Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 08-12-2010, 13:37   #1 (permalink)
Member: 1343713
Thanks Meter: 26
g five keypad not working
in a g five change display after 1 day all keys not working formate set but same wash board give some heat but same plz guide m
Old 08-12-2010, 13:47   #2 (permalink)
kiran84's Avatar
Member: 504441
Thanks Meter: 29
dear 1st change keypad strip if not ok then rehot uem ic ur problem will b solved 100%
Old 08-12-2010, 14:05   #3 (permalink)
dvd_anwar's Avatar
Member: 896667
Sonork: 100.1586139
Thanks Meter: 1,596
china phone all key not work for this type of problem-
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
(C) though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E)
though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
Old 01-30-2013, 16:50   #4 (permalink)
Member: 1748687
Sonork: 100.1656932
Thanks Meter: 26
which model
it's logic system or direct adjust pcb ???/
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
wintesla doesnt work ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-23-1999 14:51
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Page generated in 0.14312 seconds with 9 queries
