06-02-2008, 11:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: galleria suites Age: 42
Member: 754225 Status: Offline Thanks Meter: 145 | K320 unlocked!!!! v0.914034/UNI CARD SERIAL: 00000000 Loaded 51 flash descriptors SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 OTP LOCKED:1 CID:50 PAF:1 IMEI:35670601926181 CERT:RED LDR:060712 1520 HAN_DB2012_FLASHLOADER_R1A002_CXC1250695 Flash ID check:897E Flash props sent ok LDR:070410 1405 HANCXC1327364_COMPACT_SEMC_CS_LOADER_1_R3B009 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN BE SURE THAT YOU SET PHONE IN "PHONE MODE" IF ASKED, INSTALL PHONE DRIVERS SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM20 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS RED RETAIL PRODUCT FLASH CID detected:50 Speed:921600 Trying to launch embedded bootloader... INT LDR:COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R4EA031_CXC1250683_CHINA_MA Restore from:R4EA031_CXC1250683_CHINA_MA Searching... Firmware SIMLOCK check determined. Unlock DONE Elapsed: 158 secs. |
The Following User Says Thank You to iceman_27 For This Useful Post: |
k320 unlock | vlad_man | Universalbox | 3 | 08-14-2007 14:13 |
k320 unlock | TITO | Universalbox | 1 | 07-09-2007 15:23 |
k320 unlock | TITO | Universalbox | 1 | 07-02-2007 07:51 |
K320 Unlock ?? | mily2 | Cruiser Suite | 6 | 03-11-2007 11:10 |
