very instracting problem my friend i recive a china phone its model t6688 when i on the phone the phone is hang after that i try to format the phone with mc tool when i check the phone pinout type mkt its shows this massege [ 19:15:48 ] [--- Operation Started ---] [ 19:15:48 ] Detecting power pins... [ 19:15:51 ] Detected GND : 4,12 [ 19:15:51 ] Detected VCC : 1,2 [ 19:15:52 ] Failed to start search : INIT_ERROR [ 19:15:52 ] Searching for pinout... [ 19:15:52 ] Pinout does not detected! [ 19:15:52 ] Change Speed and try again! [ 19:15:52 ] [--- Operation Finished! -- then i check the phone pinout infieon its shows [ 19:16:01 ] [--- Operation Started ---] [ 19:16:01 ] Detecting power pins... [ 19:16:05 ] Detected GND : 4,12 [ 19:16:05 ] Detected VCC : 1,2 [ 19:16:05 ] Searching for pinout... [ 19:16:05 ] Pinout detected OK! [ 19:16:05 ] RX : 5 TX : 3 [ 19:16:06 ] Writing settings to Box... [ 19:16:08 ] Failed to write settings : ERROR [ 19:16:08 ] [--- Operation Successful! --- and the some time in mc tool the short light(red light) its blinking continue i am confused waht can i do |
any body know i am wating for ans |
when handset is short it shows red light on box also when you connect red pin to -ve and black to +ve also shows red light on box |
You have to read phone flash file and write it........ your problem is solved. wbr Dilip |
