Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 03-02-2009, 16:36   #1 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
china mobile on emergency
bro,some brand new china mobiles are on emergency mode and does not shows signals,any tested solution.
The Following User Says Thank You to zeeshan tayyab For This Useful Post:
Old 03-02-2009, 16:47   #2 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
chinge imei dear of this
Old 03-02-2009, 16:56   #3 (permalink)
Member: 877138
Thanks Meter: 10
Yes only change imei problem will solve tested many time.
Old 03-02-2009, 17:34   #4 (permalink)
gooshi_shah's Avatar
Member: 614090
Sonork: 100.1583645
Thanks Meter: 66
thanks brother
i do manual farmat now?
Old 03-03-2009, 09:42   #5 (permalink)
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
not effective,still same
Old 03-03-2009, 10:16   #6 (permalink)
Registered User
Member: 985433
i hv changed imei, unlock , formate but same problem
Old 03-03-2009, 17:19   #7 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
check and change PA., all will be okay.. i done many by change PA
Old 03-15-2009, 03:42   #8 (permalink)
Member: 990338
Thanks, but how I can change PA?
Old 03-15-2009, 11:34   #9 (permalink)
thomp4pal's Avatar
Member: 292106
Sonork: 100.1582885
Thanks Meter: 116
1. Look for Exact PA IC from other brands of china phone
2. When u get same PA, Remove the one from the faulty phone with an SMD Rework station ( Note the Position and Notch of PA ic).
3.Now Remove PA ic from other board, be sure the ic is good... Resolder it On your own phone in the correct positioning.
4. Now test phone, if not work Rehot cpu...
B.R
thomp4pal
Old 03-15-2009, 12:23   #10 (permalink)
Mr. Right's Avatar
Member: 796514
Sonork: 100.1583845
Thanks Meter: 53
its hard ware problem not software or changing imei, just try to check its antena components
Old 03-15-2009, 13:02   #11 (permalink)
.::skybird::.'s Avatar
Member: 594884
Thanks Meter: 1,553
Just Format your phone with any tool then write the eeprom and full flash.
.::skybird::.
Old 04-20-2010, 15:43   #12 (permalink)
Member: 199814
Thanks Meter: 1,960
i am unable to find few firmwares as they are realy new... :P
Old 09-23-2010, 05:28   #13 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
the best way .......search working phones of same models in local market and read flash then write the read flash in faulty mobile
Old 10-20-2010, 10:48   #14 (permalink)
Member: 1041401
Thanks Meter: 14
hi guys in some new china handset shows emergency.
I format the phone & also checked IMEI no. ok
but still same.
is there any solution for it
plz HELP me
Old 10-21-2010, 05:38   #15 (permalink)
mane_15's Avatar
Member: 1403558
Thanks Meter: 35
very hard solution dear,,,,,thnksssss
Emergency in china mobiles Tahir Riaz Chinese Models & Cloned Phones 26 04-08-2014 09:09
how do i activate internet on my china mobile kbsiti Chinese Models & Cloned Phones 3 05-25-2012 12:37
china mobile on calibration mode,please helpme!!!!!! faju Chinese Models & Cloned Phones 25 03-05-2011 06:58
about to install java on china mobile phone harry5641 Chinese Models & Cloned Phones 3 09-11-2010 02:58
need help on flashing china mobile phones tewariamit Multi-box LITE 4 06-04-2008 03:59
Page generated in 0.20899 seconds with 10 queries
