Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 12-06-2009, 17:29   #16 (permalink)
Member: 455304
Thanks Meter: 416
once the k800 is lock with 5 lock have to use 1 credit... click sign mode and use full unlock instead of reset code...and click unlock...remember to install modem driver... best of luck
Old 12-14-2009, 14:01   #17 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
Originally Posted by Umair Rashid View Post
Follow the three Simple Steps to Unlock Your A2 Cid 53
Remember :
1. I didn't select alternative security by pass option,and without it,it works like charm.
2.This process needs a Valid account(1 Credit )
3.First Make sure Your phone is Cid 53 .(Less than 53 are Free)
4.It's a Full Unlock (not patch)
(Thanks to Nadeem Gondal afterall)
well done ,,,,,,,,,,,,,,,,,,,,,,,,,,
Old 12-14-2009, 14:13   #18 (permalink)
alis's Avatar
Member: 206532
Sonork: 100.1622270
Thanks Meter: 874
c903 unlock done
v0.915056/UNI
CARD SERIAL: 0
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
CFG:100000000000
SERVER CREDITS LEFT/USED: 24/6
CARD COUNTERS: FLASH 1221, UNLOCK 507
Elapsed: 3 secs.
CFG:100001000000
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Elapsed: 8 secs.
CFG:100001000000
ChipID:E900,EMP protocol:0401
BOOTROM MODE DETECTED
OTP LOCKED:1 CID:53 PAF:1 IMEI:3 CERT:RED
LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
Model (from GDFS):C903
MAPP CXC article: R1EA032 prg1214-6175_HUTCHISON_FR
MAPP CXC version: R1EA032
Language Package: HUTCH-WORLD
CDA article: 1223-5605
CDA version: R10A
Default article: 1214-6153
Default version: R1EA032
PROVIDER: MULTIPLE
Network LOCKED
Elapsed: 11 secs.
CFG:100001000000
OTP LOCKED:1 CID:53 PAF:1 IMEI:35CERT:RED
LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
Executing CSCA-based unlock.
Checking for signature...
CAN'T CONNECT TO SERVER.
signature calculation not done,err: 144
Elapsed: 32 secs.
CFG:100001000000
Elapsed: 2 secs.
CFG:100001000000
OTP LOCKED:1 CID:53 PAF:1 IMEI: CERT:RED
Waiting for calculation process...
RESPONSE: "SUCCESS" [1038]
GOT SEED3D1C9A63580E6673510DD71
P96 AUTH PASSED
Backup security data...
Erasing locks...
Unlock DONE
Elapsed: 19 secs.
The Following User Says Thank You to alis For This Useful Post:
Old 12-15-2009, 20:04   #19 (permalink)
Member: 779470
Sonork: Waseem mobile
Thanks Meter: 101
Arrow Unlock DONE t715
12/15/2009 11:31:41 PM Model (from GDFS):T715
12/15/2009 11:31:41 PM MAPP CXC article: R1GA026 prg1222-7136_HUTCHISON_AM
12/15/2009 11:31:41 PM MAPP CXC version: R1GA026
12/15/2009 11:31:41 PM Language Package: HUTCH-WORLD
12/15/2009 11:31:41 PM CDA article: 1227-0475
12/15/2009 11:31:41 PM CDA version: R9A
12/15/2009 11:31:41 PM Default article: 1220-5169
12/15/2009 11:31:41 PM Default version: R1GA026
12/15/2009 11:31:42 PM PROVIDER: MULTIPLE
12/15/2009 11:31:42 PM Network LOCKED
Unlock DONE
12/15/2009 11:46:18 PM SERVER CREDITS LEFT/USED: 29/1
12/15/2009 11:46:20 PM CARD COUNTERS: FLASH 256, UNLOCK 224
12/15/2009 11:46:20 PM Elapsed: 7 secs.
12/15/2009 11:46:57 PM SIGNED MODE (USING SERVER)
12/15/2009 11:46:57 PM CFG:100001000000
12/15/2009 11:47:03 PM ChipID:E900,EMP protocol:0401
12/15/2009 11:47:04 PM PHONE STATE: "RETAIL"
12/15/2009 11:47:04 PM FLASH CID: 0053
12/15/2009 11:47:05 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703131388 CERT:RED
12/15/2009 11:47:06 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
12/15/2009 11:47:06 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
12/15/2009 11:47:07 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
12/15/2009 11:47:07 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
12/15/2009 11:47:07 PM Executing CSCA-based unlock.
12/15/2009 11:47:07 PM Checking for signature...
12/15/2009 11:47:08 PM Waiting for calculation process...
