How To Solve SOS Call Problem In Spreadtrum CPU ? I Tried With Change IMEI & Flash + Format But No Result I Face This Problem In Many Models Like Lawow F800 Lawow F900 GNEXT GN50 Lephone U505 Nokia X1 It's Hardware Or Software ? Anyone Solved This Problem ? I Need This Problem Solution Thanks In Advance. |
Fist read it's file then write a ok set flash file over it your problem will Solve i try it with my set >>>>> |
I Tried With All Like Flash Format IMEI Etc. |
1st eras full flash by manaully flash set and format it........ur set gose dead....the write on it new flash file by reading of any working set......ur problem solved..................i have tested in 10 sets...................if not solved then ur set 100% hardware problem.............. |
just return the phone to the customer or change the phone....................... |
its a hardware fault |
Dear Friend I Tried With Same File Which Is Read From Working Phone But No Result. Quote:
Really Very Nice Reply!!! |
Yes i m also face sos problem in spd based phone if this is hardwer them how to solv plz detail |
most of the case spd cpu prob change it and u get 100% result |
its heardware foult 100 its heard ware foult 100% this is pf problam |
its hardware fault .......... |
@mygsm world SOS Call Problem In Spreadtrum CPU ? It is Hardware problem. Rehot / reball Spreadtrum cpu, and change PA/RF . GM, Parash |
Dear friend sos call & show fulse network its 100% hardware problem change PA & RF ic i am tested many handset now try & post Result |
it is hardware problem, change or rehot cpu |
