03-11-2008, 22:54 | #1 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | SmartKey - repair movies, presentations, pinouts Service Software For LG Phones !!! Features : CU320 -flash-nv read-nv write-repair-imei repair-direct unlock CU400 -flash-nv read-nv write-repair-imei repair-direct unlock CU405 -flash-nv read-nv write-repair-imei repair-direct unlock CU500 -flash-nv read-nv write-repair-imei repair-direct unlock CU500V -flash-nv read-nv write-repair-imei repair-direct unlock CU720 -flash-nv read-nv write-repair-imei repair-direct unlock CU915 TEST-flash-nv read-nv write-repair-imei repair-direct unlock CU920 TEST-flash-nv read-nv write-repair-imei repair-direct unlock KU250 -flash-nv read-nv write-repair-patch unlock-same as others - need play with original SIM KU305 -flash-nv read-nv write-repair KU310 -flash-nv read-nv write-repair KU311 -flash-nv read-nv write-repair-direct unlock KU380 -flash-nv read-nv write-repair-imei repair-direct unlock KU450 OLD -flash-nv read-nv write-repair-direct unlock KU450 NEW -flash-nv read-nv write-repair patch unlock(same as others - need play with original SIM KU580 TEST-flash-nv read-nv-nv write KU730 -flash-nv read-nv write-repair-imei repair-direct unlock KU800 OLD -flash-nv read-nv write-repair-direct unlock ku800 NEW -flash-nv read-nv write-repair-imei repair-direct unlock KU950 -flash-nv read-nv write-repair patch unlock(need play with original SIM) KU970 -flash-nv read-nv write-repair patch unlock(need play with original SIM) KU990 -flash-nv read-nv write-repair-imei repair-direct unlock KS10 TEST -flash-nv read-nv write KS20 TEST -flash-nv read-nv write L600V -flash-nv read-nv write-repair-direct unlock MU500 -flash-nv read-nv write-repair-imei repair-direct unlock MU550 -flash-nv read-nv write-repair-imei repair-direct unlock TU500 -flash-nv read-nv write-repair-imei repair-direct unlock TU500F -flash-nv read-nv write-repair-imei repair-direct unlock TU515 TEST-flash-nv read-nv write-repair-imei repair-direct unlock TU550 -flash-nv read-nv write-repair-imei repair-direct unlock TU575 TEST-flash-nv read-nv write-repair-imei repair-direct unlock TU720 -flash-nv read-nv write-repair-imei repair-direct unlock U250 -flash-nv read-nv write-repair-patch unlock(need play with original SIM) U250C -flash-nv read-nv write-repair U300 -flash-nv read-nv write-repair-patch unlock(need play with original SIM) U300C -flash-nv read-nv write-repair U310 -flash-nv read-nv write-repair-patch unlock(need play with original SIM) U310C -flash-nv read-nv write-repair U450 -flash-nv read-nv write-repair-patch unlock(need play with original SIM) U450C -flash-nv read-nv write-repair U830 -flash-nv read-nv write-repair-patch unlock(phone unlocked after flash) U880 -flash-nv read-nv write-repair-patch unlock( SOS) U890 -flash-nv read-nv write-repair-patch unlock(need play with original SIM) U900 -flash-nv read-nv write-repair-patch unlock(SOS) U960 -flash-nv read-nv write-repair U970 -flash-nv read-nv write-repair U990 -flash-nv read-nv write-repair-imei repair-direct unlock U990c -flash-nv read-nv write-repair-imei repair-direct unlock B R |
09-01-2008, 18:08 | #8 (permalink) |
Product Supporter Join Date: Mar 2008
Member: 721981 Status: Offline Thanks Meter: 320 | Pinouts Pinouts USB Cable name: KG800 keyboard top 1.........18 12: phone Rx 13: phone Tx 1,11,18: Gnd Supported models: CB630, KB620, KF310, KF311, KF690, KU990, KU990MF, KU990GO, KU990R, KE990, KE990D, KE998, KU250, KU380, KU385, KU450, KU730, KU950, KU960, KU970, U990, U990C, CU515, TU515, CU575, TU575, CU720, TU720, CU500V, TU500, TU500F, CU320, CU400, TU500, MU500, MU515, MU550, CU405, CU500, KU310, KU311, KU800, KU970, U250, U300, U300C, U310, U370, U370W, U450, U450C, U830, U960, U970 |
The Following User Says Thank You to SmartKey.eu For This Useful Post: |
09-01-2008, 18:13 | #10 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | RJ45 Cable name: KE500 keyboard top 1.........18 1: Gnd 2: phone Rx (RJ45 pin-2) 3: phone Tx (RJ45 pin-3) 5: Gnd 15: Gnd 18: Gnd Supported models: KF600, KF600D, KE500, KE508 |
