Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-31-2008, 19:54 | #1 (permalink) |
Insane Poster Join Date: Apr 2006
Member: 260521 Status: Offline Thanks Meter: 7 | engeneering menu explanations i found this text about engineering menu *#3646633# and factory mode *#66*#, it is translated from chinese, could be usefull for some: [quote] I have here in this area Dongdong, but do not look at it out the whole engineering model # 3646633 * # * # 3656565 # 1, the network numbers, no, do not know how to see, the best Luandong or not, the move should also be no use Second, equipment 1, LCD-screen: ① set contrast (contrast settings) established show Set param (setting parameters) in adjustable ② set biasratio (set deviation ratio) ③ set line rate (setting line rates) ④ set temperature (temperature settings) ⑤ set COLOR (color settings) ⑥ Diplay demo pic (broadcast images) 2, GPIO 3, PWM (PWM) 4, EINT (unknown) 5, ADC (analog-to-digital converter) 6, set default level (the standard default settings) ① mainLCD contrast (contrast the main screen) ② Batterry (cell) ③ PWM1 ④ PWM2 ⑤ PWM3 7,1) Set UART (Universal Asynchronous Transfer set) ① TST config ② PS config ③ USB serial port settings to use the default, 1, 2 information, debug 2) UART POWER ON / OFF 8, Sleep mode ① Enable ② Disable 9, NAND Format (with non-circuit format), the disk is formatted, do not move, or information to Diuguang 10, DCM mode ① Enable ② Disable 11, SWDBG ① OFF ② DSP LI ③ DSP PS ④ LI PS ⑤ MCU ⑥ MCU DSP ⑦ RESET ( 12, PMIC 6318 ① Register R / W ② Charger Status Set Charger RGB KP LED BL LED Audio Misc Lcm bl setting 13, RTC XOSC (WO) Third, audio A set pattern ⊙ normal (phone set is normal) ⊙ Loudsp mode (loud mode) ⊙ Headset mode (headset mode) 2, normal ① finite impulse response (1-5 five optional) ② Speech (to speak) volume control settings, there were seven guards, can be set value ③ ken Tone (main pitch) can also be a volume control) ④ Melody (melody) regulate the volume MP3 Waifang ⑤ Sound (the ring should be regulating, not very sure) ⑥ Microphone (microphone) should adjust the microphone volume ⑦ Side Tone (background noise) 3, Loudsp mode (same as the adjusted 2) 4, Headset mode (same as the adjusted 2) 5, Melody (available on ringtones) 6, SET ECHO Suppression (set echo suppression) ① Energy Thresh (energy repeatedly) to determine show 16,384 ② Delay (delay) show 0 ③ Energy Thresh2 show 0 ④ Delay 2 (delay) show 0 7, Max Swing (maximum amplitude) 8, DEBUG INFO 9, AUTO RECORD SETTING (automatic recording settings) 4, GPRS ACT 1, Attach determine Show: Complete, (GPRS connection will be on the point) 2, Activate PDP (1-15 items, optional) (Activate the Chinese meaning is to make activities, PDP significance unknown) 3, Deactivate PDP (Deactivate the Chinese meaning is. Invalid,) 4, Send Data (data) ① send norm data (data transmission standard) ② send RLC (meaning unknown) data 5, PING (should be "inter-group net search") ① send norm data (data transmission standard) ② send RLC (meaning unknown) data 5, bandwidth selection, it's no好说 6, MISC (Miscellaneous) 1, Auto Answer (automatic response) default to the Commissioner, can be opened, I have not tried 2, High speed SIM (Subscriber Identity card high-speed), opening and closing, set by default to close 3PWR Duration (energy duration), established after the show are as follows: 10/02 12:53:48 boot may be the last time Current time] [current time 10/02 19:33:36 [] Duration Duration 00/00 06:39:48 [Last duration] 00/00 00:00:00 4, Backlight Mode (backlight mode) Can switch, is off by default, open, the phone display backlight is not extinguished 5, serial port to detect patterns, determine ① UART1 ② UART2 ③ ART3 6, Assert testing (meaning unknown) show OK - the resumption of mobile phone 7, RAM test (random access memory test) to determine - to return to MISC interface 8, memorey dump (unknown) 9, MMI Debug host interface debug (default off, can be opened, the role of unknown) 10, WAP (may be opening and closing) ① WAP Assert Debug (debug confirmation process) ② useer Agent MAUI E800 ③ Accept Header (document acceptable) WAP 1.2 WAP 2.0 WML HHTML HTML (Hypertext