Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 06-27-2009, 01:12   #1 (permalink)
Member: 1060066
I need some help from experts
Hey guys,
I have a big problem here and I need some help
A few days ago, wrongly I changed a setting in engineer menu and my MT6225 based NokLa N83 set is gone, it's completely dead!
This is the layout of the phone.
Because of having to repair it myself (some money problems and I'm living in Turkey, there is no service for these kinds of cell phones ), I have opened the phone.
This is the picture of the circuit part of the phone.
Firstly, I have to say that, I don't have any device (or any box). I only got COM port on my old computer. (old PIII can do this job perfectly), I also got data cable of the phone but it's a USB cable and I guess I can't use
Anyway, I found pins of RS232 (com port),
It seems I have to use PIN-2 (RX) , PIN-3 (TX) and PIN-5 (Ground) on RS232
But as you can see on phone there are P_KEY and VBAT pins, and I don't know what are these What are these pins?
Also I got another question, if I format my phone, do I have to flash the OS again ? or format is just removing the changes after factory??
If anyone can help me, I would be very appriciated, I'm just a student and all of my money is gone to buy this phone. I really need to fix it
Old 06-27-2009, 07:55   #2 (permalink)
Member: 908773
Thanks Meter: 13
Do format
And your phone will work!!!!
Old 06-27-2009, 09:03   #3 (permalink)
FasGsm's Avatar
Member: 283725
Sonork: 100.1584053
Thanks Meter: 1,927
Originally Posted by phx666 View Post
Hey guys,
P_key =power key
vBat=vibrator
but u don,t need these points 2 format ur set u just need 3
rx
tx
gnd
also u need com cabel to format ur set.com has 3 wires rx,tx and gnd and just attach ur com caebl rx,tx and gnd to phone rx,tx and gnd.
to format ur set search mtk flash tool or spiderman box crack in forum and just do auto format bec ur cpu is 6225 and mostly auto format is good 4 6225 cpu.
yes after format if set power on ur set goes in orignall condition and if ur set not power on then need to flash ur set with new files.
Old 06-27-2009, 13:11   #4 (permalink)
Member: 1060066
hey I have trie to attach the pins but MTK tools no nothing also I tried with spiderman, nothing happened too. I tried with battery and also without battery same result
What should I do now?
Old 09-15-2009, 22:42   #5 (permalink)
Member: 1060066
=============== Memory Detection Report ===============
Internal RAM:
Size = 0x0000C000 (48KB)
External RAM:
Type = SRAM
Size = 0x00400000 (4MB/32Mb)
NOR Flash:
Device ID = "[SPANSION] S71PL127N" (87)
Size = 0x01000000 (16MB/128Mb)
NAND Flash:
ERROR: NAND Flash was not detected!
============ RAM Test ============
Data Bus Test :
[D0][D1][D2][D3][D4][D5][D6][D7][D8][D9][D10][D11][D12][D13][D14][D15]
OK!!
Address Bus Test :
[A1][A2][A3][A4][A5][A6][A7][A8][A9][A10][A11][A12][A13][A14][A15][A16][A17][A18][A19][A20][A21]
OK!!
RAM Pattern Test :
Writing ...
0x44332211,
0xA5A5A5A5,
0xA5A5A500,
0xA500A500,
0xA5000000,
0x00000000,
0xFFFF0000,
0xFFFFFFFF,
OK!!
Increment/Decrement Test :
Writing ...
OK!!
============ NAND Test ============
SKIP! NAND Flash was not detected!
This is the memory test results from Flash_tool (MTK Tool I guess)
Old 07-10-2010, 18:45   #6 (permalink)
Member: 371302
Thanks Meter: 2
any one can help me on this model flash file?
Need some help from user/Moderators/S.Moderator mujahid_ali Off Topic Zone 3 10-16-2009 12:10
I need a help from experts med_abid_2006 Sim Cloning and Scaning 0 05-14-2009 09:23
need some advice from experts farry RE-7500 Reworking System & iSolder 0 11-30-2008 12:46
Need little Help From Experts.... /FAISAL/ SETool2 5 11-11-2008 17:29
need some help from the expert...!! bawangdagreat Nokia Base Band 5 ( BB-5 ) 0 04-06-2007 15:25
Page generated in 0.17357 seconds with 9 queries
