05-15-2010, 13:51 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 273834 Status: Offline Thanks Meter: 68 | sony j10i unlock problem CARD SERIAL 00070979 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 9 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 SERVER CREDITS LEFT/USED: 29/1 CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 5 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Elapsed: 20 secs. SIGNED MODE (USING SERVER) CFG:100001000000 SERVER CREDITS LEFT/USED: 28/2 CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 14 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100001000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 20 secs. |
05-15-2010, 15:13 | #3 (permalink) |
Member: 273834 Status: Offline Thanks Meter: 68 | AFTER ACTIVATION RUNNING v 1.06/UNI CARD SERIAL 00070979 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 PROCEDURE WAS STOPPED BY USER Can't load ID loader ! Elapsed: 179 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... CAN'T CONNECT TO SERVER. signature calculation not done,err: 144 Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100010000000 PROCEDURE WAS STOPPED BY USER FAILED TO SETUP PHONE Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 8/2 CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 4 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Elapsed: 27 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 8/2 CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. CFG:000010000000 ChipID:F100,EMP protocol:0401 PHONE STATE: "RETAIL" FLASH CID: 0080 OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock FINISHED Elapsed: 150 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED ALTERNATIVE SECURITY BYPASS NOT SUPPORTED FOR THAT PHONE Elapsed: 15 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 13 secs. |
05-15-2010, 19:46 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: {JUST@PRAY@FOR@ME} Age: 39
Member: 288504 Status: Offline Sonork: .:100.1587032:. Thanks Meter: 2,266 | version 1.04 will work fine, check next settings: signed mode, do full unlock, bypass flash mode activation for semc a2 modem drivers included in 1.04 distr. |
05-17-2010, 12:56 | #5 (permalink) |
Member: 273834 Status: Offline Thanks Meter: 68 | RUNNING v 1.04/UNI CARD SERIAL 00070979 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 No server found. CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100000000000 SERVER CREDITS LEFT/USED: 8/2 CARD COUNTERS: FLASH 1032, UNLOCK 208 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Elapsed: 25 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 14 secs. CFG:000000000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock FINISHED Elapsed: 10 secs. SIGNED MODE (USING SERVER) CFG:100100000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA USERCODE RESET TO "0000" phone detached Elapsed: 11 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:bad username/password. Elapsed: 13 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID:F100,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403067291] OTP LOCKED:1 CID:80 PAF:1 IMEI:35987403067291 CERT:RED LDR:2010-01-28 19:58 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH SIGNATURE AUTH LDR:2010-01-28 19:59 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A093 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature... signature found, skipping calculation server error:remote dongle not available Elapsed: 11 secs. |
05-17-2010, 17:55 | #8 (permalink) |
No Life Poster Join Date: Sep 2007 Location: algeria
Member: 591880 Status: Offline Thanks Meter: 561 | show your probleme to laser Official support (English)) |
06-28-2013, 16:24 | #9 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1711684 Status: Offline Sonork: 76413-640-7229107-23039 Thanks Meter: 0 | avec 3 crédit (signed mode, full unlock, disable flash mode activation) SIGNED MODE (USING SERVER) CFG:100011000000 ChipID: F100, EMP protocol: 0401 BOOTROM MODE DETECTED OTP DBG: [1,80,1,35987403439875] OTP: LOCKED:1 CID:80 PAF:1 IMEI:35987403439875 CERT:RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... signature found, skipping calculation Backup security data ... Erasing locks ... DISCONNECT PHONE NOW REMOVE SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM121 PHONE READY TO PROCEED. GOT SEED: 0085B927 ACTIVATION COMPLETED. USERCODE RESET TO "0000" DO NOT DISCONNECT PHONE FROM CABLE UNTIL PHONE TURNS ON BY ITSELF Unlock DONE |
10-06-2013, 20:12 | #11 (permalink) |
No Life Poster Join Date: Dec 2011 Location: Poland
Member: 1704846 Status: Offline Sonork: 1617108 Thanks Meter: 117 | When you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
