04-26-2009, 13:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 44
Member: 889422 Status: Offline Thanks Meter: 182 | w850i cid 49 unlock 100% 4/25/2009 10:01:19 PM ChipID:9900,EMP protocol:0301 4/25/2009 10:01:20 PM 4/25/2009 10:01:20 PM PHONE STATE: "RETAIL" 4/25/2009 10:01:20 PM FLASH CID: 0049 4/25/2009 10:01:20 PM Speed:115200 4/25/2009 10:01:20 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101693889 CERT:RED 4/25/2009 10:01:20 PM FLASH CID:49 COLOR:RED 4/25/2009 10:01:21 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 4/25/2009 10:01:22 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 4/25/2009 10:01:22 PM Flash ID check:2019 4/25/2009 10:01:22 PM Flash props sent ok 4/25/2009 10:01:22 PM writing "F:\mushtaq SEtool flashing files\Setool flash files\sony W\w850 cid 49 red ok\R1ED001_1250204_CHINA_CY.ssw.cry" 4/25/2009 10:01:29 PM CURRENT FLASH FILE CID:49 4/25/2009 10:01:29 PM SSW uses full hash, hash len is:9100 4/25/2009 10:01:30 PM Will flash 455 blocks... 4/25/2009 10:05:45 PM SSW loading returns:0 4/25/2009 10:05:46 PM writing "F:\mushtaq SEtool flashing files\Setool flash files\sony W\w850 cid 49 red ok\R1ED001_HONG_KONG_fs.ssw.cry" 4/25/2009 10:05:52 PM CURRENT FLASH FILE CID:49 4/25/2009 10:05:52 PM SSW uses full hash, hash len is:4820 4/25/2009 10:05:52 PM Will flash 241 blocks... 4/25/2009 10:07:56 PM SSW loading returns:0 4/25/2009 10:07:59 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 4/25/2009 10:07:59 PM loader startup: executed 4/25/2009 10:08:22 PM loader GDFS startup: executed 4/25/2009 10:08:35 PM loader filesystem startup: executed 4/25/2009 10:08:35 PM loader unlock: executed 4/25/2009 10:08:36 PM writing "tpa/preset/custom/C3_PCA_G3v2.cer" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/customize.xml" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/DESKTOP_HOOK_2.itm" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/Entrust.net Root Certificate.cer" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt" 4/25/2009 10:08:36 PM writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm" 4/25/2009 10:08:37 PM writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm" 4/25/2009 10:08:37 PM writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/GAMES_HOOK_3.itm" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/GTE_CyberTrust_Root.cer" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/Root.cer" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt" 4/25/2009 10:08:38 PM writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm" 4/25/2009 10:08:39 PM writing "tpa/preset/custom/ThawtePremium.der" 4/25/2009 10:08:39 PM writing "tpa/preset/custom/ThawteServerCA.cer" 4/25/2009 10:08:39 PM writing "tpa/preset/custom/Utiroot.cer" 4/25/2009 10:08:39 PM writing "tpa/preset/custom/VeriSignClass3Root.cer" 4/25/2009 10:08:39 PM writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt" 4/25/2009 10:08:39 PM Phone detached 4/25/2009 10:08:41 PM Elapsed: 447 secs. 4/25/2009 10:10:25 PM SIGNED MODE (USING SERVER) 4/25/2009 10:10:25 PM ALTERNATIVE SECURITY BYPASS ENABLED. 4/25/2009 10:10:25 PM PRELOADER SECURITY BYPASS ENABLED. 