Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
![]() | #1396 (permalink) | |
Moderator ![]() Join Date: Nov 2009 Location: South Africa > Bangladesh Age: 40
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,052 | Quote:
Keep it Up Best Regard
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
![]() | #1397 (permalink) |
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,052 | MT6582__archos__Archos_45c_Platinum__ac45cpl__4.4. 2__SLFQPLUS13B-S10A_ARCHOS_L43EN_20
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 04-23-2020 at 12:47. |
![]() | #1398 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2012 Location: Satkhira khulna Bangladesh
Member: 1716947 Status: Offline Sonork: 100.1661965 Thanks Meter: 193 | ![]() Dear NP brother I have Walton primo G3 handset problem is google play update missing.When I try to flash with sp tool flash complite done but when phone on phone not erese and phone show same .same wallpaper and same pattern lock show.Now what can i do brother please tell brother........your formula is best..........please tell...I try to erese with miracle and sptool but same........ solution please....... |
![]() | #1399 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2014 Location: B A N G L A D E S H
Member: 2171294 Status: Offline Sonork: 100.1659207(No More Use) Thanks Meter: 701 ![]() | ![]() Quote:
Your Flash Ic Curupted , change Flasher if possible.... | |
The Following 2 Users Say Thank You to tapas770 For This Useful Post: |
![]() | #1400 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2011 Location: Chin
Member: 1531030 Status: Offline Sonork: Yahoo_Akm Thanks Meter: 118 | Ace i6_White display problem Quote:
![]() | #1404 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2015 Location: Algeria
Member: 2462504 Status: Offline Sonork: 1001681026 Thanks Meter: 19 ![]() | please need sony Z6 mt6572 firmware Chinese Miracle II [MTK module] v 1.47 Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 70010053313030303408987772DC8227 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 40001 [eMMC] : FLASH_CID : 70010053313030303408987772DC8227 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E4000000 [eMMC] : FLASH_UCP : 3648 MiB [eMMC 4 GiB] DEV RID : 214E84FEAE43AB147B1CCAE0F3F3EF46 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Z6 ProdName : a831_ax_324_cht_z6 ProdModel : Z6 Device : a831_ax_324_cht_z6 AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : a831_ax_324_cht_z6_v1.4 Done! Elapsed: 00:00:13 Reconnect Power/Cable |
![]() | #1405 (permalink) |
Member: 2462504 Status: Offline Sonork: 1001681026 Thanks Meter: 19 ![]() | please need this firmware Set PreLoader USB VCOM Port (COM16) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_006E Nand Flash Code: 002C00BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0x20000/0x10000000 Reading Size: 0x21C00000 Reading infr(Nand)... PRELOADER BaseAddr:0x0 Size:0x100000 PRO_INFO BaseAddr:0x100000 Size:0x100000 NVRAM BaseAddr:0x200000 Size:0x300000 PROTECT_F BaseAddr:0x500000 Size:0x300000 PROTECT_S BaseAddr:0x800000 Size:0x300000 SECCFG BaseAddr:0xB00000 Size:0x40000 UBOOT BaseAddr:0xB40000 Size:0x80000 BOOTIMG BaseAddr:0xBC0000 Size:0x600000 RECOVERY BaseAddr:0x11C0000 Size:0x600000 SEC_RO BaseAddr:0x17C0000 Size:0x40000 MISC BaseAddr:0x1800000 Size:0xC0000 LOGO BaseAddr:0x18C0000 Size:0x100000 EXPDB BaseAddr:0x19C0000 Size:0x200000 FAT BaseAddr:0x1BC0000 Size:0x1400000 ANDROID BaseAddr:0x2FC0000 Size:0xFA00000 CACHE BaseAddr:0x129C0000 Size:0x700000 USRDATA BaseAddr:0x130C0000 Size:0xBAC0000 BMTPOOL BaseAddr:0xFFFF0050 Size:0x0 >>Done |
![]() | #1408 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Bangladesh
Member: 387110 Status: Offline Sonork: Not Use Thanks Meter: 628 | Sony Z3mini Tested Firmware For gsmhosting member Sony X-Bo Z3mini Firmware Without Password Firmware Name: MT6571__SanCup__H3000__M7A__4.4.2__ALPS.KK1.MP7.V1 |
The Following 8 Users Say Thank You to Dilip_Nath For This Useful Post: |
![]() | #1409 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: World Wide Age: 53
Member: 120932 Status: Offline Thanks Meter: 58 ![]() | Hardware : MT6572 Model : Z5 Build number : m11v20_dhd_a01_c_018_qhd_es_v05 Build date UTC : 20160120-062703 Android v : 4.4.2 Baseband v: MOLY.WR8.W1315.MD.WG.MP.V43, 2015/10/31 14:06 Kernel v : 3.4.67 ([email protected]) (gcc version 4.7 (GCC) ) #1 SMP Wed Jan 20 14:23:39 CST 2016 Helpme firmware stock please. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
