Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 05-03-2010, 15:26   #1 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
Thumbs up All china mobiles code
ALL CHINA MOBILES CODE
*#66*# Set Factory Mode CONFIRMED
*#8375# Show Software Version CONFIRMED
*#1234# A2DP ACP Mode CONFIRMED
*#1234# A2DP INT Mode CONFIRMED
*#0000# + Send : Set Default Language CONFIRMED
*#0007# + Send : Set Language to Russian CONFIRMED
*#0033# + Send : Set Language to French CONFIRMED
*#0034# + Send : Set Language to Spanish CONFIRMED
*#0039# + Send : Set Language to Italian CONFIRMED
*#0044# + Send : Set Language to English CONFIRMED
*#0049# + Send : Set Language to German CONFIRMED
*#0066# + Send : Set Language to Thai CONFIRMED
*#0084# + Send : Set Language to Vietnamese CONFIRMED
*#0966# + Send : Set Language to Arabic CONFIRMED
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send also
Service codes BenQ:
software version: *#300#
test mode: *#302*20040615#
Service codes Pantech:
software version: *01763*79837#
service menu: *01763*476#
reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx:
software version: *#79#
software version: *#837#
Service codes VK200, VK2000, VK2010, VK2020, VK4000:
service menu: *#9998*8336# (hold #)
reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG:
software version: 2945#*#
Service codes Sony-Ericsson:
J100 software version: #82#
Service codes Fly:
2040(i) reset defaults: *#987*99# Send
MX200 reset defaults: *#987*99# Send
MX200 software version: *#900# Send
SL300m reset defaults: *#987*99# Send
SL300m software version: *#900# Send
SL500m reset defaults: *#987*99# Send
SL500m software version: *#900# Send
MP500 reset defaults: *#987*99# Send
MP500 software version: *#900# Send
Set language to English: *#0044#
Set language to Russian: *#0007#
Service codes Konka:
C926 software version: *320# Send
C926 set default language: *#0000# Send
C926 set English language: *#0044# Send
Service codes GStar:
GM208 (Chinese Nokea 6230+) engineering menu: *#66*#
Service codes Motorola:
Motofone F3 software version: **9999* Send
C113, C114, C115, C115i, C116, C117, C118 software version: #02#*
C138, C139, C140 software version: #02#*
C155, C156, C157 software version: #02#*
C257, C261 software version: #02#*
V171, V172, V173 software version: #02#*
V175, V176, V176 software version: #02#*
C168, W220 software version: *#**837#
W208, W375 software version: #02#*
ZTE Mobile1- *938*737381#
2- PHONE WILL DIPLAYED DONE
3- POWER OFF YOUR PHONE AND POWER ON AGAIN
alcatelE205
unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263#
E900 full reset: *2767*3855#
Service codes Spice:
S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200
S410 engineer mode: *#3646633#
S900 software version: *#8375#
S900 serial no: *#33778#
Service codes Philips:
S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes "Chinese" models:
Service codes BenQ:
Service codes VK-Mobile 3xx, 5xx:
service menu: *#85*364# (hold #)
Service codes LG:
KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly:
M100 software version: ####0000#
Service codes Motofone-F3:
***300* Set SIM Pin
***310* / ***311* SIM Pin ON | OFF
***000* Reset Factory settings
***644* Set Voicemail number
***260* / ***261* Auto keypad lock ON | OFF
***510* / ***511* Voice Prompts ON | OFF
***160* / ***161* Restricted Calling (Phonebook only) ON | OFF
***200608* Send: software version
***200606* Send: software version
***200806* Send: flex version
***250* / ***251* Keypad tones ON | OFF
***470* Select time format
***500* /***501* Prepaid Balance Display ON | OFF
***520* Change language
and "yes"''
chiniss cord & pin out
some chinese Mobile Code And Pinouts :::::::::::>>>>>>>>>
Service codes BenQ:
Service codes LG:
Service codes Fly:
alcatelE205
Service codes BenQ:
Service codes LG:
Service codes Fly:
***300* Set SIM Pin
and "yes"''
N95Pda and N95S Pinout
2x5
4:Rx
5:TX
6:GND
K1 Moto Pinout
4:Rx
5:Tx
6:Gnd
PDA ZT6618
1........8 pin mini Conector
3:Rx
4:TX
5:Gnd
Cect 8380
1..........8 pin mini Conector
1:Gnd
2:Rx
3:Tx
KG-200
4:Gnd
3:Tx
2:Rx
N91I
1..............12 pin Connector
5:Gnd . 12:Tx
6:Tx . 13:Rx
7:Rx .
All Chinese Mobile Code And Pinouts
hi
Service codes BenQ:
Service codes LG:
Service codes Fly:
alcatelE205
Service codes BenQ:
Service codes LG:
Service codes Fly:
***300* Set SIM Pin
and "yes"''
2x5
4:Rx
5:TX
The Following 4 Users Say Thank You to bappi1 For This Useful Post:
Old 05-06-2010, 11:27   #2 (permalink)
Member: 1285979
i have nokia e71 clone/******* phone. the only codes working are *#1234#, *#06#, *#900#, *#901#, *#0000# and *#0044#.. i cant even see my cp's software version using other codes. also, none of the reset codes work for me.. are there any other codes for clone phones. by the way, this what is written on the back sticker under the battery:
TYPE: RM-364
MODEL: E71-1
IMEI: 354101000672640
IMEI: 354101000872646
SN: E71127264
IC: 6225
thanks in advance for those who can help me with my problem.
Old 06-04-2010, 16:18   #3 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Hi.
I have a china e71 and cant see reset menu.
Any new code or trick to reset my phone?
The Following User Says Thank You to gsm_unlock2 For This Useful Post:
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 14:52
PIN1/PIN2 CODE Jon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-26-2012 04:40
Page generated in 0.20027 seconds with 9 queries
