Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 03-24-2008, 17:10   #1 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Exclamation Automatic pinout detection: Troubleshooting
If you have any problems with Rx/Tx pins detection, double check the following:
  • Get sure that you have connected "Power" wires correctly ( see the previous manual for detailed information )
  • Check if the cable connector is completely inserted inside the phone connector
  • Check if the phone bottom connector contacts are clean. If no - than please clean them.
  • Examine whether the phone bottom contacts are not damaged inside the connector.
  • Check if the phone bottom connector is well soldered to phone PCB ( open the phone and check it )
  • Check if the phone bottom connector contacts are not cut internally ( open the phone and check it)
  • Examine whether the phone has Rx and Tx pins on phone bottom connector. Some phones don't have Rx and Tx pins on the bottom connector but have Rx/Tx test-points directly on phone PCB.
  • Some cables may have additional wire that should be cut for correct detection results.
    After you have carefully examined at every point and are sure that the problem is not in the above-mentioned list, than please, send an e-mail with the precise description of the problem to [email protected]. We will do our best to solve your problem within the shortest time possible!
The Following 4 Users Say Thank You to GSMtricks For This Useful Post:
Automatic pinout detection for CDMA/Qualcomm models InfinitySupport Infinity-Box 89 06-29-2012 10:07
PadFinder box - new smart universal box for automatic pinout search! GSMtricks PadFinder box 4 03-07-2011 09:28
PadFinder box - new smart universal box for automatic pinout search! GSMtricks Multi-Box 4 03-31-2008 10:56
PadFinder box - new smart universal box for automatic pinout search! GSMtricks Chinese Cocktail 6 03-27-2008 15:22
Automatic identification MTK 6226MA cable pinouts, backup flash file! phones-china Chinese Models & Cloned Phones 8 11-10-2007 17:16
Page generated in 0.11230 seconds with 9 queries
