Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 03-24-2008, 16:35   #1 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Thumbs up IMPORTANT: What is PadFinder box?
Meet PadFinder - absolutely the best solution for all problems with pinout detection!
PadFinder - the universal device, which automatically finds pinout for your cell phone. This device contains a number of unique functions and will allow you to work with a huge range of cell phones.
DISTINGUISHING FEATURES:
- Automatic selection of the desired pinout for your Chinese phones just by pressing a button on the box!
- PadFinder is fully compatible with other boxes! That means that you will be able to use it not only for searching the pinouts, but also for compatibility cables.
- The box management procedure is simple and easy understandable. Full control of all the box capabilities is performed with just one button. Now you do not need to spend time to assimilate new device!
- Signals manaul control option with multiple clicks, which is very usefull in case if you know the correct pinout on the phone with a new processor. You can point in the right place and RX / TX pins in two clicks!
- Managing the box manually provides you the unique opportunity to exclude the unnecessary pins! This is very important when dealing with 2-processors Phones, because a lot of problems arise for finding the second pinout.
- The unique opportunity to save the already found and checked pinouts. Having found the necessary pinout for your phone, you can save it and the next time you can choose from the saved models list the one you need - the box will automatically make the cable settings for you. Simply, conveniently and comfortably!
- Possibility to use PadFinder as Clip for pinouts autodetection in ALL MTK CPU phones is a distinguishing peculiarity of our box and marks it out among the same kind of devices! You get the ONE BUTTON SOLUTION for ALL MTK-based phones ( handsets besed on other processor types are under permanent development now and will be added in further updates )! need to start any service programs, choose cables and make settings for pinout autodetection - pinouts are found at once and you get to work right away.
With PadFinder you will have the work done while your competitors are just preparing!
An automatic pinout search ( extremely convenient and usefull for chinese phones ), saving the found pinout with the simple ini files system, possibility of box manual management with our programm - allows you to set manually the appropriate pinouts you know, excluding the unnecessary when searching the pinouts for the second CPU ( for chinese phones ), full compatibility with other boxes, which allows you to connect their cables to PadFinder box.
Initial support for several CPU types for an automatic search ( other CPU types will be added with the next updates ):
- MTK 62xx ( all MTK include 6228, 6229 etc )
- AD 6522 / AD 6525
- TI sample A ( VK3xx etc )
- TI sample B ( boot in ROM )
- TI sample B ( boot in Flash Rom )
- SkyWorks CX805
- Philips OM6357 ( bootstrap )
- Philips ( tat mode )
ATTENTION: Other processor types, which are absent in the list at the moment, will be added with further updates! But knowing the pinout, you can allways make the cable setting manually for any CPU type, even if it is not in the list.
What do you get having bought this device:
- PadFinder box
- Cables set ( 22 pcs )
- USB cable
- RG45 Multi-box cable
- DB26 -> RG45 coverter cable
- 1 year free support and update
- Box configuration and management program
For more info, please, spend some time and explore our official web-site: www.padfinder.net
The Following User Says Thank You to GSMtricks For This Useful Post:
Old 03-24-2008, 16:42   #2 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
reseller in india
i like to buy this box.. is the box available in indian market?
Old 03-24-2008, 16:45   #3 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
Yes sure: http://www.padfinder.net/reseller.htm
Old 03-24-2008, 21:18   #4 (permalink)
HAJGSM's Avatar
Member: 34710
Thanks Meter: 26
Thanx for this useful gadget,at least its going to save much time and make work easier.
Old 03-25-2008, 02:54   #5 (permalink)
Member: 575851
Thanks Meter: 544
sir i have question i have also munltibox lite but not cable by padfinder i can buy cable for padfinder we can use for multibox lite
Old 03-25-2008, 09:49   #6 (permalink)
Member: 327309
Sonork: 100.54567
Thanks Meter: 177
Please, read FAQ's
We strongly recommend to read F.A.Q.'s before asking, because the answer can often be there already: http://forum.gsmhosting.com/vbb/showthread.php?t=516880 - you will find: I have got Multi-box or Multi-box LITE already. How does the box work with them?
You need to connect Multi-box or Multi-box LITE using RG45 Multi-box cable ( comes with the PadFinder cable set ). You need to plug the cable from PadFinder into Special socket of Multi-box ( LITE ). No need for additional USB connect.
IMPORTANT: NO NEED FOR ANY EXTRA ACTIVATIONS to work with Multi-box (LITE) or any other boxes!
Old 03-26-2008, 17:33   #7 (permalink)
Member: 70916
Thanks Meter: 56
it is duplicate of auto pinout finder adaptor made by infinity box team what new in it ?
Old 03-26-2008, 17:38   #8 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
No is not duplicate. If you compare a functions you will see a BIG difference. Anyways we start develop this box long time ago - but because of a lot of uniqum things like:
- can work like clip
- can work standalone like any chinese box for chinese phones
- can work with many others brand
- have too many functions
- works with Multi-box and Multi-box LITE without any extra power and extra tools and axtra activations
- works with all others boxes and softwares
- etc...
It tooks so long time, and just because of chinese new year we release it just now. But this is our research from begging. If you will read all docs and manuals for this box, if you will check all video files and if you stay in this section more ( few days ) - you will see how GOOD is this new box.
Old 03-26-2008, 17:40   #9 (permalink)
Member: 51453
Thanks Meter: 729
nice box with nice support.this make work more easier
br
Old 03-26-2008, 17:48   #10 (permalink)
Member: 178365
Thanks Meter: 22
- works with Multi-box and Multi-box LITE without any extra power and extra tools and axtra activations - works with all others boxes and softwares
- etc...
so if we already have multi box (lite), we just buy padfinder lite. is it true ?
Old 03-26-2008, 17:54   #11 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
YEs is true - you don't need any activations you need just PadFinder with cables.
Activations we do just for peoples who don't have Multi-box but want to use our chinese cocktail tool and other with this box. So they can but this box and make activations and they will have full box which support all chinese phones and other ( MTK based ), but if you have already Multi-box LITE or Multi-box you DON'T need activations BECAUSE software for this you already have!
Old 03-29-2008, 14:38   #12 (permalink)
Member: 68672
Thanks Meter: 6
Does we need any EXTRA activation if want to use Padfindet standalon ???
Old 03-29-2008, 14:49   #13 (permalink)
Member: 129486
Thanks Meter: 66
you dont need any extra activation only you have to buy PadFinder box
Old 03-31-2008, 07:53   #14 (permalink)
Member: 68672
Thanks Meter: 6
@gsmtricks
Means does we need to pay extra for standalone Padfinder??
Old 03-31-2008, 08:34   #15 (permalink)
Member: 327309
Sonork: 100.54567
Thanks Meter: 177
@gsmtricks
NO, you DON'T need any EXTRA activations to use PadFinder stand-alone! All you need is PadFinder itself!
What is Infinity box and how is it used? timezout Infinity-Box 5 11-18-2011 20:45
what is nano box?and what support phone?[ANSWERED] somonahmed PolarBox 3 1 01-14-2010 07:46
What is Security BOX kulibin Sony Ericsson 2 02-06-2009 20:53
WHAT is universal box -cost (price) in india i want buy new universal box Rajan chhetri Universalbox 3 10-24-2008 08:42
What Is My Box ID: ?????? ADAMRYANREST Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-05-2002 05:51
Page generated in 0.24254 seconds with 9 queries
