Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 08-25-2008, 11:18   #1 (permalink)
Member: 695023
Thanks Meter: 53
5310 warning !bad contact charger!
anyone knows how to solved this problem....5310 when i put charger it shows charger connected but after a minute it shows ...warning bad contact charger...ived already cleaned the contact inside but no luck....it is posible its a software problem or what?
anyone encounter this problem and how to solved...
your suggestion well be appriciated.....
The Following 2 Users Say Thank You to ACID_ICED For This Useful Post:
Old 08-26-2008, 02:46   #2 (permalink)
Member: 695023
Thanks Meter: 53
update......update....
please....
The Following User Says Thank You to ACID_ICED For This Useful Post:
Old 08-26-2008, 08:23   #3 (permalink)
Member: 639286
Thanks Meter: 27
just check "k" if ok than flash or make a jumper.but it shows it is a hardware problem.
The Following User Says Thank You to hackeroflove For This Useful Post:
Old 08-26-2008, 08:55   #4 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,734
hardware problem
change charging ic/transistor.
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 08-26-2008, 10:31   #5 (permalink)
Member: 818748
Sonork: 00000
Thanks Meter: 44
first step by step repair,,,,the charging pad pls clean,,,dc jack,,,,if same
pls full flashing the phone
The Following User Says Thank You to edwin08 For This Useful Post:
Old 08-26-2008, 11:54   #6 (permalink)
israrbjr's Avatar
Member: 748544
Sonork: 100.1601881
Thanks Meter: 173
plz checked by another orignel charger
The Following 2 Users Say Thank You to israrbjr For This Useful Post:
Old 12-08-2008, 14:33   #7 (permalink)
Member: 669717
no solysan hekpppppppppp
The Following User Says Thank You to dp001 For This Useful Post:
Old 12-09-2008, 06:02   #8 (permalink)
teknospc's Avatar
Member: 852415
Sonork: 1606874
Thanks Meter: 218
Is not a Software problem, try to change the charger from original Nokia and the problem can be solved, when this kind of problems appears the data cable red ( + ) positive is need to be tested ....
The Following User Says Thank You to teknospc For This Useful Post:
Old 02-01-2009, 11:07   #9 (permalink)
Registered User
acelai00's Avatar
Member: 255011
Thanks Meter: 56
hi bro,u just rehot the cpu and power ic the problem wil be solved.i have a N82 have this problem too,already solved,good luck....
The Following User Says Thank You to acelai00 For This Useful Post:
Old 11-09-2010, 09:05   #10 (permalink)
Member: 1099351
Thanks Meter: 60
Here Are The Solutions. Please Observe Carefully.
Click Here
More : Mobile Repair
Old 01-28-2011, 09:12   #11 (permalink)
Member: 1184434
Thanks to gsmforum, i appreciate your support in inproving gsm technology. *** bless you.
Old 01-28-2011, 09:29   #12 (permalink)
Member: 1052020
Thanks Meter: 30
hardware problem check charging section
Old 01-28-2011, 10:55   #13 (permalink)
Crazy Poster
Member: 521984
Thanks Meter: 16
G'Five U808 Warning! Bad Contact Of Charger Saleemsmj Chinese Models & Cloned Phones 22 07-07-2011 07:43
Wanted really solution for Warning! Bad Contact-Charger IkaMazini Chinese Models & Cloned Phones 6 11-09-2010 09:09
nktel a 300 warning bad contect charger prateet Chinese Models & Cloned Phones 5 01-21-2010 12:55
sprint 7700 warning bad contact charger .:NOYON.: Chinese Models & Cloned Phones 2 02-23-2009 07:03
lg c2500 WARNING BAD CONTACT CHARGER gsmsikar LG 0 11-26-2007 08:50
Page generated in 0.18350 seconds with 9 queries
