CAN U HELP ME Spreadtrum Y NOT UNLOCK Connecting, phone must be off...OK Vers: Spreadtrum Boot Block version 2.0 Loading Boot...OK CPU ID: 6600D050 NOR Flash ID:00980049 - Toshiba TV0057A002CAGD Size:16Mb Reconnecting power...OK Ready... Clear User Lock... Section writing error! Clear User Lock...Failed Clear User Lock...Failed Clear User Lock...Failed Clear Thefprot Lock...Failed Clear User Lock...Failed Clear Thefprot Lock...Failed Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reading phone info... Cannot read EEPROM version info Cannot read IMEI Connecting, phone must be off...OK Vers: Spreadtrum Boot Block version 2.0 Loading Boot...OK CPU ID: 6600D050 NOR Flash ID:00980049 - Toshiba TV0057A002CAGD Size:16Mb Reconnecting power...OK Ready... then i click Read flash info its give but read phone info and i click phone lock (DO THE JOBS) its not give me info and not unlock.....Now problem is my phone lock. plz help me soon soon soon . |
You must read docs fiirst how to use soft |
plz mr.gsmtricks i need ur help but donot tell me (u must read docs first to use soft) coz i read docs many taims i have many phone n82 Spreadtrum SC6600D/E and cannot find pinout everytime plz tell me step by step how can i do |
tested and work without problem |
zaki_barika |
were sir were i found dosc.please say me this fist |
Spreadtrum tool - get the exclusive opportunities! Supported phone models list: SC 6600D MCU-based SC 6600E MCU-based CECT: 3838, Q380 SED: AK606 Software description: - Support SC 6600D MCU-based, SC 6600E MCU-based - Added "twin flash" option - Phone structure autodetection - Memory size autodetection - Firmware version autodetection - Possibility to connect the phone on different speed ( 460800, 115200 ) - Full flash backup/restore from backup option - File system formatting option - Reset to default values option - Possibility to read/write eeprom - Empty board flashing possibility - Pinout autodetect for "dead" phones - Dead phones repairing - Theft protection Lock - Automatic recalculation of security zone - Auto Calibration backup - Supports Initialization the phone after the process - Keeps Calibration data ( frequency settings, battery settings, LCD, sound ) - Supports IMEI repair/change - Restores Calibration Data - Connect/read MCU Firmware, System EEPROM, User Data, Product Data Manual for working with Spreadtrum Tool 1. Connect the phone and find the pinout using PadFinder ( see the manual on HOW TO FIND PINOUTS ) ATTENTION! * The phone has to be powered on and work in its usual manner. * For finding pinout DON'T PRESS "Power On" button * Pinout detection allows you to find the pinout for working even with "dead" phones, though the whole procedure may take up to 2-3 min. http://www.padfinder.net/UserFiles/Image/Manual1-2.JPG 2. It is strongly recommended to select the appropriate model from the models list! If you haven't found the suitable one there, than choose "Autoselect". 3. Press "Read Phone Info" button and read the handset information. http://www.padfinder.net/UserFiles/Image/Manual3.JPG 4. Select the appropriate flashfile from our support area and press "Connect/Read Flash Info" http://www.padfinder.net/UserFiles/Image/Manual4.JPG 5. Update firmware: a) if the phone is "dead", enable "MCU Firmware", "System EEPROM", "User Data", "Product Data" buttons under "Connect/read Flash Info" button; b) if the phone is functioning well, than enable just "MCU Firmware" button. http://www.padfinder.net/UserFiles/Image/Manual5.JPG 6. Power on the phone after the process. 7. If you enter the "Backup/restore" bookmark, you'll be able to Backup All Flash/Restore From Backup. ATTENTION! Don't forget to power on the phone after the process! http://www.padfinder.net/UserFiles/Image/Manual7.JPG 8. EEPROM backup/restore allows you to backup/restore the handsets values ATTENTION! Don't forget to power on the phone after the process! 9. There is a possibility to Restore Calibration Data even after the phone was flashed with full backup from other phone. In this case you'll have an opportunity to retore its native Calibration Data and old IMEI. 10. You can set new IMEI in couple of clicks. http://www.padfinder.net/UserFiles/Image/Manual10.JPG 11. With "Backup/Restore User Data" buttons you will be able to backup/restore Phone settings, Phonebook etc. ATTENTION! It is recommended to keep the handset active during the process. 12. "Reconnect Power" button reconnects the power supply. 13. "Theftprot Lock" - allows you to find your stolen phone. If you set the code to the phone, than as soon as the phone is powered on, you'll get the SMS with the info about its location. |
but can u give me pic for pinout |
