Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 02-17-2010, 12:06   #1 (permalink)
gsm junction's Avatar
Member: 1229072
Sonork: 100.1624007
Thanks Meter: 1,644
Red face china battery low shutdown solution here...
china battery low shutdown solution by sonu
The Following 11 Users Say Thank You to gsm junction For This Useful Post:
Old 02-19-2010, 11:58   #2 (permalink)
.:.GSM-ANGEL.:.'s Avatar
Member: 69984
Thanks Meter: 170
Thanks, but what we should do? remove it or change it
... please explain bro...
Old 02-21-2010, 11:47   #3 (permalink)
Member: 632919
Thanks Meter: 13
solution is not clear
Old 02-22-2010, 02:57   #4 (permalink)
Member: 598084
Thanks Meter: 9
thanks for good share ..................
Old 02-22-2010, 03:09   #5 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
im going to test now i hAVe one with same problem
post result later
Old 02-22-2010, 04:18   #6 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
is this part present in n99i i cant find it in n99i china phone
Old 02-22-2010, 04:43   #7 (permalink)
tims's Avatar
Member: 67367
Thanks Meter: 47
@gsm junction.... complete solution with guide please and what model exactly?
Old 02-22-2010, 06:24   #8 (permalink)
Member: 78717
Thanks Meter: 18
there are 2 solution for low battery shut down
first one is if u have MT6305 POWER IC in ur Chinese handset then replace the same resistance shown in the picture.
Second one is if u have MT6318 POWER IC in ur Chinese handset the replace the power IC with New one
ur Problem is solved .............
if not then contact here again
@WBR
JAGGY - Dirty Mind
Old 02-22-2010, 06:29   #9 (permalink)
Sony_computers's Avatar
Member: 570022
Thanks Meter: 67
Change it 100% tested on many phones.
[email protected]
9896087698
Old 06-28-2010, 19:20   #10 (permalink)
Member: 715649
Thanks Meter: 4
CPU reflow.... guys....100% tested for me......
Old 07-29-2010, 17:53   #11 (permalink)
Member: 1170785
china battery low shutdown solution 1000000000% divert 104 remove by gm mobile
Old 07-29-2010, 18:33   #12 (permalink)
Member: 1355122
Sonork: inside certificate
Thanks Meter: 34
that solution dose not work all time.some china set hase no this part.that i time i solved it by reheating mtk chip as well.
The Following User Says Thank You to AFTER-END For This Useful Post:
Old 07-31-2010, 11:02   #13 (permalink)
Member: 443226
Thanks Meter: 11
low battery shutdown
Sotel E99+ chinese, low battery shutdown solved by rehoting the cpu and power supply
Old 09-14-2010, 06:55   #14 (permalink)
Member: 1264285
Thanks Meter: 3
sab nakal kar rahe hai
Old 12-10-2010, 14:11   #15 (permalink)
Member: 1455839
Sonork: benicahyadi
hello all master, any body solutions for HP etouch low battery off. thanks
Hot Hot Hot Chines Mobile Low Battery Shutdown Solution Here gsmshapon Chinese Models & Cloned Phones 43 06-07-2013 17:47
China Phone Low Battery Shutdown Solution. debmobile Infinity-Box 3 11-14-2011 07:00
china battery low shutdown solution here... atulharnal Chinese Models & Cloned Phones 7 07-10-2010 16:54
china battery low shutdown solution atulharnal Chinese Models & Cloned Phones 9 04-29-2010 13:22
china battery low shutdown solution here bgreat Chinese Models & Cloned Phones 1 03-17-2010 17:01
Page generated in 0.23877 seconds with 9 queries