09-01-2008, 18:15 | #11 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | RJ45 Cable name: KG800 keyboard top 1.........18 12: phone Rx 13: phone Tx 18: Gnd Supported models: KE260, KE360, KE600, KE608, KE608N, KE770, KE800, KE820, KE850, KE850A, KE850ASV, KE858, KE970, KE970GO, KE970MF, KE970PK, ME970, ME970D, KG270, KG271, KG275, KG276, KG278, KG285, KG288, KG289, KG370, KG375, KP100, KP100GO, KP105, KP105A, KP105B, KP106, KP106A, KP106B, |
09-07-2008, 19:40 | #12 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | Repair of Unavailable Media File fast repair of Unavailable Media File within 3 seconds without the necessity of flashing the whole phone a few times you need to select the right file. The whole operation is being run in the following way: -Load File (we select the file that we want to write) -Flash Phone(the phone is restarted and the problem is over, the whole operation takes 3 seconds) Files on Ftp SmartKey server: U990__Unavailable Media File_HAS U990__Unavailable Media File_HDN U990__Unavailable Media File_HIR U990__Unavailable Media File_HIT U990__Unavailable Media File_HSW U990__Unavailable Media File_HUK Last edited by SmartKey.eu; 09-07-2008 at 20:18. |
09-08-2008, 19:04 | #13 (permalink) |
Member: 721981 Status: Offline Thanks Meter: 320 | U970__Unavailable Media File_HUK U970__Unavailable Media File_HSW U970__Unavailable Media File_HIT U970__Unavailable Media File_HIR U970__Unavailable Media File_HDN U970__Unavailable Media File_HAS |
10-26-2008, 12:10 | #14 (permalink) |
No Life Poster Join Date: Jul 2005 Location: TUNISIA Age: 44
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | SmartKey Translator/Repair/Unlock On Youtube SmartKey Translator Youtube Link http://www.youtube.com/watch?v=_nP-xAHso6w Repair Unavailable Media File Youtube Link http://www.youtube.com/watch?v=ZZfFg4kr9eQ LG U250 Repair Operation Youtube Link http://www.youtube.com/watch?v=nmOPCBuWJn4 KU385 Unlock Operation Youtube Link http://www.youtube.com/watch?v=S8TJgCw9HaU ***** Flashing Operation Youtube Link http://www.youtube.com/watch?v=GhpfAK2aVEI Soon More video Manuals will be added , Enjoy SmartKey !! SmartKeY SUPORTED MODELS KC910,HB620,HB620T,CB630,KB620,KF310,KF311,KF390,K F390Q,KF690,KU990,KU990MF,KU990GO,KU990R,KE990,KE9 90D, KE998,KS20,KU250,KU380,KU385,KU450,KU730,KU950,KU9 60,KU970,U990,U990C,CU515,TU515,CU575,TU575,CU720, TU720, CU500V,TU500,TU500F,TU500S,CU320,CU400,MU500,MU515 ,MU550,CU405,CU500,KU310,KU311,KU800,KU970,L600V,U 250, U250C,U300,U300C,U310,U310C,U370,U370C,U370W,U450, U450C,U830,U830C,U880,U880C,U890,U900,U960,U970,U9 70C SmartKeyKE SUPORTED MODELS KM710,KM710D,KF510,KF510C,KF510D,KM380,KM380C,KM38 0D,KM380T,KM385D,KS360,KS360GO,KS550,KC550D,KF600, KF600D, KF600C,KE260,KE360,KE600,KE608,KE608N,KE770,KE770C ,KE770D,KE850,KE850A,KE850ASV,KE858,KE970,KE970GO, KE970MF, KE970PK,ME770,ME770C,ME770D,ME850,ME850C,ME850D,ME 970,ME970C,ME970D,MG160A,MG160B,MG161A,MG165A,MG61 0C,MG800C, MG800D,KG70,KG77,KG90,KG90N,KG99,KG270,KG271,KG275 ,KG276,KG278,KG285,KG288,KG289,KG370,KG375,KG800,K G800S, KP100,KP100GO,KP105,KP105A,KP105B,KP106,KP106A,KP1 07A,KP110,KP110A,KP115,KP115A,KP200,KP202,KP202I,K P210A, KP215,KP215A,KP215B,KP230,KP233,KP235,KP270,KP293I SmartKey TRANSLATOR KC910,HB620,HB620T,CB630,KB620,KF310,KF311,KF390,K F390Q,KF690,KU990,KU990MF,KU990GO,KU990R,KE990,KE9 90D, KE998,KS20,KU250,KU380,KU385,KU450,KU730,KU950,KU9 60,KU970,U990,U990C,CU515,TU515,CU575,TU575,CU720, TU720, CU320,CU400,MU515,MU550,CU405,KU310,KU311,KU800,KU 970,L600V,U250,U250C,U300,U300C,U310,U310C,U370,U3 70C, U370W,U450,U450C,U830,U830C,U960,U970,U970C SmartKey BETA L601I,L602I,L704I,L705I,L705IX,L706IE,L852I TRANSLATOR http://rapidshare.com/files/157672570/SmartKey_Translator.rar.html SUPPORTING http://www./showthread.php?t=588268 MANUAL TRANSLATOR http://www./showthread.php?t=615515 FTP http://www./showthread.php?t=582006 RESELLERS http://www./showthread.php?t=512296 SmartKey Team Last edited by gsminfo; 10-26-2008 at 15:48. |
The Following 3 Users Say Thank You to DZStorm For This Useful Post: |
SonyEricsson Repair Instruction Repair Movie Here! | simonng83 | Sony Ericsson Hardware Repair | 237 | 02-01-2019 10:27 |
where can get w380 Repair Movie | 5mobile | Sony Ericsson Hardware Repair | 0 | 03-18-2009 13:00 |
