- 1+6: Gnd 7: Rx 8: Tx 5+10: +5v --- usb data cable --- 1+6: Gnd 9: white usb 4: green usb 5+10: +5v ==================== BMW-A8 connector 2x7 6-Gnd 5-vpp 4-Rx 9-Tx Version info *#43*# ==================== V666 connector 2x7 ==================== Motorola-K1 17: Rx 18: Tx 19: Gnd ==================== Nokia-V8-slim connector 2x7 ==================== MPEG4-touchscreen-PDA keyboard top 1.........18 3: Tx 4: Rx 9: Gnd 10: Gnd 17: Gnd 18: Gnd ==================== Nokia-5300 Nokia-3250 Nokia-6280 slider keyboard top 1.........18 8: Gnd 11: Gnd 13: Rx (RJ-45 pin-2) 14: Tx (RJ-45 pin-3) ==================== 2GSM-2sim keyboard top 1.........18 1: Gnd 3: Gnd 13: Tx 14: Rx ==================== Nokia-N95s Nokia-N95-PDA Cect-P168 connector_2x5_mini 4: Phone Rx (RJ45 pin 2) 5: Phone Tx (RJ45 pin 3) 6: Gnd ==================== Nokia-N96i connector_2x5_mini 1: Tx 2: Rx 6: Gnd 5: connect to phone pin-10 10: connect to phone pin-5 ==================== GStar-GM209 GStar-G851 connector_2x7_mini 3: Gnd 6: Tx 13:Rx ==================== GStar-GM809 connector_2x7_mini 2: Gnd 11: +bat 12: Rx 5: Tx ==================== Cect-V6 Vertu Veptu connector_2x6_mini 1: Gnd 2: Rx 7: Gnd 8: Tx ==================== Cect-N81 keyboard top 1.........18 3: Gnd 7: Gnd 10: Gnd 12: Gnd 14: Gnd ==================== Malata-M696 keyboard top 1.........18 2: Gnd 3: Gnd 10: VBat 18: VCharge ==================== Cect-U8800 Sony-Ericsson-K800 Nokia-6700i keyboard top 1.........18 1: Gnd 9: Tx 10: Rx 12: Gnd ==================== Cect-N1000 Cect-S500 O2 mini 3D Vertu-8088 Veptu-8088 Narnia-8088 Xunchi-138 O2-S500 keyboard top, connector_1x8_mini 1:Vcc 2: 3:V changer 4:USB 5:USB 6:Rx 7:Tx 8:Gnd ==================== Nokia-N73 (new release, PDA screen big than old model) Nokia-N75 small Cect-V668 Pocket_PC-1688-2sim keyboard top, connector_1x8_mini 1: Gnd 2: Tx 3: Rx 4: USB D- 5: USB D+ 6: +Vcc 7: +Vcc |
The Following User Says Thank You to debmobile For This Useful Post: |
08-06-2008, 20:04 | #7 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 440163 Status: Offline Thanks Meter: 2,470 | Are you sure your phone have english language? The best way for you is flashing your set with same original version, but never forget make fully backup before makeing any action. B.R |
Samsung i780 need how set english language | Unicom | UST Pro II | 0 | 11-19-2009 14:48 |
Samsung i780 need how set english language | Unicom | HTC & Smartphones ( WM Without Touch) | 0 | 11-19-2009 14:12 |
LG U8330 after Downgrade How to set in english Language? | irish_4 | LG | 1 | 06-21-2008 13:25 |
plz tell me hw to set english language for sagem myx6-2 | sachin_udai | ARM9 BASED M62 / M62+ | 1 | 02-29-2008 16:02 |
Cect U8800(11) set in English | intervix | HTC & PDA WM( With Touchscreen) | 0 | 11-09-2007 10:25 |
