12-01-2012, 09:41 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: ATF Earth Age: 36
Member: 598395 Status: Offline Thanks Meter: 664 | Sony Ericsson LT15i Unlock Done CARD SERIAL 0002XXXX USBFLASH DRIVER VERSION 03.00.00.00 SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: 6E76783714018E9A61A2E4C7EEC229CABEB2E5AC FLASH ID: "0098/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 3581480416xxxx Checking for signature ... WRITING SEMCBOOT ... Unlock DONE Elapsed: 48 secs. |
The Following User Says Thank You to Sahil2007 For This Useful Post: |
12-08-2012, 11:38 | #2 (permalink) |
Registered User Join Date: Sep 2005 Location: On the path Age: 43
Member: 182574 Status: Offline Thanks Meter: 54 | SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_EROM VER "R9A021" EROM_AID : 0001 LOADER_AID : 0001 SW_AID : 0001 CUST_AID : 0001 SIM_LOCK_AID : 0001 DEVICE ID: B20A6A5676AAB70C9366C74E6AD4FB1A6AD32456 FLASH ID: "002C/00B3" LOADER VERSION: "R4A069" PHONE IMEI : 01XXXXXXXXXXXXXX MODEL (from GDFS): LT15i SOFTWARE VERSION: 1241-4324_4.1.B.0.587 CUSTOM VERSION: 1247-1722_R3I FILESYSTEM VERSION: VFE-1-8_4.1.B.0.587 SERIAL NO: XXXXXXXX Elapsed: 26 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 DETACH USB CABLE FROM PHONE REMOVE BATTERY FROM PHONE ATTACH TESTPOINT PRESS "READY", THEN ATTACH USB CABLE TO PHONE PROCESSING ... REMOVE TESTPOINT NOW, THEN PRESS "READY" PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ... RUNNING S1_LOADER VER "R4A069" EROM_AID : 0001 LOADER_AID : 0001 HWCONF_AID : 0001 ACTIVE_LOADER_AID : 0001 DEVICE ID: B20A6A5676AAB70C9366C74E6AD4FB1A6AD32456 FLASH ID: "002C/00B3" LOADER VERSION: "r4A069" PHONE IMEI : 012XXXXXXXXXXX Checking for signature ... WRITING SEMCBOOT ... Unlock DONE Elapsed: 205 secs. |
The Following User Says Thank You to Salem_Gsm For This Useful Post: |
