Any help htc one v to unlock LGE Tool version: 2.1 OS Version: Windows XP [NT 5.1] Service Pack 3 Administrative privileges: yes Locale: Netherlands / Dutch CPU frequency: 3008 MHz Total memory: 3327 MB Free memory: 2327 MB Free space on system disk C:\: 52.00 GB Free space on disk E:\: 46.00 GB Free space on disk F:\: 88.00 GB Connecting with One V To connect with this phone you should use special microSD cable. Press the button "Cable" to view pinout. In order to make microSD cable you should do the following: 1. Get microSD card (1Gb or 2Gb, don't use SDHC). 2. Get two thin wires. 3. Solder first wire to microSD to pin4(+2.8V..+3.3V). 4. Solder second wire to microSD to pin6(GND). 5. You can use any +3V source (even 2xAAA) as power supply. 6. Also you should use microSD card reader. 7. External power supply(+3V) needed only for the phone microSD reader. 8. Do not use external power supply with PC microSD reader. WARNING: Don't forget to click "Disconnect" at the end. Connected Receiving phone info In order to connect with phone you should: 1. Install HTC ADB drivers 2. Turn on the phone 3. Enable Debug mode in phone (Settings->Applications->USB Debug) 4. Check your Internet connection 5. Plug USB Cable WARNING: Don't forget to click "Disconnect" at the end. Probing ADB Interface... Android Debug Bridge version 1.0.29 Starting ADB server... Waiting for device... Device Found: SH2ABTV02177 Waiting for data... Waiting for boot completion... Waiting for device id... Getting data... Serial Number: SH2ABTV02177 Android Version: 4.0.3 Manufacturer: HTC Model: HTC One V Hardware: primou ROM Version: 2.22.401.1 BOOT Version: 1.18.0000 IMEI: 353115-05-949969-8 CID: HTC__E11 / HTC-Dutch Backup CID: HTC__001 Linux Kernel Version: 3.0.16-g133e482 Removing Root Privileges... Stopping ADB server... Info received Reading codes Searching microSD disk... MicroSD disk found: Volume: J:\ Device: \\.\PhysicalDrive4 Label: HTCTOOL Size: 1028096 Writing image to microSD disk... Writing image to microSD disk: OK Waiting for User's Actions... Searching microSD disk... MicroSD disk found: Volume: J:\ Device: \\.\PhysicalDrive4 Label: HTCTOOL Size: 1028096 Reading codes... Connecting to server... Sending data to server... Receiving data from server... Server Error: Incorrect Phone Data Action cancelled |
