PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Hackers hell
Member: 327309 Status: Offline Sonork: 100.54567 Thanks Meter: 177 | ![]() PadFinder is a really Universal cable-box - can work with all brands! After you have successfully found the pinout, you just run the latest version of the necessary soft ( from the Multi-box or Multi-box LITE's list ) and start working! PROCEDURE OF WORKING WITH MULTI-BOX ( LITE ) ![]() 1. Connect PadFinder to PC via an ordinary AB USB cable 2. Connect Multi-box or Multi-box LITE using RG45 Multi-box cable ( comes with the PadFinder cable set ). * Plug the RJ45 to RJ45 cable into "Special" socket of Multi-box ( LITE ) and "MULTI-BOX CONNECT" socket on PadFinder. *No need for additional USB connect. ATTENTION: If connected like this, you must start any service tool of Multi-box ( LITE ) to give supply to PadFinder via RJ45 tyo RJ45 cable. If you don't do this, you won't be able to use PadFinder! 3. Connect the DB26 cable to PadFinder ( "Special" socket ) and to the phone. 4. Find the pinout using PadFinder ( see the manual ) OR use the CLIP function ( see the manual ) to save your time and for more convenience if the phone is MTK-based! 5. Start the appropriate soft of Multi-box ( LITE ) and start working! IMPORTANT: No need for any activations to work with Multi-Box ( LITE )! SEE THE VIDEO FILE AVAILABLE! Last edited by Multi-box TEAM; 03-25-2008 at 17:34. |
The Following User Says Thank You to Multi-box TEAM For This Useful Post: |
![]() | #3 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | as i said in the video manual...i did it... but in the Chinese cocktail phone not detected... only searching but in the PADFINDER it detects the pinout please guide me... also in the video manual...u add the process you do in the USB disconnecting and the connecting the USB to the Multi box and doing... |
![]() | #4 (permalink) | |
Member: 327309 Status: Offline Sonork: 100.54567 Thanks Meter: 177 | Quote:
1. What phone do you have? 2. Do you use only PadFinder or some other device to work with the phone? 3. In what Mode (Unibox or Command) are you trying to work with the phone? | |
![]() | #5 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | when i try to work the PADfinder with Infinity works very nice..... i follow all the steps as you said in the manual... only thing i doughted is the disconnecting the PADfinder and then connecting it into the Multi box... i have Multibox lite with full activation..i have connectee RJ45 -Rj45 in the Special port in the multi... 1 . selected the Pinout using PADfinder 2. set the mode as Unibox mode 3. removed the USB from Pad 4 . Usb connected to the Multi box.. 5. from Multi "special " RJ45 -RJ45 cable is connected to the PADfinder 6. now when i try to find out the phone from Chinese cocktail ...it fails this what i did... but the PADfinder works very nice and also very speedy... works with Spiderman(crack) also... ![]() thanks sir.. |
![]() | #6 (permalink) | |
1. Connect your Multi-box LITE via ordinary USB to PC 2. Connect PadFinder and Multi-box using Multi-box RJ45 -RJ45 cable 3. START CHINESE COCKTAIL TOOL OF Multi-box LITE (!!!) 4. Find the phone pinout using PadFinder 5. Try to connect the phone and read info in Chinese cocktail Please, do it step-by-step as written & post the result! | |
![]() | #7 (permalink) |
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | yes sir i tryed with this steps... after the 3rd step.. after opening the chinese cocktail....i minimized it.. and when i try to open the PADfinder exe...it says.. " PADfinder box not detected.please ensure that box connected to USB. Also switch box to command mode by manually pressing button on box." what to do now.. |
![]() | #8 (permalink) | |
OR You can work with PadFinder Chinese cocktail if you have it activated! | |
![]() | #10 (permalink) |
Member: 327309 Status: Offline Sonork: 100.54567 Thanks Meter: 177 | I didn't tell not to open Main tool at all! All I wanted to tell you that you can't flash/unlock the phone with Main tool. You can do it with PadFinder's Chinese cocktail (if you have it activated), with Multi-box (LITE) or any other box with the appropriate software. You have told me the the problem was not in finding the pinout, but in working with the phone in Chinese cocktail - so I gave you the recommendations concerning this issue. Talking about your question: You can find the pinout using CLIP function as well. And the box saves the found pinout automatically, so the next time when you connect PadFinder you don't need to search the pinout again! |
![]() | #11 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Tanzania
Member: 14229 Status: Offline Thanks Meter: 136 | i have followed the procedure just as you said but i cant use my padfinder with multbox-lite. i can use it with infinity, otherfree software but not with multbox please help me |
![]() | #13 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: falcon box
Member: 106346 Status: Offline Sonork: 100.1577684 Thanks Meter: 1,061 ![]() | Quote:
![]() | #14 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 320622 Status: Offline Thanks Meter: 4 | Quote:
multi box and multi box lite | kwasasco | Multi-Box | 2 | 08-04-2009 11:17 |
How does PadFinder work with other boxes like Infinity, Furious, ET-box etc.? | Multi-box TEAM | PadFinder box | 49 | 11-21-2008 10:39 |
PadFinder box and Multi-box - flash files update at support area! | GSMtricks | Service Products News & Updates | 0 | 09-23-2008 11:42 |
What is the differents between Multi-box and Multi-box LITE? | GSMtricks | Multi-Box | 0 | 08-29-2007 11:38 |
