Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
01-30-2009, 07:05 | #1 (permalink) |
Freak Poster Join Date: Nov 2006 Location: enreekang, sulwesi selatan, in
Member: 401094 Status: Offline Thanks Meter: 86 | Need fileflash CROSS G10 Hardware version:8A03 CPU Type: 6225 CPUID :03320100 Flash Type: [TOSHIBA] TV00578002DABD Flash Size: 0x01000000 |
The Following User Says Thank You to ansarsossok For This Useful Post: |
01-30-2009, 21:44 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I suggest you to post here required software version or phone photo, in other case it will be quite hard to give you an advice and firmware. |
01-31-2009, 16:00 | #3 (permalink) | |
Member: 401094 Status: Offline Thanks Meter: 86 | upload photo Quote:
previously I can't read software version before reball CPU and Flash IC, read detail information log: Code: Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:3203:0001 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: 98004900000002:18A59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98004900000002:18A59F00000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .................... detect standard fat location pass #1... ........................................................ detect extended fat location pass #1... ........................................................ fat location can't be detected error: ffs/eeprom detection failed: element #1 detecting ffs/eeprom structure pass 2... ........................................................ can't detect fat record name location error: ffs/eeprom detection failed element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 115 sec Remove/Install battery now ! reball CPU and flash IC then format FFS with infinity this SW version: Code: CBM6225_06B_PCB01_GPRS_MT6225_S00.CBM21_K5CROSS_V5 CROSS G10: B.R., ansarsossok | |
cross g10 flashing problem | ru_dee | Infinity-Box | 12 | 12-23-2012 20:13 |
need pinout cross G27 | didi.didi | Chinese Models & Cloned Phones | 0 | 12-26-2009 19:18 |
needed fileflash ASIAFONE AF501 infenion 7880 | twentyonecell | CPF-BOX Ⅱ | 14 | 06-14-2009 11:03 |
I need fileflash Gnet G414 | chuithailand | Chinese Models & Cloned Phones | 0 | 03-25-2009 16:54 |
Need FileFlash For I Mobile 315 | Han_Ok1712 | Infinity-Box | 1 | 10-23-2007 09:16 |
