Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
10-21-2009, 21:29 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1145623 Status: Offline Thanks Meter: 2 | Iphone 3G 1:1L White Screen problem I am new here I would like to know if somebody can help me..... My Iphone 3G 1:1L have a white screen problem and it work because I can receive the incoming call's, but I can't dial a number because nothing appear on the screen. This happend by itself, I didn't nothing to the phone just few minutes before was ok and few minutes later was all white. I tryied to to turn off and on the phone but didn't work, I tryed to reset it pressing the button inside the hole just up from the volume controls on the left side of the phone and didn't worked to. Someone can tell me if is an hardware or software problem? I mean, I suppose is an hardware problem related to the screen, am I right or not? Any suggestion on how I could fix by myself? Thanks to everyone, I hope to get help soon.... bye digimark |
The Following User Says Thank You to digimark For This Useful Post: |
10-23-2009, 00:44 | #2 (permalink) |
Member: 1145623 Status: Offline Thanks Meter: 2 | Thanks to everyone, I decided to opn my phone and I checked all the connectors and I found the problem was the screen connnector hat wasn't pugged in firmily. So I repaired it! Bye Digimark |
10-24-2009, 17:47 | #4 (permalink) |
Member: 1145623 Status: Offline Thanks Meter: 2 | hi did you tryied to change the phone software? because if you load a wrong versionof your phone software, you can get this type of problem, if it just heppened like in my case that just few minutes before was ok and few minutes later the screen becomed white,is probably an hardware problem, like in my case that was the screen connector not properly plugged in. So if you dind't made a mess trying to change the phone software I would suggest you to open the phone and check the screen connector. What is important to understand is your phone working? I mean if you disable pin request on your sim and u try to power on the phone can it receive the incoming call's? If yes, probably is just a screen related problem, like in my case my only problem was that I couldn't see nothing on the on the screen, but when i had an incoming call I answered just remembering where usually the answer button was on the screen and touching it as normal. Don't be scared to open and riassemble the phone is much more easy than what you could thing! At the start I was scared to, but at the end I was suprised that was that much easy! I hope this can help you. If you need more info just ask to me! Bye Digimark |
11-15-2009, 03:23 | #5 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1161581 Status: Offline Thanks Meter: 0 | hi i have same issue on iphone hi. my phone has white screen but i can receive phone call. i opened it but i cannot solve the problem. could you tell me which connector was unplugged on your i phone. there was some numbers on the connector. thank you. |
12-31-2009, 21:01 | #6 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1197443 Status: Offline Thanks Meter: 0 | Solution if your iphone is jailbroke or randomly happened while purchasing something off itunes hold the home and lock button for ten seconds then turn the iphone back on this should solve it as well. if it does not work try to restore it using itunes on the computer this should solve it |
Compatible FM Transmitter & Remote Control for iPhone/iPhone 3G/iPods - White | IPMART | ipmart WebShop | 0 | 04-28-2009 16:20 |
IPhone Hang & White Screen | rafiqnth | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 03-27-2009 06:04 |
Wanted: iPhone 3G 16GB white | SEMC | Wanted Products | 1 | 02-12-2009 04:10 |
E630 White Screen problem!!!(Not Flex Cable) | PhoneDeal | Samsung Hardware Repair | 5 | 09-20-2005 18:40 |
LG7050 white screen problem | foneb0i | LG | 3 | 11-08-2004 10:16 |