12/15/2009 11:47:09 PM RESPONSE: "SUCCESS" [1038]
12/15/2009 11:47:11 PM GOT SEEDDD6ECC33580137135C01320
12/15/2009 11:47:11 PM P96 AUTH PASSED
12/15/2009 11:47:11 PM Backup security data...
12/15/2009 11:47:11 PM Erasing locks...
12/15/2009 11:47:12 PM Unlock DONE
12/15/2009 11:47:13 PM Elapsed: 15 secs.
12/15/2009 11:47:27 PM SIGNED MODE (USING SERVER)
12/15/2009 11:47:27 PM CFG:100001000000
12/15/2009 11:47:30 PM SERVER CREDITS LEFT/USED: 28/2
12/15/2009 11:47:32 PM CARD COUNTERS: FLASH 256, UNLOCK 224
12/15/2009 11:47:32 PM Elapsed: 4 secs.
The Following 2 Users Say Thank You to waseem pirmahal For This Useful Post:
Old 01-27-2010, 07:35   #20 (permalink)
..::HITU::..'s Avatar
Member: 1212089
Thanks Meter: 123
T715 unlock done !!!
The Following User Says Thank You to ..::HITU::.. For This Useful Post:
Old 01-27-2010, 10:27   #21 (permalink)
Member: 1212089
Thanks Meter: 123
Again t715i unlock done !!!
1/27/2010 2:52:50 PM SIGNED MODE (USING SERVER)
1/27/2010 2:52:50 PM CFG:100000000000
1/27/2010 2:52:51 PM SERVER CREDITS LEFT/USED: 18/12
1/27/2010 2:52:52 PM CARD COUNTERS: FLASH 683, UNLOCK 390
1/27/2010 2:52:52 PM Elapsed: 2 secs.
1/27/2010 2:52:58 PM SIGNED MODE (USING SERVER)
1/27/2010 2:52:58 PM CFG:100001000000
1/27/2010 2:53:07 PM ChipID:E900,EMP protocol:0401
1/27/2010 2:53:08 PM BOOTROM MODE DETECTED
1/27/2010 2:53:10 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35662803073063 CERT:RED
1/27/2010 2:53:10 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/27/2010 2:53:10 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
1/27/2010 2:53:11 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/27/2010 2:53:11 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
1/27/2010 2:53:11 PM Executing CSCA-based unlock.
1/27/2010 2:53:11 PM Checking for signature...
1/27/2010 2:53:12 PM Waiting for calculation process...
1/27/2010 2:53:12 PM RESPONSE: "SUCCESS" [1038]
1/27/2010 2:53:13 PM GOT SEED:59051CFD358014713570D611
1/27/2010 2:53:14 PM P96 AUTH PASSED
1/27/2010 2:53:14 PM Backup security data...
1/27/2010 2:53:14 PM Erasing locks...
1/27/2010 2:53:15 PM Unlock DONE
1/27/2010 2:53:15 PM Elapsed: 16 secs.
Old 01-28-2010, 11:46   #22 (permalink)
Member: 1212089
Thanks Meter: 123
Again t715 unlock done !!!
1/28/2010 4:12:01 PM SERVER CREDITS LEFT/USED: 17/13
1/28/2010 4:12:03 PM CARD COUNTERS: FLASH 686, UNLOCK 392
1/28/2010 4:12:03 PM Elapsed: 2 secs.
1/28/2010 4:12:12 PM SIGNED MODE (USING SERVER)
1/28/2010 4:12:12 PM CFG:100001000000
1/28/2010 4:12:18 PM ChipID:E900,EMP protocol:0401
1/28/2010 4:12:18 PM PHONE STATE: "RETAIL"
1/28/2010 4:12:18 PM FLASH CID: 0053
1/28/2010 4:12:20 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35662803119085 CERT:RED
1/28/2010 4:12:20 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
1/28/2010 4:12:20 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
1/28/2010 4:12:22 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
1/28/2010 4:12:22 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
1/28/2010 4:12:22 PM Executing CSCA-based unlock.
1/28/2010 4:12:22 PM Checking for signature...
1/28/2010 4:12:22 PM Waiting for calculation process...
1/28/2010 4:12:22 PM RESPONSE: "SUCCESS" [1038]
1/28/2010 4:12:23 PM GOT SEED:371C2FA53580147135D0121D
1/28/2010 4:12:24 PM P96 AUTH PASSED
1/28/2010 4:12:24 PM Backup security data...
1/28/2010 4:12:24 PM Erasing locks...
1/28/2010 4:12:25 PM Unlock DONE
1/28/2010 4:12:25 PM Elapsed: 12 secs.
