Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 11-16-2011, 18:01   #1 (permalink)
Member: 704189
Thanks Meter: 13
Question bassoon f200 flash file problem "menu" not show
i need bassoon f200 flash file problem "menu" not show?
The Following User Says Thank You to sanjay telecom For This Useful Post:
Old 11-17-2011, 07:04   #2 (permalink)
jamaletw's Avatar
Member: 599228
Thanks Meter: 112
format gpg...............now
Old 11-17-2011, 07:39   #3 (permalink)
Member: 704189
Thanks Meter: 13
i format gpg dragan but show error
Old 11-17-2011, 07:41   #4 (permalink)
Member: 704189
Thanks Meter: 13
format ,reset ,unlock all show flash error???
Old 11-17-2011, 07:43   #5 (permalink)
Member: 704189
Thanks Meter: 13
error
Initializing...
DA_LIB_VER_3.6.0.0
It is sensing the pinout fast...
D-=2 D+=3
Searching commport...please wait...
Connecting...
Spd USB-to-Serial=COM4
Connected...sending boot...
FDL test...OK
ArmBootMode: 6610000000B65A00_01
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 921600 ok
Reading phone HW info...
Unknow Manufacturer ID, Flash does not exist or failed to initialize H/W.
CPU: 66100000 Flash: NOR_UNKNOWN
setting the Flash Parameters...
Settings have been completed!
CPU: 66100000 Flash: User-defined
Reading FileSystem info...
FileSystem Version: 0A
Start=0x00000000, Size=0x00000100, Running NV=0x00007D00
Error: Unsaft EFS Address, Please input the right format address and try again.
Failed to auto format.
Old 11-17-2011, 08:20   #6 (permalink)
Member: 1666176
Thanks Meter: 58
hi send me ur team viewer id and pass i solve ur problem..............
Old 11-17-2011, 08:22   #7 (permalink)
badal don's Avatar
Member: 1564275
Sonork: badal ranchi
Thanks Meter: 120
http://forum.gsmhosting.com/vbb/f562...ormat-1381060/
Old 11-22-2011, 14:37   #8 (permalink)
Member: 1134047
Sonork: 123456
Thanks Meter: 14
i format gpg dragan 2.10 bassoon f30 write flesh 0% error set dead pleeez help
Old 11-23-2011, 06:24   #9 (permalink)
Moderator
tkowsar's Avatar
Member: 233205
Thanks Meter: 5,014
Originally Posted by sanjay telecom View Post
Initializing...
may your device haven't support for this type of flash chip, try other.
try other device or wait till device company give support for this type of flash chip.
Old 12-03-2011, 11:43   #10 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 1,061
Bassoon f200 flesh file
DOWNLOAD HERE
Old 12-03-2011, 12:51   #11 (permalink)
logicmobile's Avatar
Member: 1016569
Thanks Meter: 229
solution
Initializing...
DA_LIB_VER_3.6.0.0
D-=2 D+=3
Connecting...
FDL test...OK
Done.
Done.
wait for new update of GPg dragon
if u will try to flash with dragon it goes in dead position.
Old 12-23-2011, 10:20   #12 (permalink)
{X-MAN}'s Avatar
Member: 1169043
Sonork: 100.1586033
Thanks Meter: 58
Initializing...
DA_LIB_VER_3.6.7.1
D-=23 D+=22
Connecting...
Spd USB-to-Serial=COM15
FDL test...OK
ArmBootMode: 6610000000805A00_01
Done.
Done.
Set baudrate to 921600 is ok
Read info is done.
CPU: SC6610/20 Flash: SF_FM25Q32
setting the Serial Flash Parameters...
Unlocking all blocks before program/erase...
Unlock Done.
Programming...
Compare Image: Enable
Error: Failed to send request to phone.
Old 01-04-2012, 19:28   #13 (permalink)
[SV]'s Avatar
Member: 1690589
Sonork: 100.1609373
Thanks Meter: 39,696
Blossom F200 Repair 100%
See Here What is Miracle
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.24165 seconds with 9 queries
