dragon make rokea r3850 dead plz help MODEL> rokea r3850 PROBLEM> set working normal but some time restart ACTIVITIES> READ FULL FLASH AND WRITE THE READED BACKUP (WITH EXPERT MODE AND TICKED WITH ERASE OPTION) NOW>> SET DEAD INFO> >>> Getting Mobile Connection Info... VCC Pin: GND Pin:1, Signal Pin:2, 4, 7, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:2 D-:7 >>> Scanning Mobile USB Port... Detecting Mobile USB Port :COM6 Mobile Connection Success... >>> Downloading First "boot1.bin" Success... Reading the First Boots: Spreadtrum Boot Block version 1.1 >>> Downloading Second "boot2.bin" Success... >>> Mobile Info CPU Name:6800H Flash ID:0000ADA1 Flash Size:08000000->128M Flash Name:H8BCS0PG0MBP Factory Flash:NAND_HYNIX All Done... |
try to download to support |
Bro read flash another working set.. and then full flash with volcano.. before flashing format the phone with volcano when u format the phone in that time format cpu and then flash the phone ur prob is solved... |
I have solved my rokea R3850 dead problem and I want to share my experience>>>>>>>> ** GPG DRAGON DON'T HAVE ANY BUGS (SPD 6800H READ AND WRITE)** ** ROKEA R3850 WAS DEAD BECAUSE OF MY SPD DRIVER PROBLEM OF MY PC ** 1> FIRST WHEN I CONNECTED THE HANDSET ROKEA R3850(CPU>SPD 6800H1) WITH DRAGON IT DOES NOT DETECTED THROUGH NORMAL USB(V3 LIKE) PORT. SO I CONNECTED THE HANDSET VIA DP, DM, RXD, TXD. RESULT>> SET BOOT OK, SET READ AND WRITE OK, BUT SET MADE DEAD. 2> AFTER REPAIR XP, UNINSTALLING SPD DRIVER FROM CONTROL PANEL RESULT>> SET DETECTED WITH NORMAL USB PORT(V3 TYPE), FLASHED WITH SAME BACKUP FILE, SET ALIVE.. 3> NO MATTER WHAT IS THE FLASH ID OF HANDSET ([Hyundai] HY27UF081G2AM, HYNIXH8BCS0PG0MBP, H8BCS0CG0MBR ETC.) OR WHAT IS THE MODEL NAME (R3850, R5830, R212 ETC.) MATTER IS FLASH FILE SIZE 66MB OR 132MB AND TESTED OK OR NOT... |
