6 credits for one T303 !!!! SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 30/0 CARD COUNTERS: FLASH 7, UNLOCK 153 Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:35379003298011 Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [2325] GOT SEED:CF8D3ED482019002C20078B8 P96 AUTH PASSED Unlock DONE Elapsed: 34 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 24/6 CARD COUNTERS: FLASH 7, UNLOCK 154 Elapsed: 2 secs.:confused: |
Next time you set : Signed mode Alternative bypass UNLOCK/REPAIR Now you know how to Unlock T303 for FREE BR Max_B |
6 credits unlock - is permanent unlock with signature recalculation. And unlock with Alternative bypass - is patch unlock - after flashing phone will be locked again. |
is this same thing like u5i vivaz ?? |
If you find just cheaper service, any box ... then the_laser will decrease to cheaper BR Max_B |
six(6)credit use to unlock w100i why dis u need give my credit back dis is de logs RUNNING v 1.09/UNI CARD SERIAL 00118328 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 6/24 CARD COUNTERS: FLASH 567, UNLOCK 158 Elapsed: 3 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Unlock FAILED Elapsed: 279 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 222 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 86 secs. CFG:000000000000 llbug:read error: "The parameter is incorrect" Can't load ID loader ! Elapsed: 111 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 85 secs. CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 17 secs. SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R6A037" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "0089/887E" LOADER VERSION: "R4A039" PHONE IMEI:35231304071940 MODEL (from GDFS): W100i SOFTWARE VERSION: 1230-3694_R1BE003 MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" CUSTOM VERSION: 1241-0874_R4A MINOR ERROR "MISC_ERROR (No_such_unit)" IN "MISC_CLASS" Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "C" BUTTON... EROM "R6A037" AID: 0001 SOFTWARE AID: 0001 LOADER AID: 0001 FLASH ID: "0089/887E" LOADER VERSION: "R4A039" PHONE IMEI:35231304071940 UCCK 8339124110020179 UNCK 0687677383068831 UNSCK 7609560814093474 USPCK 0942512965127735 Unlock DONE Elapsed: 19 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 SERVER CREDITS LEFT/USED: 0/30 CARD COUNTERS: FLASH 567, UNLOCK 159 Elapsed: 3 secs. |
It is not W100i that costs 6 logs only. It is Server use that costs 6 credits in whole. Do you server and you'll get charged 6 credits Add to bookmarks is a must CREDITS CONSUMPTION BR Max_B |
BR Max_B |
Code: Some users on different forums missunderstood information about update. I will confirm one more time, you do not need any activation to use v1.0 FINAL. It is free for all SEtool users. Full unlock is only workable via Signature server though (6 credits today) Signature server unlock is required to repair if IMEI or Secunits are damaged, Otherwise who on earth will update T303 firmware after unlock ? Hope all is clear ;) BR Max_B |
