Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 02-21-2009, 15:29   #1 (permalink)
Member: 926425
Thanks Meter: 33
how to repair and unlock w380 with setool?
sir
i received a set for flashing with problem of camra but when i flashed with the files R9BB001_APP_SW_1201_4421_GENERIC_LE_RED_CID53_PNX5 230.ssw and R9BB001_FS_ORANGE_GEN_LE_RED_CID53.ssw the phone now giving me confegration error contatct network operator following info is from mobile showing
1. erom_readvar: error reading unit 2/DE5
2. Network LOCKED
plz wat should i do. plz help me
thanx
khalid khan
v0.915032/UNI
CARD SERIAL: 00075326
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED.
PRELOADER SECURITY BYPASS ENABLED.
ChipID000,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0053
skipping empty loader...
OTP: LOCKED:1 CID:52 PAF:1 IMEI:35502502244626 CERT:RED
Model:W380i
MAPP CXC article: R9BB001 prg1201-4421_GENERIC_LE
MAPP CXC version: R9BB001
Language Package:TELEF_GEN
CDA article: 1205-1940
CDA version: R5A
Default article: 1201-4439
Default version: R9BB001
PROVIDER: 000-00
Network LOCKED
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
SECURITY UNITS BACKUP CREATED.
Elapsed: 9 secs.
The Following User Says Thank You to faizi_khalid For This Useful Post:
Old 02-28-2009, 15:43   #2 (permalink)
karlleeto's Avatar
Member: 383592
Thanks Meter: 91
Bro, You Need To Customize Your Set. In Setting, Tick Complete Phone After Flash And Press Flash. No Need To Put Flash File In Box, Just Leave It Empty.
The Following User Says Thank You to karlleeto For This Useful Post:
Old 03-01-2009, 13:55   #3 (permalink)
Member: 926425
Thanks Meter: 33
karlleeto
sir
thank u for ur advice and i did as u instructed but now the phone give me message insert correct sim is it to be lock or i should simply unlock the phone ur precious advice plz
thanx
khalid khan
Old 03-01-2009, 14:17   #4 (permalink)
Member: 956278
Sonork: mobileunlock2000
Thanks Meter: 6
try to unlock now with selection of signe mode and preloadr bypass and perform fullunlock options and post results here
Old 03-02-2009, 11:05   #5 (permalink)
Member: 926425
Thanks Meter: 33
karlleeto
hi sir i did the job for unlocking and the phone successfully unlock but no the phone didnt on and after unlock the mobile info shows that the gdfs failed fatal plz do advice as my phone dead now
Elapsed: 139 secs.
FLASH CID: 0053
Speed:921600
LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER
Flash ID check:2019
Flash props sent ok
writing "C:\Documents and Settings\hazrat bilal\Desktop\R9BB001_APP_SW_1201_4421_GENERIC_LE_ RED_CID53_PNX5230.ssw"
CURRENT FLASH FILE CID:53
SSW uses full hash, hash len is:9600
Will flash 480 blocks...
SSW loading returns:0
LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
writing "tpa/preset/custom/C3_PCA_G3v2.cer"
writing "tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm"
writing "tpa/preset/custom/customize.xml"
writing "tpa/preset/custom/DESKTOP_HOOK_2.itm"
writing "tpa/preset/custom/Entrust.net Root Certificate.cer"
writing "tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt"
writing "tpa/preset/custom/FM_PICTURES_HOOK_3.itm"
writing "tpa/preset/custom/FM_SOUNDS_HOOK_3.itm"
writing "tpa/preset/custom/FM_THEMES_HOOK_3.itm"
writing "tpa/preset/custom/FM_VIDEOS_HOOK_3.itm"
writing "tpa/preset/custom/GAMES_HOOK_3.itm"
writing "tpa/preset/custom/GTE_CyberTrust_Root.cer"
writing "tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt"
writing "tpa/preset/custom/Root.cer"
writing "tpa/preset/custom/SEMC_E2E_Root_CA.crt"
writing "tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm"
writing "tpa/preset/custom/ThawtePremium.der"
writing "tpa/preset/custom/ThawteServerCA.cer"
writing "tpa/preset/custom/Utiroot.cer"
writing "tpa/preset/custom/VeriSignClass3Root.cer"
writing "tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt"
Phone detached
Elapsed: 275 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
DISCONNECT PHONE NOW
INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
INSTALL PHONE MODEM DRIVERS IF NEEDED
SEARCHING FOR PHONE, "STOP" TO ABORT
PHONE FOUND AT COM9
PHONE READY TO PROCEED
EXECUTOR STARTED
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
FLASH CID: 0053
Speed:921600
Trying to launch embedded bootloader...
