Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 03-24-2008, 17:06   #1 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Lightbulb How can the manual pinout selection be usefull?
Multi-box Team has made it possible to set Rx/Tx pins and enable/disable pins manually - with just two clicks of the mouse. It is very usefull if you know the correct pinout in a phone with a new currently not supported processor. You can point in the right place RX / TX pins with two clicks! It is also worth saying, that you get the solution for ALL PROBLEMS with 2-processors Chinese phones, because the second pinout can be found easily in no time. All you need is just to disable manually the already found pinout for the first processor and PadFinder will find you the pinout for the second CPU in no time!
You can manually set the Rx/Tx pins directly on the cable schematic or on the table :
After the manual pin selection you can use the found/selected pin configuration to work with any flashing/unlock software you like ( for instance, Multi-box Chinese cocktail ). Or buy PadFinder Full version to deal with huge range of cel phones: ABSOLUTELY ALL Chinese MTK-based phones and also with Spice, Bird, Philips S-series, TCL and Bleu handsets!
The Following User Says Thank You to GSMtricks For This Useful Post:
Old 03-27-2008, 20:06   #2 (permalink)
turkcellgsm's Avatar
Member: 395431
Thanks Meter: 459
best sulution thanks multibox team
always speed team
Old 03-27-2008, 22:27   #3 (permalink)
Member: 638062
Thanks Meter: 46
thanks multibox team 100000000000000
Old 03-28-2008, 12:11   #4 (permalink)
erkan06us's Avatar
Member: 174769
Thanks Meter: 19
its fantastic thanx
Old 03-31-2008, 09:48   #5 (permalink)
Member: 270936
Thanks Meter: 33
Hey its gud work from multi team thanks
Old 04-04-2008, 09:01   #6 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
And more is comming sure very soon!
can the alactel miss sixty be unlocked jjsweets Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 5 01-10-2010 08:35
how can i flash w208 to be arabic with mss attia1984 Motorola ODM 0 06-01-2008 13:19
Can the new Rogers ROKR be unlocked? ticktock Smart-Clip 2 11-03-2005 15:37
How can the M 100 be unlocked? Like n-100 with imei? sifasli VLSI, Conexant, Skyworks and Old Models 3 11-18-2001 11:44
Page generated in 0.13890 seconds with 9 queries