1/28/2010 4:14:15 PM SIGNED MODE (USING SERVER)
1/28/2010 4:14:15 PM CFG:100000000000
1/28/2010 4:14:16 PM SERVER CREDITS LEFT/USED: 16/14
1/28/2010 4:14:18 PM CARD COUNTERS: FLASH 686, UNLOCK 392
1/28/2010 4:14:18 PM Elapsed: 2 secs.
Old 02-03-2010, 19:55   #23 (permalink)
Member: 1120374
Thanks Meter: 67
ALTERNATIVE SECURITY BYPASS ENABLED
PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5")
CFG:110000000000
OTP DBG: [1,53,1,35662803084131]
OTP LOCKED:1 CID:53 PAF:1 IMEI:35662803084131 CERT:RED
GOT CHALLENGE
GOT SEED:EAF216A83580147135308A14
GOT RESPONSE
signoff response ok
P96 AUTH PASSED
DEVICE KEY:147E4CCB861D67FB66AEDC35078EA39A (0)
RESTARTING...
LDR:2009-04-21 18:39 1202-0417_DB3210_RESET_LOADER_ACC_SDRAM_R2A081
LDR:2009-04-21 18:40 1202-0416_DB3210_RESET_LOADER_APP_SDRAM_R2A081
GOT CHALLENGE
GOT SEED:B52E1B973580147135308A14
GOT RESPONSE
signoff response ok
P96 AUTH PASSED
RESETTING SECURITY TO FACTORY STATE...
RESTARTING...
OTP LOCKED:1 CID:53 PAF:1 IMEI:35662803084131 CERT:BROWN
LDR:2009-06-26 16:10 1202-0415_DB3210_PRODUCTION_LOADER_ACC_SDRAM_R2A082
LDR:2009-06-26 16:11 1202-0414_DB3210_PRODUCTION_LOADER_APP_SDRAM_R2A082
WRITING SEMCBOOT...
PREPARING SECURITY...
WRITING CLEAR SIMLOCK UNITS...
ALL UNLOCK/LOCK CODES SET TO "04010781"
CHANGING DOMAIN TO "CURRENT"
SIGNING...
DEVICE KEY RESTORED
Unlock FINISHED
Elapsed: 70 secs.
CFG:110000000000
SERVER CREDITS LEFT/USED: 9/21
CARD COUNTERS: FLASH 435, UNLOCK 245
Elapsed: 13 secs.
The Following User Says Thank You to ATUGA For This Useful Post:
Old 02-05-2010, 06:31   #24 (permalink)
Member: 169579
Thanks Meter: 10
pls help, i tried to unlock G502, but phone cannot be detected when press C & insert cable. Im using cruiser 5-in-1 cable. Driver installed. Cable is detected in com port. Has anyone tried this cable for unlocking using setool?
Pls share usb dcu-60 cable pins out, i may have to try one.
b.r
Old 02-05-2010, 11:35   #25 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,032
DCU-60 is the cable that comes with the Package. Cable use is only USB Cable(DCU60 or DCU-65)
Old 02-08-2010, 08:07   #26 (permalink)
Shahid_Toshiba0's Avatar
Member: 756180
Sonork: 100.1582554
Thanks Meter: 56
shahid_toshiba01: v0.915057/UNI
CARD SERIAL: 00080064
CFG:000000000000
ChipID:8040,EMP protocol:0301
FLASH CID: 0049
Speed:921600
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35434201171174 CERT:RED
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Starting embedded bootloader...
INT LDRB2010_RESPIN_ID_LOADER_SETOOL2
LDRB2010_RESPIN_PRODLOADER_SETOOL2
FLASH ID:2019
FOUND VERSION "R4DA044_CXC1250466_GENERIC_DO"
Setting up GDFS...
ALL UNLOCK/LOCK CODES SET TO "51111686"
SIGNING...
Unlock FINISHED
Elapsed: 62 secs.
after unlock searching then error no network coverege
plz help anybody
Last message received on 2/8/2010 at 12:33 PM
Old 02-08-2010, 21:52   #27 (permalink)
Member: 169579
Thanks Meter: 10
help-G502 cannot be identified
I installed drivers for G502, when plugged phone with DCU-60 to USB port, phone detected by pc to load pics,etc...but v0.915057 cant detect the phone when press 'identify'.
check connector, all pins clean. dcu-60 used can detect w910i. pls help, why this G502 phone can't be detected by v0.915057.
thanks for your help
Old 02-09-2010, 08:28   #28 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
v0.915057/UNI
CARD SERIAL:
CFG:000000000000
FLASH CID: 0053
OTP LOCKED:1 CID:53 PAF:1 IMEI:35427803544582 CERT:RED
Elapsed: 21 secs.