INT LDR:PNX5230_PRELOADER_FOR_SETOOL2
LDR:PNX5230_PRODUCTION_LOADER_FOR_SETOOL2
Flash ID check:2019
Flash props sent ok
FOUND VERSION "R9BB001_1201-4421_GENERIC_LE"
can't open file "C:\Documents and Settings\hazrat bilal\Desktop\v0.915034\rest\R9BB001_1201-4421_GENERIC_LE"
USERCODE RESET TO "0000"
Searching...
Firmware SIMLOCK check determined.
Unlock DONE
Elapsed: 177 secs.
after unlock phone info
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
GDFS startup failed (1D)
loader GDFS startup failed, that is fatal
Elapsed: 18 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed: 16 secs.
Old 03-02-2009, 11:07   #6 (permalink)
Member: 926425
Thanks Meter: 33
w380 dead after unlock done
karlleeto
Elapsed: 139 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Phone detached
Elapsed: 275 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
PHONE FOUND AT COM9
EXECUTOR STARTED
THEN PRESS "READY"
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Searching...
Unlock DONE
Elapsed: 177 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed: 18 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed: 16 secs.
Old 03-04-2009, 15:03   #7 (permalink)
Member: 956278
Thanks Meter: 6
so still you have not solved youir problem?
Old 03-04-2009, 15:25   #8 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,270
Flash props sent ok
that is ur falt
Old 03-17-2009, 14:39   #9 (permalink)
Member: 535835
Thanks Meter: 2
Originally Posted by mohsin-* View Post
Flash props sent ok
that is ur falt
try to pût this file "v0.915034\rest\R9BB001_1201-4421_GENERIC_LE" in restore file and try again
Old 04-10-2009, 14:29   #10 (permalink)
Member: 33954
Thanks Meter: 10
same problem here i try your solution same resault not work
4/10/2009 3:56:08 PM PHONE STATE: "RETAIL"
4/10/2009 3:56:08 PM FLASH CID: 0053
4/10/2009 3:56:08 PM Speed:921600
4/10/2009 3:56:09 PM OTP: LOCKED:1 CID:52 PAF:1 IMEI:35270402227239 CERT:RED
4/10/2009 3:56:10 PM LDR:071213 1552 PERCXC1720441_R2A022_PNX5230_FLASHLOADER
4/10/2009 3:56:10 PM Flash ID check:2019
4/10/2009 3:56:10 PM Flash props sent ok
4/10/2009 3:56:14 PM LDR:070904 1356 AN2CXC1250610_R3A016_PNX5230_CSLOADER
4/10/2009 3:56:14 PM loader startup: executed
4/10/2009 3:56:14 PM GDFS startup failed (1D)
4/10/2009 3:56:14 PM loader GDFS startup failed, that is fatal
4/10/2009 3:56:15 PM Elapsed: 25 secs.
The Following User Says Thank You to NEGRIA For This Useful Post:
Old 10-17-2010, 16:19   #11 (permalink)
ASIEDU ANNOR's Avatar
Member: 510345
Thanks Meter: 40
w380 still dead after flash
i flashed the above mentioned phone with setoolbox3 and its still off. it flashes as if its not dead then
Old 10-17-2010, 17:02   #12 (permalink)
Member: 510345
Thanks Meter: 40
try this
Check signed mode and complete phone after flash at the settings tab
Originally Posted by faizi_khalid View Post
karlleeto
Elapsed: 139 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Phone detached
Elapsed: 275 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
PHONE FOUND AT COM9
EXECUTOR STARTED
THEN PRESS "READY"
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Searching...
Unlock DONE
Elapsed: 177 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed: 18 secs.
FLASH CID: 0053
Speed:921600
Flash ID check:2019
Flash props sent ok
Elapsed: 16 secs.
how to repaire gdfs k750 cid49 with setool farid29 SETool2 2 01-03-2009 07:50
how i cane flash and unlock k550i withe setool karamfone SETool2 9 08-29-2008 13:40
how to complet pone after flash with setool lite lamine007 Sony Ericsson 4 01-21-2008 12:48
How to flash and unlock C139 with UBL? CRUELTY Ultima Box Light 1 04-07-2007 20:13
Page generated in 0.24378 seconds with 9 queries
