Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Nokia Fault Finder Box
Old 05-02-2010, 14:47   #1 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
HWK Repair Box..
HWK Repair Box..........
Thanks
The Following 23 Users Say Thank You to bappi1 For This Useful Post:
Old 07-31-2010, 02:09   #2 (permalink)
Member: 1347523
Thanks Meter: 3
my hwk box in< >dual serial ,so pls solution
The Following 2 Users Say Thank You to sanjay2170 For This Useful Post:
Old 07-31-2010, 02:10   #3 (permalink)
Member: 1347523
Thanks Meter: 3
hwk box problem
my hwk in< > dual serial mode
The Following User Says Thank You to sanjay2170 For This Useful Post:
Old 07-31-2010, 05:35   #4 (permalink)
mmrozibul's Avatar
Member: 725443
Sonork: 100.1601305
Thanks Meter: 330
Contact me by [email protected]
The Following User Says Thank You to mmrozibul For This Useful Post:
Old 07-31-2010, 06:08   #5 (permalink)
Registered User
Member: 407063
Thanks Meter: 2,133
your box eeprom is demage you need repair eeprom and use thsi tool your prb solve 100%
UFS repair tool - WBGSM
The Following 2 Users Say Thank You to naeem_skg786 For This Useful Post:
Old 07-31-2010, 06:14   #6 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Thanks
dear brother can we repear error 45 hwk not connected?
The Following 2 Users Say Thank You to asif123456789 For This Useful Post:
Old 07-31-2010, 06:42   #7 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
Thanks
The Following User Says Thank You to asif123456789 For This Useful Post:
Old 07-31-2010, 07:13   #8 (permalink)
UNLOCK PARK ®'s Avatar
Member: 1004001
Sonork: WhatsApp+971506319003
Thanks Meter: 448
Thanks your info...............
The Following User Says Thank You to UNLOCK PARK ® For This Useful Post:
Old 07-31-2010, 13:30   #9 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Dear it is possible to repair error 45 hwk not connected...
Contact with me......
VISIT HERE
The Following 2 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 07-31-2010, 13:54   #10 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
WE Can repair dead or not connected hwk 100%
ABDUL HAKEEM
[email protected]
The Following 3 Users Say Thank You to >>PakFones<< For This Useful Post:
Old 08-06-2010, 16:28   #11 (permalink)
tuffy123's Avatar
Member: 761145
Thanks Meter: 46
that was happen me before.When you click the DCTxBB5 it will prompt two serial number, just because before it happens you plug another box aside from the serial number you installed before.
Old 08-06-2010, 16:38   #12 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
try to have some sleep mate
Old 08-06-2010, 16:41   #13 (permalink)
tuffy123's Avatar
Member: 761145
Thanks Meter: 46
try this solution and do not install 2 box in one cpu as long as it has hwk orig and follow this procedure:
How to properly upgrade UFS box firmware .
1. Download and run UFS3Tool.exe, Connect>> select v2.6>>
check Write Firmware, Write Eeprom, Write 93c46 and
click Fix and Update buttons.
2. Reconnect box again>> select v2.5>> check only Write
Firmware and click Fix and Update buttons.You have a
downgraded UFS box with v2.5 firmware.
3. To upgrade it to v2.6 or v2.8, run UFS_DCTxBB5.exe -
DCTxBB5 TOOLS v.2.0.1. HWK by SarasSoft or higher,
you can use either original or patched.
4. Connect, and on warning message, choose Yes.
5. Now, your UFS box firmware is properly upgraded .
The Following 2 Users Say Thank You to tuffy123 For This Useful Post:
Old 08-06-2010, 16:43   #14 (permalink)
tuffy123's Avatar
Member: 761145
Thanks Meter: 46
@ bos
hehehe sori ....side effect of sleepy
Old 08-08-2010, 03:25   #15 (permalink)
Member: 685065
Thanks Meter: 2
best box
hwk or ub which box is best plz urjent
The Following User Says Thank You to sajawal_haq786 For This Useful Post:
Nokia "Contact Service" Repairer Dirk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 10-04-2011 05:45
i WANT TO BUY NOKIA BOX !!! Eric Wanted Products 8 02-14-2011 13:23
New NOKIA BOX - New Prices gsmEsteve Main Sales Section 0 12-03-2000 03:43
New Nokia BOX for you!!! gsmEsteve Main Sales Section 0 11-18-2000 17:09
Page generated in 0.22736 seconds with 9 queries
