02-18-2014, 07:14
#1 (permalink)
Member: 1823421
Sonork: = r3dsk!n = Thanks Meter: 8 | ckk c55 phone dead after format... help :( ckk c55 phone dead after format... help Quote:
Volcano Updated: 2014-02-11
Connecting...
Connection successful,connected state!
Version: V3.8
SN:459-967-590
Port:COM103
After format or Flash you have to press & hold power button for at least 1.30 mins.
Note for win7 users :
Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'.
After that the spd drivers will have the ability to be loaded.
For many phones, charge pins need to be set in order to identify USB devices.
Detecting D+ and D-...
Vcc: 10
Gnd: 1 4
Detection initiated...
D+ = 9, D- = 8
Detection D+/D- with 5.40 seconds!
Continue to detect BOOT pin...
BOOT(Pull Down) = 6
Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00)
Detection completed.
Setting pinouts...
Pinout setting complete.
Available Ports:COM1 COM103 COM104
Vcc: 10
Gnd: 1 4
Analyzing D+ and D-...
D+ = 9, D- = 8
Detection D+/D- with 1.14 seconds.
BOOT(Pull Down) = 6
Setting...
Find USB device:SCI USB2Serial (COM104), (VID_1782&PID_4D00)
Pinouts setting complete!
Internal version: SPRD3
Boot downloaded.
Start boot please wait a moment....
Please change Boot or reduce Baudrate, try it again.
Ready to read/write again, please remove the power supply clip or battery and then re-loaded it.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.64 seconds.
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.19 seconds.
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Spreadtrum Boot Block version 1.2
CPU TYPE:SC6531 [65310000]
FLASH ID: 00C8006000170000
Flash Type:[GD] 25LG64bWL
Reading completed.
The data has been saved in C:\Users\apache\Desktop\ckk-c55\MOCOR_12B_6531.W13.05_Release_20140218_135403_ FullFlash.bin, size: 8 M.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Set to Factory successfully.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.36 seconds.
Pinouts are not fonud!
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.61 seconds.
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Writing completed.
Flash file C:\Users\apache\Desktop\ckk-c55\MOCOR_12B_6531.W13.05_Release_20140218_135403_ FullFlash.bin has been written.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.20 seconds.
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Writing completed.
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.67 seconds.
BOOT(Pull Down) = 6
Setting...
Temporary does not support this guide to read the reset function
Vcc: 10
Gnd: 1 4
D+ = 9, D- = 8
Detection D+/D- with 1.06 seconds.
BOOT(Pull Down) = 6
Setting...
Boot downloaded.
Writing completed.
i did backup and rewrite firmware but still the same dead.... please help |