Markup Language) ④ MMS Version (MMS version) MMS Default (default) MMS1.0 MMS1.1 ⑤ Offine page (offline page) to open the phone after the Internet can be saved page 11, J2ME TCK OK - into the engineering model JAVA Normal (standard) CLDC TCK (significance are unknown) MIDP TCK WMAPI TCK MMAPI TCK 12, AMR 13, TOUCH SCREEN 14, VIDEO HIGH BITRATE 7, Auto test list (list of automatic test) should be # * # 66 of the show 8, PWA Down Control (control of energy reduction) 1, PDN_con0 1278 2, PDN_con1 65175 3, PDN_con2 63470 4, PDN_con3 65535 Guess four electricity grid may be set numerical 9, Debug info (debugging process information) ① FS TRACE (unknown) ② Last Exception (unknown) 10, Socket test (testing interface) 1, DNS Query After determining the emergence of a Domain Name input box 2, HTTP Get 3, ECHO 4, Date query (Enquiry) 5, TRACERT 6, IPERF 11, SW PATCH SELECT --- DSP PATCH - Data 12, Profiling --- Multimedia (Multimedia) 1, Auto Play Files (automatic player) 2, Camera (cameras) 3, Video Player (MP4 players) 4, Video Recorder (video player) 13, RF TEST TOOL Multimedia (Multimedia) 1, Auto Play Files (automatic player) 2, Camera (cameras) 3, Video Player (MP4 players) 4, Video Recorder (video player) Test phone use Instructions: * # * # 66 Description: ┳ ━ ━ Version version information ┃ ┣ ━ ━ MCU SW micro-controller software program ┃ ┣ ━ ━ Melody tunes version ┃ ┣ ━ ━ Serial No. Serial number ┃ ┣ ━ ━ BB Chip chip substrate (MT6218B, which also use it to the phone ») ┃ ┣ ━ ━ DSP Code digital signal processor code ┃ ┣ ━ ━ DSP Patch amended version of digital signal processors, ┃ ┣ ━ ━ MS Board MS board (is not very clear, I do not know what the acronym. Memory System??) ┃ ┗ ━ ━ Build No. Version ┃ ┣ ━ ━ Resource BIN resources BIN (do not know how up, binary code? ») ┃ ┣ ━ ━ Audio Audio ┃ ┣ ━ ━ Image Image ┃ ┣ ━ ━ STR string (guess) ┃ ┗ ━ ━ Font fonts ┃ ┣ ━ ━ Echo Loop Cycle Show (do not know over the Zhunbu Zhun) can switch, but do not know You Shayong ┃ ┣ ━ ━ button (the original is the Chinese) can be tested by determining access to the keys on the keyboard so that it ┃ press the corresponding button on the screen characters will disappear, so that this button ┃ UP: key on the DN: Under the direction of bond LF: Left RT: key to the right direction ┃ LSK: Left softkey (is not that soft) RSK: a softkey (not Ruzuo softkey) ┃ Snd: access key End: hang up keys Vup: large volume Vdn: small volume ┃ 1 2 3 4 5 6 7 8 9 0 * #: the number keys and * # ┃ after the completion of testing will Pass ┃ ┣ ━ ━ Vibrator vibration tests elections "on" test vibration function is available ┃ ┣ ━ ━ Loud Spk speakers (I always want to say "speaker") test "in a" test whether the speaker can be audible ┃ ┣ ━ ━ ring (the original is in Chinese) ring test "in a" test tone function is normal ┃ ┣ ━ ━ LED LED indicator light (lantern) Testing ┃ ┣ ━ ━ Main LCM BL main display backlight (switch, Commissioner of the election will be extinguished, then click can be left open) ┃ ┣ ━ ━ Sub LCM BL sub-display backlight (which can be switched, but I have no reaction, no bad it ») ┃ ┣ ━ ━ Keypad LED lights keyboard (switch) ┃ ┣ ━ ━ Status LED R state of red lights ┃ ┣ ━ ━ Status LED G state green light ┃ ┗ ━ ━ Status LED B status light blue (my three colors of the dislocation) ┃ ┣ ━ ━ LCD screen test ┃ ┣ ━ ━ Auto display with automatic test automatically filled with red, green blue and white four-color screen, can detect whether there are Huaidian ┃ ┣ ━ ━ Red filled the screen in red ┃ ┣ ━ ━ Green filled with green screen ┃ ┣ ━ ━ Blue filled with blue screen ┃ ┗ ━ ━ White filling the screen with white ┃ ┣ ━ ━ LCD Contract contrast screen test ┃ ┣ ━ ━ Main LCD main display contrast, shows a picture ┃ ┃ the key 15 adjustable contrast from top to bottom, but I have no changes in how - ┃ ┗ ━ ━ Sub LCD-(outside) display contrast, the contrast can be transferred 15 ┃ adjustment changes, but no pictures, only text ┃ ┣ ━ ━ Receiver receiver ( »») originally wanted to test translated into the microphone, but the microphone was what reaction ┃ I do not know what this means Receiver ┃ election started on a Zhizhi's voice, ear-piercing