ERROR!!! MT11i.....qcReceivePacket: can't get packet start. i'm trying to unlock MT11i with SETOOL but i get this error PROCESSING ... qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED please help me to solve this porblem.thanks |
COMPLETE LOG!!!!!!!! SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" qcReceivePacket: can't get packet start. FAILED TO SETUP PHONE Unlock FAILED Elapsed: 21 secs. |
Setool support site information: if phone new security, it will not be unlocked and no harm will be done to phone. 2012 year all Sony Ericsson new security bug fixed, closed, can't unlock! |
@gsm_jatt2 U Connect Bad TP So that's y u facing this Problem Connect Correct TP & Then try to unlock ur phone again.. |
TP is right,its not first time im doing this i have done it before many times, but never i have sen this error. may be there is another problem, please help me to slove this. its urgent. |
answer from lazer q: i'm trying to unlock msm8x55-based phone, i'm sure that procedure done properly, but i'm always receive error: a: bad luck, that is mcu with fixed security flaw and you can not unlock,repair trim area, repair semcboot, rebuild hwconfig using altbypass method. |
i have tried on two diffrent PCs but still the same problem ( |
http://forum.gsmhosting.com/vbb/8425625-post10.html |
