..::n95 china first copy(sliding one) sensor problem::.. china n95 first copy (sliding) touch screen(sensor damaged) so in the market no same sensor available ................alternate sensor available of same size but difference in strip mean old one have 4 prints and this one also have 4 prints but it is slightly broad so i sold this sensor strip with wire but its not work,plz help me how to fix this problem? urgent help needed? ..::HUM::.. |
plz some body guide me,i think print difference. plz help. ..::HUM::.. |
Snow ur touch screen 4 pins ways, i can help u how 2 fix it! Br., Robandi. |
now i put original sensor but it also not work plz any soliution? ..::HUM::.. |
plz help no one here to give solution for china n95 slider ,whose touch screen not working,i try with 3 touch screens. plz help? ..::HUM::.. |
n 95 slider chinese 1 Attachment(s) hi azim bro.check four prints from board that thay r showing u continuity or not.if yes then check four tracks by changing its position.check pic. |
thnx i will try and post result. ..::HUM::.. |
bro jai ur solution not work,plz give me another solution? ..::HUM::.. |
bcoz all chines touch pad have not same contect. pls. post result here. wbr |
now the last touch screen i take from same set than y it not work? ..::HUM::.. |
n 95 chinese did u checked tracks r ok? or use them directly from board.not from display strip. |
plz help me through pic.......................? ..::HUM::.. |
goodoooooooooooooooopooooooooooo |
wat is this? ..::HUM::.. |
flash with infinity. solder rx tx and gnd and flash it it will not go to touch mode |
