Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 08-14-2008, 08:56   #16 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Originally Posted by Vey View Post
Ok, now I m using the clip function. After successfully with (4), but I failed at (5). Cant detect anything.
Sorry but I dont understand your question
Old 08-14-2008, 11:04   #17 (permalink)
Vey
Member: 320622
Thanks Meter: 4
Ok.
Step 1: Connect MultiBox to PC via USB. Done!
Step 2: Connect Padfinder to Multibox RJ45 to RJ45 (No PC USB to Padfinder). Done!
Step 3: Run Chinese Cocktail v9.0. Done!
Step 4: Find phone pinout using Padfinder (Using Clip Function. Read the manual over and over again). Done!
Step 5: Click "Connect" on Chinese Cocktail. No phone found!
LOL! Im scratching my head all over. Where could have I gone wrong?
Oh, my phone is K-Touch B921 (China). I have test it with Padfinder alone using Maintool and the search for the pinouts no problem.
Old 08-14-2008, 11:15   #18 (permalink)
Vey
Member: 320622
Thanks Meter: 4
Originally Posted by Multi-box TEAM View Post
1. Connect PadFinder to PC via an ordinary AB USB cable
2. Connect Multi-box or Multi-box LITE using RG45 Multi-box cable ( comes with the PadFinder cable set ).
* Plug the RJ45 to RJ45 cable into "Special" socket of Multi-box ( LITE ) and "MULTI-BOX CONNECT" socket on PadFinder.
*No need for additional USB connect.
ATTENTION: If connected like this, you must start any service tool of Multi-box ( LITE ) to give supply to PadFinder via RJ45 tyo RJ45 cable. If you don't do this, you won't be able to use PadFinder!
3. Connect the DB26 cable to PadFinder ( "Special" socket ) and to the phone.
4. Find the pinout using PadFinder ( see the manual ) OR use the CLIP function ( see the manual ) to save your time and for more convenience if the phone is MTK-based!
5. Start the appropriate soft of Multi-box ( LITE ) and start working!
IMPORTANT: No need for any activations to work with Multi-Box ( LITE )!
SEE THE VIDEO FILE AVAILABLE!
1)Connect USB to Padfinder and not Multibox Lite?
2) RG45 or RJ45?
Old 08-14-2008, 11:17   #19 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
2) RG45 or RJ45?
1. To USB first and need find pinout first than can conect to LITE
2. What do you mean RG 45?
Old 08-14-2008, 11:32   #20 (permalink)
Vey
Member: 320622
Thanks Meter: 4
Old 08-14-2008, 11:39   #21 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
And where is the problem ?
Old 08-14-2008, 11:46   #22 (permalink)
Vey
Member: 320622
Thanks Meter: 4
Im sorry, theres no problem. Just that when things dont work for me I tend to go thru ever tiny bits of detail trying to figure out where did I went wrong. I sincerely thank you for your patience and effort trying to help me
So RG45 is the cable with RJ45 connector on both end?
Old 08-14-2008, 11:49   #23 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Did you chech post with I made bellow? There aleady even pic with correct conenctions and step-by-step written all how to do
Old 08-14-2008, 12:33   #24 (permalink)
Vey
Member: 320622
Thanks Meter: 4
My connection is exactly like this. And this time I dont use the CLIP method. Instead I follow "How_does_PadFinder_work_with_Multi-box_eng.swf" instructions.
1) Connect Padfinder to USB and run Maintool.
2) Found the pinouts then click on "Unibox Mode".
3) Unplug USB from Padfinder and connect to Multibox.
4) Padfinder connect to Multibox (RJ45-RJ45).
5) Run Chinese Cocktail v9.0 and click on "Connect".
6) Chinese Cocktail ask for "Press and hold power on button.."
7) TIMEOUT!
I have tried all 4 Based platform also same. Tried both Baud Rate also same.
Is my procedure wrong?
Old 08-14-2008, 13:46   #25 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
7) TIMEOUT!
1. You must be sure that your phone is really MTK
2. You must press and hold power on botton long time
Old 08-15-2008, 04:27   #26 (permalink)
Vey
Member: 320622
Thanks Meter: 4
I did. I even tried it with a N95 China (which is now working in a fine condition) I ever repaired with my Multibox and I tried it with Padfinder. Searching for the pinouts is a no problem with padfinder but when trying to detect with my Multibox, it failed. Tested on 3 phones none worked. So right now Im full of question marks. Where could my problem be?
-Padfinder outlet socket to Multibox problem?
-RJ45-RJ45 cable problem?
-Multibox problem?
-My pc problem?
Im very sure I have done the procedure correctly and I have go thru the manuals over and over again. Maybe I will borrow another Multibox from a friend and give it another try or try it in another pc.
Old 08-20-2008, 02:49   #27 (permalink)
Member: 73455
Thanks Meter: 23
i have another problem regarding connecting the multi box lite & padfinder box i tried connecting both already the two boxes but my padfinder box seems dont have power coz it doesnt show light...what do u think is the problem?
Old 08-20-2008, 08:01   #28 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
This is not a problem. You just need docs. There written that you must start chinese cocktail tool than your padfinder will have power.
Old 08-22-2008, 08:44   #29 (permalink)
Cheater -Don't Deal with him-
Member: 490708
Sonork: 100.1587135
Thanks Meter: 569
Kindly tell me if i have multi box not multi box lite then i need to activate my box or not?
Old 08-22-2008, 08:52   #30 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Bu we told already - NO NEED. Soft for Multi-box and Multi-box LITE is same.
multi box and multi box lite kwasasco Multi-Box 2 08-04-2009 11:17
How does PadFinder work with other boxes like Infinity, Furious, ET-box etc.? Multi-box TEAM PadFinder box 49 11-21-2008 10:39
PadFinder box and Multi-box - flash files update at support area! GSMtricks Service Products News & Updates 0 09-23-2008 11:42
What is the differents between Multi-box and Multi-box LITE? GSMtricks Multi-Box 0 08-29-2007 11:38
Page generated in 0.24734 seconds with 9 queries
