HTC Desire S S-OFF and CId change done by Lgtool :
Connecting with Desire S
To connect with this phone you should use special microSD cable.
Press the button "Cable" to view pinout.
In order to make microSD cable you should do the following:
1. Get microSD card (1Gb or 2Gb, don't use SDHC).
2. Get two thin wires.
3. Solder first wire to microSD to pin4(+2.8V..+3.3V).
4. Solder second wire to microSD to pin6(GND).
5. You can use any +3V source (even 2xAAA) as power supply.
6. Also you should use microSD card reader.
7. External power supply(+3V) needed only for the phone microSD reader.
8. Do not use external power supply with PC microSD reader.
WARNING: Don't forget to click "Disconnect" at the end.
Connected
Repairing Security
Searching microSD disk...
MicroSD disk found:
Volume: N:\
Device: \\.\PhysicalDrive2
Label:
Writing image to microSD disk...
Writing image to microSD disk: OK
Waiting for User's Actions...
MicroSD disk found:
Volume: N:\
Label: HTCTOOL
Reading HBOOT...
Connecting to server...
Sending data to server...
Receiving data from server...
Patching Security: S-OFF
Writing HBOOT...
Security successfully repaired
Changing CID
Action cancelled
Changing CID
MicroSD disk found:
Volume: N:\
Label: HTCTOOL
MicroSD disk found:
Volume: N:\
Label: HTCTOOL
Reading HBOOT...
Patching CID: 11111111...
Writing HBOOT...
CID successfully repaired
