Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
12-30-2009, 17:26 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1196490 Status: Offline Thanks Meter: 7 | not allowed dial prob with china clone iphone 3gs ps. sms works but phonecalls not |
The Following 2 Users Say Thank You to makisalo For This Useful Post: |
01-02-2010, 00:05 | #4 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1197672 Status: Offline Thanks Meter: 1 | imei is 355103010026857 and 355103010026865 All other function is OK - receive ansuer no problem; surf to internet no problem... .. SIM card or GSM provider all its OK , but no dail function...?????? What its wrong?? CPU MT 6235 (i68..) Please haw to repar id ???! PLS! |
01-02-2010, 11:48 | #6 (permalink) |
Freak Poster Join Date: May 2008 Location: VietNam Age: 36
Member: 768903 Status: Offline Thanks Meter: 43 | Please check in Call Setting and go to '' SEND MY CALLER ID'' change to .: ''Set by network '' ..... if can't solved problem... please format phone |
The Following User Says Thank You to let go For This Useful Post: |
01-02-2010, 17:16 | #7 (permalink) |
Member: 1197672 Status: Offline Thanks Meter: 1 | So i fimd to forum this: http://forum.gsmhosting.com/vbb/showthread.php?t=860314 but the code to engeneering menu is diferent Anybody know a valid code for the following phone Lixin N1 [version]: P285-ALL_FOREIGN_Ver 1.2 [branch]: 08B SICOM35_08B [bild time]: 2009/10/23 18:11 serial P2850910151055410 |
01-05-2010, 07:49 | #10 (permalink) |
Member: 1197672 Status: Offline Thanks Meter: 1 | Is there a method for enabled engeneering menu if it be desable to manufacturer? I try to codes *#3646633# and *#9646633# or many other , but it does not work..... So if solution is test to RF , can be done in another way? For example through forced interruption of the process "search network"....? |
01-06-2010, 12:25 | #11 (permalink) |
Member: 1196490 Status: Offline Thanks Meter: 7 | Another way how ? is it possible without service codes ? who really knows ? I try many different codes but dont works . This is big problems because i dont understand why sms works and answer for phonecalls but i cant take a phonecalls my own . Is that sim card prob or software prob or something else ? We a not alone with " not allowed to dial" prob . |
01-06-2010, 13:35 | #12 (permalink) |
Member: 1196490 Status: Offline Thanks Meter: 7 | i foud this but code dont works for me http://support.***********.com/index...barticleid=241 |
01-08-2010, 20:47 | #13 (permalink) |
Member: 1196490 Status: Offline Thanks Meter: 7 | My first phone call back is done. My friend send to me mms message and his number found via mms. inside mms is option to call back for people who was sending mms message. It works.. this is my first time..... mms inbox-mms message-options-use details-then mms phone number- an there is "call" option... it works !!! If all my friends send to me mms I can call back.. so crazyyyy!!! Anyway normal phonecalls back... NO ! |
The Following User Says Thank You to makisalo For This Useful Post: |
01-11-2010, 13:28 | #15 (permalink) |
Member: 1203605 Status: Offline Thanks Meter: 5 | Makis you can try *#337# and then the phone wll reboot. If not fixed then try: 01. Make sure two SIMs are online with good coverage, WLAN switched off. 02. Press the “call”-button and type in *#3646633# 03. The phone shows “Engineer mode” with a menu of 10 different items. 04. Go to No. 10 “RF test tool”, using the up/down button at the left side of the mobile. 05. Choose “GSM” 06. A message shows up “Wifi….blabla”, just confirm with OK 07. Choose “Power Scan” 08. Select your local GSM frequency (an eisai Cosmote bale GSM900) and press OK. 09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!! 10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!! 11. Press the Menu button (second from the left, the one with the seven small dots on it) until you you the main menu with the 12 icons on the display. 12. Go to “Settings” –> “Network Setup” –> “SIM1 network setup” 13. Go to “Preferred mode” and choose “GSM preferred” 14. The mobile will switch to your selection, but the message that it will stay on display. Do not press anything else, just wait for about 10 – 15 seconds. 15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection. 16. Get back to main menu, switch off and restart the mobile –> DONE. |
The Following 3 Users Say Thank You to papakion For This Useful Post: |
iPhone 3gs sold in China have no WIFI (Can not unlock with blacksnow) | yonylove | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 02-03-2010 15:18 |
Compatible Touch Pad with Ribbon for iPhone 3GS | IPMART | ipmart WebShop | 0 | 01-14-2010 11:40 |
Original Volume Ribbon with IC for iPhone 3GS Phone(White) | IPMART | ipmart WebShop | 0 | 12-23-2009 14:40 |
china clone iphone 3gs | tonggo | Chinese Models & Cloned Phones | 0 | 09-10-2009 15:05 |
