Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 05-14-2008, 16:56   #1 (permalink)
Member: 749916
Sonork: 1647914
Thanks Meter: 43
Ztc Lv915 Badsoftware
Please Help How To Solve Problum Ztc Lv918 Comming On Display Badsoftware
Old 05-14-2008, 21:05   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
How it was happened that phone become with "bad software" message ?
Old 05-15-2008, 07:58   #3 (permalink)
Member: 749916
Sonork: 1647914
Thanks Meter: 43
Idont Know Becoz Custemer Given As Bad Software
Old 05-20-2008, 12:55   #4 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
plz download eeprom_file (2 file) from infinity support area
root/flashfile/Chinesmiracle/MT6205-MT6227/repair_eeprom/
MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_02.B0E
MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__Cect-LV918_eeprom_03.B0E
dowmload firmwarefile from infinity support area
root/flashfile/Chinesmiracle/MT6205-MT6227/noname/
MOBILEDEN25_06B_PCB01_GPRS_MT6225_S00[1].M608_V_1_07_P1HXM25BC30_CN__16m_Ru_Fr_En_Th_Vn_Ar _w_eeprom.B0M
first chinesmirecle tool speed set on 460800
write eeprom
write firmwarefile
chandresh
The Following User Says Thank You to Chandreshswami For This Useful Post:
Old 06-13-2008, 14:10   #5 (permalink)
Member: 60993
Thanks Meter: 22
I HAVE A FLASH FILE OF CHINA Ztc Lv918 Badsoftware
PAWANK
Old 06-19-2008, 13:00   #6 (permalink)
Member: 60993
Thanks Meter: 22
PAWANK mob=+919421952801 plss
Old 06-19-2008, 17:31   #7 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 180
When Customer Given Its In Hang Problem Then I Can Format Its Go On Bad Software.some Mobile After Flash Ok But Mobiles Goes On White Display Any Solution For That
Old 06-20-2008, 11:42   #8 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
write eeprom
write firmwarefile
please write those files it will come on white screen but all is working good
Old 06-20-2008, 11:42   #9 (permalink)
Crazy Poster
Member: 484608
Thanks Meter: 9
write eeprom
write firmwarefile
[email protected]
Old 08-12-2008, 07:55   #10 (permalink)
vijeeshkannur's Avatar
Member: 597241
Sonork: 100.1575009
Thanks Meter: 85
infinty v2.56 repaired badsoftware successfully
model :jinpeng v9188
Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e
Loading data, wait...
[Infinity Box] v2.56
S/N: ***x:***x
Wait...
Device: Autodetect 6205-6227 NOR
Done
COM38 [VCP0] selected
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: repair "bad software"
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:7003:000A
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: SINGLE25_06B_PCB01_GPRS_MT6225_S00.J800_V1_00.BIN
ver. sw2: J800_V1.00, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting firmware protection...
detecting firmware structure #8...
done
detecting firmware structure #9...
done
detecting firmware protection failed
Finished, time used: 47 sec
Remove/Install battery now !
Model: Autodetect 6205-6227 NOR
19200 autodetect
CPU: MT6225
Connecting, wait...
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: J800_V1.00
Version: Single25_06B_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 13579024681122
warning: current phone imei is wrong !
It's need to repair imei for correct phone functionality !
connection Ok
detecting structure #6 (mode-1)...
done
163 byte(s) read
writing data...
verification...
verification Ok
Finished, time used: 12 sec
heres the log
THANKS INFINITY
UR THE KING OF CHINESE PHONES
infinty v2.56 repaired badsoftware successfully vijeeshkannur Infinity-Box 33 09-18-2008 04:38
5310 Badsoftware Extremest Problem Help Me Out Thanks waji mobiles Chinese Models & Cloned Phones 1 08-12-2008 07:51
ztc zt9198 and ztc zt918 pinout diferent? dimitron Infinity-Box 2 01-20-2008 10:11
Ztc Zt-9000 voodoogsm55 Various 0 10-13-2006 17:23
ZTC minimini phones meisam Various 0 09-03-2006 18:15
Page generated in 0.23015 seconds with 9 queries
