spd error- Failed to auto format. flash read ok unlock ok flash write ok format error- below Initializing... DA_LIB_VER_3.6.0.2 It is sensing the pinout fast... D-=8 D+=6 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM15 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00780000, Size=0x00070000, Running NV=0xD41C7900 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. how to solve this solve plz help me |
it is a hardware problem |
that the problem spredtrum chips , sometimes the result of format is dead unit....than to use format , use the reset |
Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast... RXD=4 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL128N_T setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00000000, Size=0x00004100, Running NV=0x0000EE00 Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. plz help me my maile [email protected] |
@gsmcannt & rajpurohit , try to set lower baudrate then check , also u can reset unti insted of format. if still not solve ur problem then need to full flash d unit. |
