PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
08-10-2008, 06:43 | #1 (permalink) |
Registered User Join Date: Feb 2006 Location: tagum,davao philippines
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | q380 spreadtrum flashfile needed |
08-10-2008, 06:44 | #2 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | Detecting pinout, please wait... (Push box button to Abort) Processing, please wait...OK Rx - 13 Tx - 11 BootPin - 6 Reading phone info... Section read error! Connecting, phone must be off...OK Vers: Spreadtrum Boot Block version 2.0 Loading Boot...OK CPU ID: 6600D050 NOR Flash ID:00EC257E - Samsung ?????? Please read full flash backup and contact [email protected] for update Warning! Unknown flash chip type! Please read full flash backup and contact for upgrade. Reconnecting power...OK Ready... Connecting, phone must be off...OK Vers: Spreadtrum Boot Block version 2.0 Loading Boot...OK CPU ID: 6600D050 NOR Flash ID:00EC257E - Samsung ?????? Please read full flash backup and contact [email protected] for update Reading phone backup... Reading data...OK Reconnecting power...OK Ready... |
08-10-2008, 08:15 | #3 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | Detecting pinout, please wait... (Push box button to Abort) Processing, please wait...OK Rx - 13 Tx - 11 BootPin - 6 Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reconnecting power...OK Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reading phone info... Cannot read EEPROM version info Cannot read IMEI Reading phone info... Version: V1.0.1-B7 Modem Vendor: Spreadtrum Communication CO. IMEI: 354047011863663 version: TS6811_V1.3.7_for528.TS6811_V1.3.7_for528 Product info: 35404701186366 User lock: - OPEN Thefprot code: - OPEN Card IMSI: 000000000000000000 Phone number: Reading calibration data...OK Ready... No connection with box! No connection with box! No connection with box! No connection with box! No connection with box! No connection with box! |
08-10-2008, 15:43 | #5 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 43
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Manual for working with Spreadtrum Tool 1. Connect the phone and find the pinout using PadFinder ( see the manual on HOW TO FIND PINOUTS ) ATTENTION! * The phone has to be powered on and work in its usual manner. * For finding pinout DON'T PRESS "Power On" button * Pinout detection allows you to find the pinout for working even with "dead" phones, though the whole procedure may take up to 2-3 min. 2. It is strongly recommended to select the appropriate model from the models list! If you haven't found the suitable one there, than choose "Autoselect". 3. Press "Read Phone Info" button and read the handset information. 4. Select the appropriate flashfile from our support area and press "Connect/Read Flash Info" 5. Update firmware: a) if the phone is "dead", enable "MCU Firmware", "System EEPROM", "User Data", "Product Data" buttons under "Connect/read Flash Info" button; b) if the phone is functioning well, than enable just "MCU Firmware" button. 6. Power on the phone after the process. 7. If you enter the "Backup/restore" bookmark, you'll be able to Backup All Flash/Restore From Backup. ATTENTION! Don't forget to power on the phone after the process! 8. EEPROM backup/restore allows you to backup/restore the handsets values ATTENTION! Don't forget to power on the phone after the process! 9. There is a possibility to Restore Calibration Data even after the phone was flashed with full backup from other phone. In this case you'll have an opportunity to retore its native Calibration Data and old IMEI. 10. You can set new IMEI in couple of clicks. 11. With "Backup/Restore User Data" buttons you will be able to backup/restore Phone settings, Phonebook etc. ATTENTION! It is recommended to keep the handset active during the process. 12. "Reconnect Power" button reconnects the power supply. 13. "Theftprot Lock" - allows you to find your stolen phone. If you set the code to the phone, than as soon as the phone is powered on, you'll get the SMS with the info about its location. |
08-11-2008, 01:44 | #6 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | yes i read that one how many times but my problem is how to get those files and how to put it in the software this number four on ly is my problem 4. Select the appropriate flashfile from our support area and press "Connect/Read Flash Info" |
08-11-2008, 01:52 | #7 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | pls upload some image how to get files and putting it on the software i have realy a problem doing this number 4 to 5 guide because in my case if you see my logs Detecting pinout, please wait... (Push box button to Abort) Processing, please wait...OK Rx - 13 Tx - 11 BootPin - 6 Reading phone info... Section read error! Connecting, phone must be off...OK Vers: Spreadtrum Boot Block version 2.0 Loading Boot...OK CPU ID: 6600D050 NOR Flash ID:00EC257E - Samsung ?????? Please read full flash backup and contact [email protected] for update Warning! Unknown flash chip type! Please read full flash backup and contact for upgrade. i reaally need to flash the unit because it is already samsung???????? |
08-11-2008, 04:44 | #8 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | please pad finder team check your support if it has really a spreadtrum flashfile in your support because if your just really looking it in your support theres nothing in there .......what kind of box is this i activated it for spreadtrum and now theres no spread trum in the support ....area |
08-11-2008, 05:13 | #9 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | pls supporter you must look persionally for the support site if theres spreadtrum there as waht you said http://files-for-all.com/support2/_m...12AB8A0A7B2221 |
08-11-2008, 07:46 | #10 (permalink) | ||
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
Software told you already what need to do man!!! | ||
08-11-2008, 08:58 | #11 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | i already read full flash back up and send email to multi box so what next????can i repair this unit or not? |
08-11-2008, 12:40 | #15 (permalink) |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Stop spam with same post man: http://files-for-all.com/test/files/...ol/Flash_files |
need good flashfile q380 spreadtrum.......... | jonar23 | PadFinder box | 6 | 10-11-2008 11:11 |
5 q380 spreadtrum killed by new update | RED PHOENIX | SpiderMan | 19 | 09-14-2008 05:11 |
IPHONE Q380 spreadtrum cpu can we FLASH? | Brod Aries | Chinese Cocktail | 1 | 07-14-2008 08:40 |
can i do format Q380 spreadtrum sc6600d5 w/out usbpinfinder | batiks | SpiderMan | 6 | 06-24-2008 15:24 |
i-phone Q380 spreadtrum chip formatt fs ? | kungpaoski | Infinity-Box | 2 | 06-07-2008 14:23 |