4/25/2009 10:10:29 PM ChipID:9900,EMP protocol:0301 4/25/2009 10:10:29 PM 4/25/2009 10:10:29 PM PHONE STATE: "RETAIL" 4/25/2009 10:10:29 PM FLASH CID: 0049 4/25/2009 10:10:29 PM Speed:115200 4/25/2009 10:10:29 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101693889 CERT:RED 4/25/2009 10:10:29 PM FLASH CID:49 COLOR:RED 4/25/2009 10:10:30 PM PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 4/25/2009 10:10:31 PM LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 4/25/2009 10:10:31 PM Flash ID check:2019 4/25/2009 10:10:31 PM Flash props sent ok 4/25/2009 10:10:33 PM LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 4/25/2009 10:10:33 PM loader startup: executed 4/25/2009 10:10:53 PM loader GDFS startup: executed 4/25/2009 10:11:01 PM loader filesystem startup: executed 4/25/2009 10:11:01 PM loader unlock: executed 4/25/2009 10:11:06 PM 4/25/2009 10:11:06 PM DISCONNECT PHONE NOW 4/25/2009 10:11:06 PM INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN 4/25/2009 10:11:06 PM INSTALL PHONE MODEM DRIVERS IF NEEDED 4/25/2009 10:11:06 PM 4/25/2009 10:11:06 PM SEARCHING FOR PHONE, "STOP" TO ABORT 4/25/2009 10:11:46 PM PROCEDURE WAS STOPPED BY USER 4/25/2009 10:11:46 PM Can't find attached phone with IMEI 35240101693889 4/25/2009 10:11:46 PM Elapsed: 81 secs. 4/25/2009 10:11:54 PM PRELOADER SECURITY BYPASS ENABLED. 4/25/2009 10:12:04 PM ChipID:9900,EMP protocol:0301 4/25/2009 10:12:04 PM 4/25/2009 10:12:04 PM PHONE STATE: "RETAIL" 4/25/2009 10:12:04 PM FLASH CID: 0049 4/25/2009 10:12:04 PM Speed:115200 4/25/2009 10:12:05 PM Trying to launch embedded bootloader... 4/25/2009 10:12:35 PM embedded flashloader not responds ! 4/25/2009 10:12:35 PM Elapsed: 40 secs. 4/25/2009 10:12:51 PM PRELOADER SECURITY BYPASS ENABLED. 4/25/2009 10:12:56 PM ChipID:9900,EMP protocol:0301 4/25/2009 10:12:56 PM 4/25/2009 10:12:56 PM PHONE STATE: "RETAIL" 4/25/2009 10:12:56 PM FLASH CID: 0049 4/25/2009 10:12:56 PM Speed:115200 4/25/2009 10:12:57 PM Trying to launch embedded bootloader... 4/25/2009 10:12:57 PM INT LDRB2020_PRELOADER_FOR_SETOOL2 4/25/2009 10:12:57 PM OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101693889 CERT:RED 4/25/2009 10:12:59 PM LDRB2020 LOADER FOR SETOOL2 4/25/2009 10:13:10 PM FOUND VERSION "R1ED001_CXC1250204_CHINA_CY" 4/25/2009 10:13:19 PM USERCODE RESET TO "0000" 4/25/2009 10:13:19 PM Searching... 4/25/2009 10:13:21 PM Firmware SIMLOCK check determined. 4/25/2009 10:13:25 PM Unlock DONE 4/25/2009 10:13:26 PM Elapsed: 34 secs. |
The Following 5 Users Say Thank You to best_unlocking For This Useful Post: |
08-31-2009, 13:44 | #5 (permalink) |
Junior Member Join Date: Jun 2009 Location: UK
Member: 1049886 Status: Offline Thanks Meter: 3 | How do you do this? any links to the software used? im trying to unlock an old w850i for my sister to use, currently locked to Three network (uk) I'm trying to unlock using Setoollite + SIMLockPatchGen but i don't have the frirmware files etc Please help! Thanks |
help to unlock my SE w850i cid 49 | chris2007 | FuriousGold | 1 | 04-30-2009 02:28 |
W850i cid 49 red that died | Roderick626 | Cruiser Suite | 2 | 03-11-2009 11:54 |
W850i CID 49 or 52 | SkyNet4u | HWK | 9 | 10-12-2008 13:48 |
w850i cid 52not unlocking | jtg | FuriousGold | 5 | 11-24-2007 22:50 |
how to k608i cid 49 unlock and debrand? | sgufa | Cruiser Suite | 3 | 03-06-2006 19:11 |
