Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 03-24-2008, 17:07   #1 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Lightbulb How to use PadFinder as CLIP?
Possibility to use PadFinder as Clip - absolutely unique feature for ALL MTK-processor based phones!Opportunity to use PadFinder as Clip for pinouts autodetection in ALL MTK CPU phones is a distinguishing peculiarity of our box and marks it out among the same kind of devices! This unique opportunity allows you to find the pinout WITHOUT STARTING SERVICE TOOL in several seconds!
Why it is usefull?
- You get the ONE BUTTON SOLUTION for ALL MTK-based phones ( handsets besed on
other processor types are under permanent development now and will be added in further updates )!
- No need to start any service programs, choose cables and make settings for
pinout autodetection
- Connects to PC via ordinary USB AB cable
- Pinouts are found at once and you get to work right away
- You can start the appropriate Service program for phone unlocking/flashing
etc. right away ( For example, Multi-box "Chinese Cocktail" )
While your competitors are just preparing for work, you already HAVE the WORK
DONE!
PROCEDURE OF USING PadFinder AS CLIP
1. Connect PadFinder to PC via ordinary USB AB cable
2. Remove phone battery!
3. Plug DB26 (26 pins) to "SPECIAL" socket.
4. Plug the appropriate phone connector to the phone input.
5. Using power wires from DB26 connect them insted of battery
"+" (red) power wire must be connected to phone "+" contact
"-" (black) power wire must be connected to phone "-" contact
6. PRESS and HOLD "MODE SELECT" button ( located near the "SPECIAL" socket of
PadFinder ) for 7-8 seconds
* after you hold the button for 3 seconds you will see the YELLOW LED lighted -
the box is in Command Mode, continue pressing
* after 5-6 seconds the RED LED will light - the box is ready to detect the
pinout
7. STOP PRESSING "MODE SELECT" button after 7-8 seconds - the YELLOW LED will
light again
8. PRESS and HOLD "Power On" button ON THE PHONE
9. The YELLOW LED will start blinking => it means that PadFinder searches the
pinout
10. The RED LED will light => it means that PadFinder has found the pinout and
you can release "Power On" button of the phone
NOTE:
ALL THE PROCESS OF PINOUT AUTODETECTING TAKES APPROXIMATELY 20-25 seconds
The Following User Says Thank You to GSMtricks For This Useful Post:
Old 03-29-2008, 22:04   #2 (permalink)
fonec's Avatar
Member: 11101
Sonork: 100.1641000
Thanks Meter: 1,783
thanks for great work
Old 03-29-2008, 23:18   #3 (permalink)
Ramicom's Avatar
Member: 76754
Sonork: 1580514
Thanks Meter: 37
yes its very great work
Old 03-30-2008, 14:31   #4 (permalink)
i-care's Avatar
Member: 225419
Thanks Meter: 63
Cool wow great!!!!!
today i used it!!!
amazing, it is very good tool to find pinouts in seconds without running any software.
very good
thanks multibox team and thanks my reseller krinovate communications who suggested me this box.
regards,
i-care.
Old 03-30-2008, 14:33   #5 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 296
Thanks for Gd Information.
Old 03-30-2008, 17:11   #6 (permalink)
.:CARLO:.'s Avatar
Member: 126086
Sonork: 100.113901
Thanks Meter: 232
wow nice info sir.............
Old 03-31-2008, 10:09   #7 (permalink)
Member: 270936
Thanks Meter: 33
Thanks for the info its great to read n work
Old 03-31-2008, 12:29   #8 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
while using with Multibox...
how to do...
fisrt yellow light blinks...and then red blinks...
i removed the button then yellow blinks and immediatel the red blinks...
what to do now
Old 03-31-2008, 12:44   #9 (permalink)
Member: 327309
Sonork: 100.54567
Thanks Meter: 177
how to do...
what to do now
What button have you removed? Follow the procedure carefully as written and you will face no problem
Old 04-02-2008, 05:55   #10 (permalink)
harim_1981's Avatar
Member: 243961
Sonork: 100.1591654
Thanks Meter: 104
thanks for the reply sir...
finally it works for me...box as clip....and then connected to the Multibox..used the Chinese cocktail software..and made all the operation fine...
thanks to multi team...
Old 04-02-2008, 09:05   #11 (permalink)
Member: 327309
Sonork: 100.54567
Thanks Meter: 177
We are glad that you enjoy all the advantages and conveniences of PadFinder!
Old 04-04-2008, 09:08   #12 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Sure is working. Very good
Old 06-28-2008, 14:08   #13 (permalink)
Member: 39069
Sonork: 100.1606677
Thanks Meter: 190
My experient, please not yet connect phone to padfinder box untill software run (open) properly coz all cable pinout free( no use ) always connect to ground. if we connect cable from box to phone befor open software will appear Padfinder not detect. I think many user know but if dont know just tr it.
Old 06-28-2008, 14:19   #14 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
That mean your box was not in clip mode
Old 07-12-2008, 22:50   #15 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Thanks Meter: 374
this box is truly unique, mine arrives monday ans i hope to enjoy it!
How to use padfinder full version benny Haraba PadFinder box 3 08-08-2009 18:10
how to use padfinder with SE j132 gsmdok PadFinder box 5 02-01-2009 05:50
How To Use Padfinder misal PadFinder box 4 09-01-2008 08:01
How to use UB as ordinary usb to serial 2xxu Universalbox 1 03-04-2007 19:06
how to use MP3 as a ring tone? sunilshrestha Nokia Multimedia 2 04-20-2006 15:48
Page generated in 0.24564 seconds with 9 queries
