Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
11-15-2011, 18:43 | #5 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1524941 Status: Offline Thanks Meter: 2 | Is it a Q5 model? [IMG]http://2.bp.********.com/-lV_V8wNcOMM/TbrzrFhxp3I/AAAAAAAAEGY/C119F8OooIs/s1600/Celular-Mp20-Q5-Qwert-2chips-.jpg[/IMG] And I don't understand too what you mean by "the phone doesn't boot"!!! |
11-15-2011, 19:20 | #6 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: Sénégal Dakar
Member: 217769 Status: Offline Thanks Meter: 24 | Quote:
THANKS | |
11-15-2011, 19:58 | #7 (permalink) |
Member: 1524941 Status: Offline Thanks Meter: 2 | Did you tried with another program? If it is Mediatek phone you can use Flashtool to format. Z3x box also have a Mediatek program, so you can try boot your phone and make format with one of these programs. Use the comport of Mcn box and don't forgot to make a backup, in case of something goes wrong Good luck! |
11-15-2011, 20:16 | #8 (permalink) | |
Ok I see . It need to pay activation for this module and I think it's very expensive for this small soft. THANKS Last edited by elhadjioumar; 11-15-2011 at 20:26. | |
11-15-2011, 20:33 | #9 (permalink) |
No Life Poster Join Date: Dec 2009 Location: NIGER
Member: 1186610 Status: Offline Thanks Meter: 333 | http://forum.gsmhosting.com/vbb/f646...-boot-1351961/ mt6252 not boot with GPGDragon 2.09 Rev 2!!! PCT Flashing added!!! mt6252 file error restore default Checking box, wait... Box Firmware version: 1.56 Device: GPGDragon - The Ultimate Box verify complete. Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast,please hold on the phone Power key Sense failure i think that its hardware problem solution needed thankx |
11-15-2011, 20:57 | #10 (permalink) |
Member: 1524941 Status: Offline Thanks Meter: 2 | So, you Z3x is not activated to mediatek. Try Flashtool, the original program for mediatek: http://forum.gsmhosting.com/vbb/f443...pdate-1319492/ Well, I'm not at work now, but I think I remember the steps. It's a bit more complicated with Flashtool, but you can Format this phone with it. If it is Mediatek, if not, I have no idea what program you can use! First, you have to go to "Options" menu then set: -"Operation method" to "NOR" (usually, these simple chinese phones have NOR memory) -"Baudrate" to your desired speed (to format, better is 115200, for read flash you can put 460800) -set comport to you mcn box port number. I'm not sure if Mcn box work with Flashtool, but another boxes like Spderman, after search pinout, work very well. If not work with your mcn box... The correct is make a backup first, in case of something goes wrong. For it you could use the "read back" tab. You can search tutorial for do that in this forum. If you are brave, like me you can only tick "Format" button in "Download" tab an then tick "Format Fat". So, connect your phone and press power button. Then you're done! After format, your phone will be fully working, but you need to repair the 2 imei. I think you can repair imei with Mcn box. |
11-15-2011, 22:58 | #11 (permalink) | |
THANKS | |
b270i with 41000101 error [ANSWERED] | scorpionly | PolarBox 3 | 1 | 11-15-2011 16:51 |
