Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
09-30-2008, 22:31 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 579970 Status: Offline Thanks Meter: 0 | plz help china phone Cect T689 dual Sim i don't have a box , thus as told here , usb cable as max232 makes flash with MTK TOOLS, i need help , i have usb to com , prolific cable , am using , db9 pins : 2,3,5 as Tx Rx and Ground. but it never works , what's the problem ??? even MTK Format doesn't work plz reply |
10-01-2008, 16:58 | #3 (permalink) |
Freak Poster Join Date: Feb 2008
Member: 698055 Status: Offline Thanks Meter: 60 | Bruce bro dont worry use profilice cable to formate.note setp 1 insert u r usb cable before that install profilce driver 2. Goto device manager and check at what port u r usb cable is selected and ex 3,4,5 3. Then check the ground wire in usb cable may be green with use of multie meter then check voltage for remanig wires u will get 1.27-2.28 volte for the two remaining tx & rx exp white rx ,blue tx. Open mtk and select the port u noted then load scat file da file .remove basband chip in option select format manully and power on u r ok |
The Following User Says Thank You to bathri525 For This Useful Post: |
plz help china phone restart on sim | brain00000 | Infinity-Box | 1 | 06-11-2009 20:40 |
which is problem cect t689 dual sim | genci titi 2002 | Infinity-Box | 4 | 07-02-2008 08:05 |
CECT T689 Dual sim question. | Raklm | Chinese Cocktail | 11 | 03-16-2008 19:58 |
Cect T689 Dual Sim ...auto Off | gidanz | Infinity-Box | 18 | 09-11-2007 19:59 |
CECT T689 dual sim PDA Phone | crvkva10 | HTC & PDA WM( With Touchscreen) | 1 | 07-12-2007 08:31 |
