Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Multi-Box TEAM Products > PadFinder box
PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions.
Old 07-02-2009, 15:35   #1 (permalink)
Member: 57456
Thanks Meter: 11
Unhappy I cant use my padfinder box....plese help me .......
Sir,
I have a pad finder box.but i can't use this box with infinity.
First i connected phone with pad finder box and after finding the pinouts i selected unibox mode and minimised the padfinder main tool.After that i opend the infinity box software and selected the phone model and padfinder port.
I pressed 'Format' button in service tab then it shows..
COM3 [VCP1] selected
module v2.82
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
then i pressed power button but it is not connected...
and i repeated with another phone but the same fault...
and also checked with another padfinder but it have also same fault...
now what can i do sir ???
Old 07-03-2009, 08:24   #2 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
This is not infinity support section
Old 07-03-2009, 13:47   #3 (permalink)
Member: 57456
Thanks Meter: 11
Padfinder box is not working.....
then tell me sir for what purpose this box is used ????????
then what is the function of "unibox mode" ????????
if you don't konw about padfinder box please refer me another one expert....!!!
i have 3 pad finder boxes .......
what i can do with this boxes ?
may i send this to you.....???
Old 07-03-2009, 14:22   #4 (permalink)
Member: 430612
Thanks Meter: 301
i had same problem before and no one was helping me bro dont be lazy read the manuel www.padfinder.net
if you want to connect padfinder with infinity it very simple just 1.connect infinity box to usb port
2.connect padfinder to usb also ,then such the pin and make sure you press POWER ON on main tool and then select right cable
close main tool open infinity chinese miracle on port select padfinder port according to device manager and voila it work fine
The Following User Says Thank You to luyanda For This Useful Post:
Old 07-06-2009, 08:59   #5 (permalink)
Member: 57456
Thanks Meter: 11
Unhappy
wat r u saying man ?
last two mnths i used this box perfectly....
nw it is nt wrkng.....
when i asked this question here they saying its nt infinity support section....
and i repeated this in infinity section then they said it is nt their fault pls ask in padfinder section....
then wat can i do ?
Old 07-06-2009, 09:21   #6 (permalink)
GSMtricks's Avatar
Member: 3610
Sonork: 100.54638
Thanks Meter: 1,652
then wat can i do ?
You are using their soft now our. We dont support other softwares. If you want to ask why infinity soft not working - ask in their section.
Old 07-29-2009, 09:50   #7 (permalink)
Member: 57456
Thanks Meter: 11
my padfinder is not working.....
sir, then tell me which is your software ?
Old 09-22-2009, 18:25   #8 (permalink)
Member: 32705
Thanks Meter: 66
open padfinder tool. find your pinout then close padfinder (this puts padfinder back to uni-mode or the light should show red). open infinity software, select port where your padfinder is then run infinity software.
The Following User Says Thank You to neville For This Useful Post:
i cant use my cruiser log .... plz help Prof_Seiko D-Unlock Suite 11 01-22-2010 17:49
How to repear my ufs Box plese help me sekar_k HWK 1 12-12-2008 21:43
please help my i cant use my new box razorra_mooon UST Pro II 3 09-23-2008 18:06
why i cant update my padfinder box firmware richardnikko PadFinder box 3 07-08-2008 17:30
Page generated in 0.17599 seconds with 9 queries