CDA version: R10A
PROVIDER: MULTIPLE
Network LOCKED
SECURITY UNITS BACKUP CREATED.
Elapsed: 18 secs.
CFG:110000000000
OTP DBG: [1,53,1,35427803544582]
server step1 error:bad username/password.
Elapsed: 35 secs.
CFG:100001000000
SERVER CREDITS LEFT/USED: 26/4
CARD COUNTERS: FLASH 68, UNLOCK 14
Elapsed: 5 secs.
CFG:100001000000
FLASH CID: 0053
GOT SEED:B97AD01A3580E6673560F484
P96 AUTH PASSED
Erasing locks...
Unlock DONE
Elapsed: 27 secs.
CFG:100001000000
SERVER CREDITS LEFT/USED: 25/5
Elapsed: 3 secs.
CFG:100001000000
FLASH CID: 0053
CDA version: R10A
PROVIDER: 000-00
SIMLOCKS NOT DETECTED
The Following 2 Users Say Thank You to msashami For This Useful Post:
Old 02-18-2010, 12:35   #29 (permalink)
Member: 893958
Thanks Meter: 3
Hi Guys,
anyone knows how to flash lang on T715, I mean which options should be ticked apart from the "sign mode".
Thanks in advance.
Falak
Old 02-24-2010, 14:35   #30 (permalink)
Member: 1212089
Thanks Meter: 123
2/24/2010 6:56:48 PM v0.915056/UNI
2/24/2010 6:56:48 PM CARD SERIAL: ********
2/24/2010 6:56:48 PM Loaded 51 flash descriptors
2/24/2010 6:57:07 PM SIGNED MODE (USING SERVER)
2/24/2010 6:57:07 PM CFG:100000000000
2/24/2010 6:57:08 PM SERVER CREDITS LEFT/USED: 9/21
2/24/2010 6:57:10 PM CARD COUNTERS: FLASH 703, UNLOCK 398
2/24/2010 6:57:10 PM Elapsed: 3 secs.
2/24/2010 6:58:56 PM SIGNED MODE (USING SERVER)
2/24/2010 6:58:56 PM CFG:100001000000
2/24/2010 6:59:06 PM ChipID:E900,EMP protocol:0401
2/24/2010 6:59:06 PM PHONE STATE: "RETAIL"
2/24/2010 6:59:06 PM FLASH CID: 0053
2/24/2010 6:59:07 PM OTP LOCKED:1 CID:53 PAF:1 IMEI:35662703560708 CERT:RED
2/24/2010 6:59:08 PM LDR:2009-06-26 16:03 1202-0421_DB3210_CS_LOADER_ACC_SDRAM_R2A082
2/24/2010 6:59:08 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH
2/24/2010 6:59:09 PM LDR:2009-06-26 16:04 1202-0420_DB3210_CS_LOADER_APP_SDRAM_R2A082
2/24/2010 6:59:09 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA
2/24/2010 6:59:09 PM Executing CSCA-based unlock.
2/24/2010 6:59:09 PM Checking for signature...
2/24/2010 6:59:09 PM Waiting for calculation process...
2/24/2010 6:59:10 PM RESPONSE: "SUCCESS" [1038]
2/24/2010 6:59:11 PM GOT SEED:8060C751358013713540E488
2/24/2010 6:59:12 PM P96 AUTH PASSED
2/24/2010 6:59:12 PM Backup security data...
2/24/2010 6:59:12 PM Erasing locks...
2/24/2010 6:59:13 PM Unlock DONE
2/24/2010 6:59:13 PM Elapsed: 17 secs.
2/24/2010 6:59:16 PM SIGNED MODE (USING SERVER)
2/24/2010 6:59:16 PM CFG:100001000000
2/24/2010 6:59:17 PM SERVER CREDITS LEFT/USED: 8/22
2/24/2010 6:59:21 PM CARD COUNTERS: FLASH 703, UNLOCK 398
2/24/2010 6:59:21 PM Elapsed: 4 secs.
sucessfully unlocked w995 CID 53 in setool it cost1 crdeit azad4u SETool2 1 01-01-2010 17:36
unlock A2 CID 53????????? dzedzui_the Sony Ericsson 2 11-20-2009 19:38
need a2 cid 53 csca last step, modem driver for T707 kaholukkk Universalbox 0 08-29-2009 15:28
how to unlock k800 cid 53 nilan DreamBox 7 11-13-2008 17:56
how to unlock w200 cid 53 doller DreamBox 6 06-09-2008 16:41
Page generated in 0.26130 seconds with 10 queries