death ┃ ┣ ━ ━ ADC I do not know what the acronym ┃ ┣ ━ ━ VBAT battery voltage ┃ ┣ ━ ━ BTemp battery temperature (many people say can not be charging the battery temperature is low, the logic in this) ┃ ┣ ━ ━ VAUX auxiliary voltage (I do not know what is), usually 0.02 V ┃ ┣ ━ ━ Current charge current, using data lines for charging 0.33 A, not a small Afghanistan ┃ ┗ ━ ━ VChgr charge voltage, plug in the charger / data will be there ┃ ┣ ━ ━ Charger chargers, above and beyond into the ADC is the same menu ┃ ┣ ━ ━ Headset headset test (headphones lost, can not test), you can switch, plug in headphones may be what it sounds ┃ ┣ ━ ━ RTC personal speculation is the acronym for Real Time Clock, in fact shut down the alarm was to test the ┃ click "OK" will immediately shut down and turned off the alarm test whether the state can activate an alarm shutdown ┃ ┣ ━ ━ MTBF still do not know what the acronym ┃ click "OK" after the vibration, speakers, LCD, LED integrated test ┃ ┣ ━ ━ Nand Flash memory chip testing, if the normal show "success" ┃ ┗ ━ ━ CAMERA camera test, according to the "OK" to enter, select "Options" There are three options ┣ ━ ━ Flash Level R translated in accordance with the meaning, it should be stressed is the flash of color ┣ ━ ━ Flash Level G But no matter how stressed are no changes ┗ ━ ━ Flash Level B therefore do not know if this is some of what the mtk phone several projects under the mode of application "MP3, MP4 players either use headphones or speakers on board, volume related to the minimum still think that the" solution is as follows: 1) Open digital keyboard, enter * # 3646633 # into the work mode menu; 2) Select ③ "audio" into the audio type menu; 3) Choose ② "normal" into the normal mode menu; 4) Choose ④ "Melody"; volume 0-6 here on behalf of the entire seven-volume series, the volume 0 on behalf of the smallest volume series, the actual volume value is 64, no wonder the Commissioner of less than quiet, the chief culprit in This! ! The numerical grade level are as follows: volume 0 - 64 Volume 1 - 80 volume 2 - 96 volume 3 - 128 Volume 4 - 160 Volume 5 - 192 Volume 6 - 224. 5) Select ① "level 0", set into the adjustment. Under the direction of adjustment until the 0 key and then determine, step by step to return to the prompt "was revised parameters» "when the choice is" Yes ", before returning to withdraw from the project mode, adjust the end. But this way, the volume from the series 0-1 in too much, therefore, will be based on personal preference for numerical grade level in all appropriate adjustments to adapt to the human ear hearing sensitivity. In one word, not to jump to the volume from a series of clinical progression when people feel very sudden, great changes, but should feel a change but is not, able to adapt to. Therefore, the volume will be 1-6 6-class values re-adjustment, of course, if necessary, will not only. And the voices screaming on the Echo solution 1: Enter * # 3646633 # 2: access to audio 3: Go to normal 4: Go Microphone 5: The set of parameters for 120 6: retention of the parameters |
The Following 7 Users Say Thank You to r0c0 For This Useful Post: |
01-17-2010, 04:32 | #5 (permalink) |
Major Poster Join Date: Jan 2006 Location: Brazil/São Paulo Age: 42
Member: 220492 Status: Offline Thanks Meter: 2 | I did *#6810# and the message Done have poped up on my display, Now I can not enter the Engineering menu *#3646633# again on My F003 Mobile, does anyone know how to activate it again? I also have restarted the phone to original configuration but it doesn't work anymore, I Need help. Thanks 4 All |
Engeneer mode for PT410 | cactus31odo | Chinese Models & Cloned Phones | 0 | 11-26-2008 18:57 |
LOOKING FOR 2 maintenance ENGENER FOR GSM MOBILES | ezz2003 | Old Ericsson Phones & Sony Phones | 3 | 12-03-2001 04:13 |
LOOKING FOR 2 maintenance ENGENER FOR GSM MOBILES | ezz2003 | Old Ericsson Phones & Sony Phones | 0 | 11-29-2001 11:22 |
LOOKING FOR 2 maintenance ENGENER FOR GSM MOBILES | ezz2003 | Main Sales Section | 0 | 11-29-2001 11:21 |
New sagem Engeneering menu | InKola | Infineon C16X M51 & ARM7 M52 BASED | 0 | 05-13-2000 18:05 |
