Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 07-28-2009, 02:52   #1 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile Can you add a new cables to the soft?????
We need a new update of this tool. Adding new cables to the soft because only has until the PAD022 in the list. I try to edit the .ini files and modiffied an image of one cable. But no work.
I attach here an example, maybe in some days I can add all new cable images and Multi Box Team will correct any mistake. Then you can update the software again adding a new cables set.
And maybe you can add some option like automatic selection of phone plattaform.
Example of PAD025 Cable Details:
Example of PAD025 Cable that will show the software:
Best Regards................aslam870
Old 07-28-2009, 06:53   #2 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
I told already soft is working. Select cable with 24 pins and search pinout it will work.
Old 07-28-2009, 07:31   #3 (permalink)
aslam870's Avatar
Member: 383033
Sonork: 100.1580642
Thanks Meter: 441
Smile
We know that my friend. I test this software many time without any problem. Is only to improve the graphic interfase of the software.
Best Regards...........aslam870
n75 new version - can you add to your server? hridaya MT-BOX 3 12-07-2007 19:52
CAn you add new SIEMENS file to support for SL75, S68, EL71, M81, ME81 and other new? wgmmmx MT-BOX 0 10-21-2007 16:45
Can you add support to new driver for smartcard CCID???? wgmmmx BB5BOX 3 09-24-2007 23:50
Can you add update from cid51 to cid52 becouse I don't see on support wgmmmx MT-BOX 3 05-17-2007 15:25
Can you use a serial cable to put images, mp3 etc onto D500 solid_snake SWIFT Platform 0 09-27-2005 19:24
Page generated in 0.14547 seconds with 9 queries
